Cartrimhome 14.6" C12 Radio
Discussion in 'Audio & Video' started by NC Narc, May 25, 2025.
  1. May 25, 2025 at 8:58 PM
    NC Narc
    NC Narc [OP] New Member
    Andrew
    I decided to take chance on the Cartrimhome 14.6” radio for my 2018 limited. When I made the purchase, I couldn’t find much information on the radio or reviews, so I’m going to share what I have learned after installing it.
    Prior to the Cartrimhome radio I had an Alpine Halo11 headunit, a Kenwood Excelon 5-channel amp and two JL 10w1’s. My truck has the JBL system, so I kept the stock speakers. I used the wiring harness I got from Tech12Volts to wire in my aftermarket amp and subs.
    To install this radio you have to disassemble a lot from the dashboard, but its really easy. The instruction manual that came with the radio actually has pretty good pictures to show you exactly what needs to come off, so I didn’t take pictures of that part.
    The issues I ran into came from the wiring, which is why I am posting this. There are zero instructions anywhere for the wiring part. The wiring harnesses that come with the radio are not specific to the Tundra so there will be a lot of plugs that go unused. Now, I will say that the plugs coming from the truck only fit into one plug on the harness, so you can really F it up. The wiring issues I ran into were how to wire in the RCA’s for my rear speakers, my subs, and the front camera (front camera came with the radio).
    The pictures below will show anyone who buys this radio how to wire up RCA’s with an aftermarket amp and the extra front camera. If you have an all stock sound system, the install is straight forward.
    Also, there is only 1 sub RCA plug, so you will have to get a 2 to 1 RCA converter. I picked one up at AutoZone for $8.
    This wire is where you will plug in your RCA's for your rear speakers
    This is the plug for the factory backup camera
    This is the plug for the front camera. From what ive been told, the front camera only comes with the most expensive radio option.
    These are all of the harnesses that i used, plugged into the radio.
    The radio came with two harnesses for the front camera, one of which has a tag that says BT-ANT. That is the one i used.
    i ran both the brown wire labeled AMP-DET and the blue wire labeled AMP CONT to my amp trigger wire and it turns on and off like it should.
    within the radios settings, you can select thousands of variations of makes, models of vehicles and trim levels. The option you select will determine if your steering wheel controls work correctly.
    The tech support at Cartrimhome told me to use XP(Simple),Toyota,Camry,2018. But there were some small issues with that. i ended up using KYC,Toyota,Prado,2010-2017.MID.AUTO and everything seems to work correctly.
    The only issue i am having right now is not being able to change, within the vehicle settings, when the doors lock and unlock. I cannot change the doors to unlock when put in park, or lock by vehicle speed. I am currently emailing the tech support back and forth to see if they can resolve it.
    Other than that one small issue, everything else is amazing. I put a 4G sim card in the radio and it connected immediately. the vehicle icon shows when your doors are open, when you brake while driving and you can put your license plate on it, which is cool. The front camera is also ridiculous quality.
    If anyone decides to pull the trigger on this radio and needs help, feel free to reach out to me. If anyone has questions about it before buying it, ask away.
    I dont come on here much, so feel free to shoot me a text 7045605900
    HulkSmurf14, jamesonellistx and woods like this.
  2. Jun 18, 2025 at 7:42 PM
    MrJimmyPenguin
    MrJimmyPenguin Penguined
    Jimmy
    2021 Black Crewmax Toyota Tundra TRD Off Road Premium 4x4
    How are you liking it now with some time? maybe some firmware updates etc...
  3. Jun 18, 2025 at 7:54 PM
    NC Narc
    Andrew
    I ended up fixing the door locking issues with a Carista OBD plug.
    I've been emailing the company back and forth to iron out other small glitches and sending them data logs so they can patch the software. The company actually has pretty damn good customer service.
    So far, I love the radio. Well worth the money. The equalizer is extremely customizable so my sound system sounds better than it did with my old Alpine headunit. The front camera is a nice addition and having wireless android auto is nice. I added a SIM card to it so I never end up using carplay or android auto but its nice to have the option.
    woods likes this.
  4. Jun 18, 2025 at 7:56 PM
    MrJimmyPenguin
    Jimmy
    Great to hear, would love a 6month and maybe a year check in on it.
  5. Jun 19, 2025 at 7:24 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    I would likely be all over this if they had matched the round vents. My OCD will not let me do this because of that.
    burtlively likes this.
  6. Jul 9, 2025 at 4:15 PM
    NC Narc
    Andrew
    if you go with the black vents instead of the silver, they blend in with the dash and it doesn't stick out near as much.
  7. Jul 22, 2025 at 10:41 AM
    Bo'Dapro
    Bo'Dapro New Member
    Bo
    2019 Toyota Tundra Crewmax limited (cement color)
    stereo, shifter knob, tail lights so far
    Purchased the same unit April 23rd, I still havent installed it as of yet due to some medical issues. I appreciate all of your updates and willingness to share, I plan on installing soon! Thanks again
  8. Jul 22, 2025 at 12:44 PM
    NC Narc
    Andrew
    if you need any help, reach out. I've had about a dozen or more people text/call me so far and i think ive been able to solve most of their install issues.
    RobertD likes this.
  9. Jul 22, 2025 at 12:45 PM
    NC Narc
    Andrew
    If there is anyone in the Charlotte, NC area that wants to buy the radio, im willing to help with the install. That would allow me do document the install in more detail, so i can put it on here.
    woods likes this.
  10. Jul 27, 2025 at 4:42 PM
    Bo'Dapro
    Bo'Dapro New Member
    Bo
    Thanks for messaging, I was supposed to install today actually, I have a 2wd limited 2019... Well Cartrimhome sent me a seperate knob control power button that will go in the place of the 4WD opening. Well there are no instructions of course so I've reached out to cartrimhome awaiting instructions. If no resolution, I'll install without the button and plug the hole with a Toyota coin holderScreenshot_20250727_183549_Gallery.jpg Screenshot_20250727_183358_Gallery.jpg Screenshot_20250727_095541_Gallery.jpg
  11. Jul 27, 2025 at 7:17 PM
    NC Narc
    Andrew
    That's interesting, I havent seen that yet. If they don't get back to you, let me know. They have been really good about responding to me. They actually sent me their new side mirror caps with integrated turn signals to test out. I just installed them and am going to do a write-up for them for their website.
    BR73 likes this.
  12. Jul 27, 2025 at 8:57 PM
    Bo'Dapro
    Bo'Dapro New Member
    Bo
    They just got back to me, they've been very responsive since I first placed the order. So here is the solution from Cartrimhome. Im going to install tomorrow Screenshot_20250727_225550.jpg
    woods likes this.
  13. Jul 28, 2025 at 6:09 AM
    NC Narc
    Andrew
    Seems pretty simple. Also, glad to hear their customer service has been good for others!
  14. Jul 29, 2025 at 9:18 AM
    Rockytrdpro
    Rockytrdpro New Member
    Rocky
    2020 black tundra trd pro
    i'm thinking about pulling the trigger on this, can you take wide angle shot of the system with full dash?
  15. Jul 29, 2025 at 9:25 AM
    Just my opinion but no way in hell would I put a Chinese head unit in my truck. I'd be too worried about electrical issues or a fire.
  16. Jul 29, 2025 at 10:21 AM
    NC Narc
    Andrew
    Where do you think the factory head unit was made? China or some other Asian country.
    If you look at the specs on this headunit and the hardware in it, its no different than most name brand ones. But to each their own.
    BR73 likes this.
  17. Jul 29, 2025 at 10:21 AM
    NC Narc
    Andrew
    I'll take some pics when I get home tonight and post them.
    Rockytrdpro[QUOTED] likes this.
  18. Aug 3, 2025 at 10:49 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles +2 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light
    I want to install a set on my 2020 SR5 but I'm not sure about wiring the mirror cap turn indicator
  19. Aug 3, 2025 at 6:40 PM
    NC Narc
    Andrew
    Im going to post the write up for them tomorrow. I'll link the thread here so you can find it. It's a pretty easy install.
    BR73[QUOTED] likes this.
  20. Aug 6, 2025 at 10:19 AM
    NC Narc
    Andrew
    Old.Ski.Bum and BR73[QUOTED] like this.
  21. Aug 12, 2025 at 4:12 PM
    Old.Ski.Bum
    Old.Ski.Bum New Member
    Paul
    2021 Luna Rock TRD PRO
    Looks like a cool setup. You’ve certainly did your homework and you’re determined to get everything out of this unit! Kudos! One question I have is does it support Sirius XM radio?
  22. Aug 12, 2025 at 6:51 PM
    Tundracob
    Tundracob New Member
    2019 Tundra SR5 5.7L V8 4x4
    I'm about 5 hours out, I'm not sure when I'll get to installing it but if this offer is still on the table would definitely be interested in talking details.
  23. Aug 14, 2025 at 12:08 AM
    TrdErnie
    TrdErnie New Member
    Ernesto
    2021 Tundra Trd Pro
    Ssw wheels Toyo r/t
    Looking to purchase the head unit but my only concern is my Remote start option. I’ve heard that with Dasaita units that function goes away….that would be my only reason for not pulling the trigger
  24. Aug 18, 2025 at 12:59 PM
    NC Narc
    Andrew
    It does not support XM, but you can install the XM app on the radio.
  25. Aug 18, 2025 at 1:01 PM
    NC Narc
    Andrew
    I would send an email to cartrimhome to find out if it will be retained. I have the remote start from 12voltsolutions so I havent had any issues. The canbus that comes with the radio seems to mimic the factory canbus so I would think it wouldnt be a issue, but dont take my word on it.
    BR73 likes this.
  26. Aug 18, 2025 at 1:02 PM
    NC Narc
    Andrew
    yeah buddy, I'm sure we could figure something out. Just shoot me a text when you get to that point.
