Payload
Discussion in 'Towing & Hauling' started by AlanCraig1, May 26, 2025.
  1. May 26, 2025 at 6:12 PM
    AlanCraig1
    AlanCraig1 [OP] New Member
    Alan
    2025 Toyota Tundra SR5 TRD Rally
    So for anyone wondering, I put the payload capacity of a 25 TRD Rally to the test today. Went and picked up about 10 cubic yards of material from Lowe’s. 7 of it was garden soil. On the low end, I was probably pushing between 1500-1600lbs and it handled it like a champ. Aside from the obvious suspension squat, it was barely noticeable. Just thought I’d share. Note that this greatly exceeds the recommended payload capacity of this truck.
    Florida AF, 22whatwedo and Bulldog6 like this.
  2. May 26, 2025 at 6:39 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Do you mean cubic feet??? Only a dump truck can carry 10 yards at once. A 6.5ft bed can only take about 1.8 yards so only 8ft trucks take 2 yards at once. 10 yards of soil would be 15k lbs or so depending on moisture.
    ColoradoTJ and Tileguy like this.
  3. May 26, 2025 at 6:46 PM
    AlanCraig1
    Alan
    I may have mathed wrong. 28 cubic feet of garden soil and 20 cubic feet of mulch. That said, weight was done based on cubic feet so that was accurate.
    Florida AF likes this.
  4. May 27, 2025 at 6:24 AM
    WineryCowboy
    WineryCowboy New Member
    2022 White Tundra SR5
    Timbrens SES Rear
    Very nice looking rig, you just reminded me I need to wash mine.
  5. May 27, 2025 at 6:29 AM
    1500-1600lbs greatly matches the payload of that truck. Check your door jamb. I put a yard of supersoil in the bed of my 2000 Tundra. That was a little over 2k pounds.
    Dfrink and Florida AF like this.
  6. May 27, 2025 at 6:40 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    Divide cubic feet by 27 to get cubic yards... You had 1.8 yards. The math on the split of the soil material at 7 out of 10isn't mathing either 28/48 isn't 70% it's 58%... Me thinks your units of measure are all jacked up and maybe the weight you calculated is off too.
    ColoradoTJ and Breathing Borla like this.
  7. May 27, 2025 at 6:50 AM
    imgreenlantern2
    imgreenlantern2 New Member
    Snake Plissken
    Central Texas
    2021 Tundra TRD Pro Double-Cab
    285/70/18 Nitto Ridge Grapplers. RCI rock sliders Leer Tonneau Cover NSV Hood Mounted Lightbar. Suspension air bags for better towing.
    I have put 2,000 lbs easily in the back of my 2021 TRD Pro and its done just fine.
  8. May 27, 2025 at 6:56 AM
    teab
    Ty
    Denver
    @AlanCraig1 there is about 55ish cubic feet of room in the 6.5' bed...if you were about 2-3 inches of so from the top of the bed rails that's would put you about 48 cubic feet of material in the bed.
    Breathing Borla likes this.
  9. May 27, 2025 at 6:58 AM
    Breathing Borla
    Northern Illinois
    lol, yes, for reference the semi trucks we use to haul impacted soil to the landfill and clean rock on the way back hold 12 cubic yards legally. thats 18-20 tons
    OP, 1500lbs in the is just fine, but the math is off
    clayey soil is about 1.5 tons per cubic yard depending on moisture.
  10. May 27, 2025 at 6:59 AM
    teab
    Ty
    Denver
    You forgot to mention your V8 engine didn't blow up either.
  11. May 27, 2025 at 5:36 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Payload is interesting. I was just thinking the other day how I stress about my 900lb slide-in camper, figuring I should only have it in the truck for short periods, and not take really long trips, to keep from wearing out wheel bearings, brakes, u-joints, transmission. But then I think that if I had 8 friends (well over 1,000lb) in the back of my truck, I wouldn't actually think of it as taxing. It just doesn't seem like something that would cause a lot of wear & tear. But having that one big camper makes me nervous.
