Fuel pump check valve
Discussion in '1st Gen Tundras (2000-2006)' started by cadillacjoe, May 27, 2025.
  1. May 27, 2025 at 7:46 AM
    cadillacjoe
    cadillacjoe [OP] New Member
    2002 Tundra SR5
    Has anyone ever installed a check valve in line coming from fuel pump when you have a failure of the in fuel pump check valve? This is just a temporary solution to postpone replacement of a fuel pump that's working fine with exception of check valve failure not holding pressure on fuel manifold/rail after sitting causing extended crank time to start.
