  1. May 25, 2025 at 6:58 PM
    rmeyer7
    rmeyer7 New Member
    Roy
    2008 Double Cab 5.7L
    Yup, Bar Keepers Friend was the only thing that improved it at all. It's become my favorite cleaner lately (starting when I ditched my teflon pans and got a combination of stainless and carbon steel instead). Maybe after everything is sealed I'll try a couple more rounds of it to see if there's any further improvement.
  2. May 25, 2025 at 7:17 PM
    shifty` All my rowdy friends have settled down
    I used quite a few of them on jobs as pull cords to chase cat6 down in the walls, if they’re in strategic locations.
  3. May 25, 2025 at 7:20 PM
    Yeah, last thing I need in our house is more listening devices :rofl:
    Man, some of the deep dive dissections the IoT research guys at my old job did on consumer devices would leave you wanting to be a Luddite for life.
  4. May 25, 2025 at 7:32 PM
    TaquitoBandito
    Joel (AKA Bif)
    Yeah, I'd feel bad for the poor sap that gets stuck listening in on me. They'd be bored as hell.
    oddhours, rmeyer7, NWPirate and 3 others like this.
  5. May 26, 2025 at 10:40 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Barkeepers Friend contains grit. Have you tried a Magic Eraser to see if it will help?
  6. May 26, 2025 at 11:55 AM
    Outbound
    Aaron
    Northern Alberta
    I want to turn this grass into gravel for parking my trailers. If I can avoid ripping out the sod, it'd be alot less work. I'm thinking of weed whacking the grass to nubs, covering with dirt and then landscape cloth and finally road crush compacted.
    Thoughts?
    TaquitoBandito likes this.
  7. May 26, 2025 at 12:25 PM
    Azblue
    The Dirty T ( ^_^)_且
    Get some generic Roundup concentrate and mix it 2-3x strength. Then go ahead with your plan. Also, compact the hell out of whatever fill you use for that angle and install a drain if needed.
  8. May 26, 2025 at 12:30 PM
    Melamine foam (“magic eraser”) is also an abrasive FYI. It works by sanding away the stain. I learned this the hard way not long after someone got the bright idea to rebrand the stuff as “magic eraser” and I used it on my truck’s paint 20+ years ago. Big mistake. It sanded hazy spots into my paint everywhere I used it. Had to polish out the whole truck.
    woods, TaquitoBandito and Fotnot like this.
  9. May 26, 2025 at 1:09 PM
    NWPirate
    Zach
    WA
    Assuming you need to keep somewhat of a valley here for drainage for you and your neighbor?
    A short 2 block retaining wall would be sweet but that would probably crowd property lines.
  10. May 26, 2025 at 1:13 PM
    Outbound
    Aaron
    Northern Alberta
    The neighbor is on board with turning the whole thing gravel, so no wall needed.
  11. May 26, 2025 at 1:19 PM
    NWPirate
    Zach
    WA
    Even better:thumbsup:
  12. May 26, 2025 at 1:30 PM
    NWPirate
    Zach
    WA
    Unfortunately, it looks like your sod is quite a bit higher than your concrete at the bottom of your driveway.
    I'd rent a power sod ripper and do it right, to get your finished rock grade on plane with the sidewalk/driveway.
  13. May 26, 2025 at 2:41 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I'd follow suit with @NWPirate's plan. Renting a sod ripper will deliver the best long term results. Still use some sort of landscape cloth for regrowth.
  14. May 26, 2025 at 2:41 PM
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    Maybe pull Sheetrock and do tongue in groove wood?
  15. May 26, 2025 at 3:23 PM
    NewImprovedRon
    Ron
    NW Arkansas
    Yes, I know Magic Eraser is an abrasive. My point was that the OP had already been using an abrasive. It wouldn't do a vehicle's finish any good for sure.
  16. May 26, 2025 at 3:36 PM
    ACDC2ZZTop
    Travis
    Oregon
    Prepping house for paint. First step was to take out this ridiculously large window going to the garage. Will be doing Hardie plank on this west side.
    BroHon, woods, Tripleconpanna and 5 others like this.
  17. May 26, 2025 at 3:36 PM
    Can you please jump back in time about 25 years ago and tell 20-something me that? :rofl:
    It cost me about 6-8 hours of hardcore polishing to undo that fuckuppery.
  18. May 26, 2025 at 3:52 PM
    Outbound
    Aaron
    Northern Alberta
    Today I learned there's such thing as small sod cutters. That changes everything.
  19. May 26, 2025 at 4:31 PM
    NWPirate
    Zach
    WA
    :D:fistbump:
  20. May 26, 2025 at 5:01 PM
    Outbound
    Aaron
    Northern Alberta
    Tundras.com really is a one stop shop. :D
  21. May 26, 2025 at 5:27 PM
    NWPirate
    Zach
    WA
    Usually an expensive shop too :laugh:
  22. May 26, 2025 at 5:42 PM
    Outbound
    Aaron
    Northern Alberta
    Especially after exchange and shipping. :(
  23. May 26, 2025 at 6:12 PM
    Mdnitedrftr
    Mdnitedrftr TAKITEZ
    Rich
    NW, CT
    '21 1794
    Took advantage of the nice weather and did some more yard work. Trimmed some low hanging branches that I always run into mowing the lawn, did some weeding (probably some poison ivy-ing too), ripped out some very expensive bushes that didn't make it, and mowed the lawn.
    As much as I hate yard work, it's extremely gratifying when everything is cleaned up and neat looking.
    woods, BroHon, NWPirate and 3 others like this.
  24. May 26, 2025 at 8:04 PM
    I had no idea. I’ve got some great pics of me clearing a good 200-300sf+in my front yard. Flathead shovel. Kick it down into be ground an inch, tilt it backward, kick it forward until you get a good sized square skimmed. Works great.
  25. May 26, 2025 at 8:26 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Weed whack, spray it down w/ 'all vegetation' killer, verify it's dead, then cloth, and rock..
    or, that other high speed stuff they talked about before I woke up :cool:
  26. May 27, 2025 at 3:57 AM
    Kung
    KG, VA
    If you think that's old, imagine my surprise when we bought our house in 2023 and found *these* telephone jacks:
    Our house was built in '73, I believe it was...and still has these in 2 or 3 rooms. If only my Dad were still alive - he retired from AT&T and would probably die laughing at these.
    That said, no need to have phone lines run, because:
    - our new house has fantastic internet
    - also has fantastic cell phone reception
    - the 'telephone service' from Breezeline is basically just repackaged VoIP that is crap, and also requires their routers that are ALSO crap. LOL
    We just use our cell phones, and haven't found an actual need for a wired phone line since we moved here.
  27. May 27, 2025 at 4:39 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Ha ha ha yep!!
  28. May 27, 2025 at 4:41 AM
    Corndog123
    Sam
    Tennessee
    Attempted to install a new outlet in the bathroom. No big deal, I've done dozens of them and had no issues. We'll, the wiring is pretty old, at least not asbestos old thank the Lord but it's pretty old. May have to put the old outlet back in. I wanted a new one that has the USB outlets. Oh well.
    TaquitoBandito and woods like this.
  29. May 27, 2025 at 6:04 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    I've banned verizon from our property. They promised me they could get us DSL (laugh it up, was the best option at the time, and only 5 years ago too) if we gave them a right away and used them for our business. When it came time to build the house, they refused and said they wouldn't add more dsl anywhere, the limit was reached. We ripped their lines out of our business, and told them we're all set at the house. Refused them at my MIL's too. Luckily we got fibre on the road two years ago, because we have no cell service.
    Was a tough 3-4 years of satellite internet with a 25gb limit for the month. Hughes net can suck a big one, that was such a bad internet experience. My mom has starlink now and says its not even in the same world as hughes net was.
    BroHon and TaquitoBandito like this.
  30. May 27, 2025 at 6:09 AM
    Kung
    KG, VA
    Yeah, suffice to say I'm not a fan of Verizon *OR* Hughesnet. I mean, where I used to live, it was better than dialup...but only marginally so, IMHO.
    Thankfully, not only is Breezeline (coax, 1Gbps) good at our house (with an AFTERMARKET router, mind you lol), but cell service is good enough that we can use it as a backup if our internet goes down (which is almost never, to be honest).
    woods[QUOTED] and TaquitoBandito like this.
