How screwed am I?
Discussion in '2.5 Gen Tundras (2014-2021)' started by point08, May 10, 2025.
  1. May 10, 2025 at 7:51 PM
    point08
    point08 [OP] New Member
    Kyle
    2014 Toyota Tundra 5.7L SR5 4WD DC
    AirLift LoadLifter 5000 Ultimate Plus, AirLift Wireless One 2nd Gen, TRD Rear Sway Bar, Bakflip G2 Tonneau Cover, Running Boards, Tint, Power Tailgate Lock, Hike-It X9 Throttle Controller, Tekonsha P3 Brake Controller with Custom In-Dash Housing, Method 701 Wheels, Toyo Open Country III Tires, 3WLiner Window Mod, External Fuse Box, Dash Cam, Pioneer DMH-1500NEX
    Dealing with the 'rat chewed my knock sensor' story that everyone has on here... I kept throwing a code with the 3rd party harness... so I bought an OEM harness and as I went to plug it in (tried to shortcut it with the lifting of the manifold), I realized I had loose cables in the harness from the loom... omfg.
    Trying to trace this down... i'm kind of at a loss.
    HulkSmurf14 likes this.
  2. May 10, 2025 at 8:02 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Well, this sucks...no way around it...you need new pins and some patience...you're very capable of knocking this out, but I'd walk away for a bit, come back after some rest and see if you're able to depin and reuse them...
  3. May 10, 2025 at 8:10 PM
    MarkM0369
    MarkM0369 New Member
    Mark
    2017 Tundra SR5 4x4
    275/70 KO2, Pro Hood Bulge and grille, OEM fender flares, Fox rear shocks
    That sucks, they make a molex connection tool and pin kit, and similar if you want to try and reconnect the pins, or you could go wire by wire and just use butt connectors or male and female spade connectors if you want to be able to easily take it apart again, and just skip the plugs, just label the wires so you know what’s what in the future
  4. May 10, 2025 at 8:15 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    This is time consuming but in no way impossible. Get a pin removal tool or use a needle. Unhook the battery, depin the plug, add a little
    More to each connection and add new pins. Then plug those pins into the factory connector. You can get the pin kits on Amazon for 20 bucks or so.
    point08[OP] and HulkSmurf14 like this.
  5. May 11, 2025 at 5:55 PM
    ToyotaBeast
    ToyotaBeast New Member
    Not a hard fix. You can get new pins from the dealer and just solder them on.
  6. May 11, 2025 at 6:04 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    whodatschrome likes this.
  7. May 12, 2025 at 1:03 PM
    point08
    Kyle
    smokint, Blufin and ZappBrannigan like this.
  8. May 12, 2025 at 2:16 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    smokint and NewImprovedRon like this.
  9. May 12, 2025 at 3:18 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    How screwed am I?
    On a scale of 1 to 10? 10 being Lexington Steele is clapping your butt cheeks?
    34
  10. May 15, 2025 at 7:00 AM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    Like your at a party and you asked for an aspirin for a headache. Then you start to feel weird and the last thing you see is P Diddy walk in the room.....
  11. May 15, 2025 at 9:14 AM
    point08
    Kyle
    Oh my
  12. May 15, 2025 at 9:15 AM
    point08
    Kyle
    explains all of the oil leaks...
  13. May 15, 2025 at 9:52 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    lulz...
    smokint likes this.
  14. May 24, 2025 at 8:39 PM
    point08
    Kyle
    So... I broke the white locking mechanism trying to get the Y56C8 plug off to repin. Shit.
    I bought a macgyver type-replacement and am wondering if I were to appropriately match and splice the pigtail, I'd be fine? Or just suck it up and re-crimp new pins on the bad half?
    Any tricks to get the new lock out?
    EDIT
    Apparently I only need to move it a few mm... It doesn't come out.
    Question about splicing still open.
  15. May 24, 2025 at 9:38 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Instead of splicing, re-pin the new plug with the original wires.
    https://m.youtube.com/watch?v=XgovfeYaaDk
  16. May 24, 2025 at 9:40 PM
    point08
    Kyle
    4 are good... 4 need to be fixed and then repinned. I can splice it easier than putting new tips on but I hear ya.
  17. May 24, 2025 at 9:41 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Gotcha. In that case as close to the end of the original wiring as possible.
    If you don’t have the length on the original wires just to add a new pin on, you can cut the whole connector off and butt connect the new pigtail on.
    It’s scary the first time you hack up a factory wiring harness with a pigtail, but I can tell you it’s not abnormal. In fact the brake switch repair for a 2009 wrx sedan entails cutting the old Nissan connector off and putting a new pigtail on to accept a different sensor. This was a dealer supplied solution to replace the crappy sourced Nissan brake switch.
    smokint and point08[QUOTED][OP] like this.
  18. May 25, 2025 at 1:16 PM
    point08
    Kyle
    Does the top row match the bottom row in terms of wire placement? When I found it; one entire row had been pulled out. Two of the four rubber gaskets were still in.
    Thx! Getting ready to dive in!
  19. May 25, 2025 at 5:06 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    I don’t know, but what color are the wires on the other side that it plugs into? That might give you an idea.
    otherwise maybe someone else can chime in or you can look at a wiring diagram
  20. May 25, 2025 at 5:16 PM
    point08
    Kyle
    Success! Splicedin the pigtail to give me more cable if I have to replace it again (STUPID RATS!).
    Put it all back together, cleared the codes and started it up. Now she needs a well deserved bath and a long drive!
  21. May 25, 2025 at 5:18 PM
    point08
    Kyle
    The other side didn't match at all... It was only green and red.
    Gambled and went with the same color on top as on bottom.
    ZappBrannigan[QUOTED] likes this.
  22. May 25, 2025 at 5:53 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    That’s what I’m talking about. Good job!
  23. May 25, 2025 at 10:24 PM
    point08
    Kyle
  24. May 26, 2025 at 6:46 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    I mean, that’s a BMW though, so it’s to be expected that you’re going to have some “interesting issues” pop up from time to time.
  25. May 27, 2025 at 5:00 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Good job!! We'll done!!! Maybe put some rat traps under your truck.....or a snake.
