  1. May 23, 2025 at 1:05 PM
    It shocks me how many so-called "contractors" don't understand the basic principles of building a proper shower pan, with liner up the walls, constructed so all water redirects to the drain. The last couple showers we had people knock out had low spots in one corner or something equally stupid.
  2. May 23, 2025 at 2:15 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    building some trails at a friend's place.
    tree stump jump
    and some sheetrock
    Edit to add...
    We've since cut some of the camber out of the turn leading up to the ramp so you can roll it faster. Pretty fun for 2 over 50yr olds.
  3. May 23, 2025 at 3:38 PM
    woods
    woods New Member
    2021 SR5 TRD Sport
    I'll take some bike trails over here when you are all done :rolleyes: Looking very nice, you guys will be having some fun!
  4. May 23, 2025 at 4:52 PM
    I love Werner ladders. Sturdy and super light.
  5. May 23, 2025 at 4:56 PM
    rmeyer7
    rmeyer7 New Member
    Roy
    2008 Double Cab 5.7L
    I'll spare everyone from having to see the gross before picture...but here's what I'm in the middle of. When we bought our current house I knew this shower would be a project. This weekend the wife and kids are away visiting the grandparents so I'm tackling it. This is just after several hours of cutting, scraping, scrubbing, grinding, etc. to get the old caulk removed and some of the grout as well. Some of those black spots are voids where the grout was removed, rather than mold.
    Tomorrow will be the day for heavy duty industrial strength chemicals. If I can get it thoroughly clean I'll finally be re-grouting, re-caulking, re-sealing the tile, etc. If not...I may be shopping for new tile in the near future.
    Florida AF, woods, OldGuy03 and 4 others like this.
  6. May 23, 2025 at 5:19 PM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    I like your humor.
    LMFAO!!!
  7. May 23, 2025 at 6:04 PM
    TaquitoBandito
    Joel (AKA Bif)
    Plumber called me this morning and gave me an hours notice that he was on his way. My contractor friend had just told me how they use Kreg jigs to put up stringers (to hang the shower valve and neck thingy on). Past Joel hooked me up - I must have bought one on clearance at Lowes 12 or so years ago. Never opened it up until today...
    Got the stringers up for the plumber.
    So my wife ran into an old lady who's grandfather or some relative who used to own our house. She said that above the stairway, there was a landing that had a window that overlooked the front door. A ghost of a young special needs girl could be seen looking out of it. I figured she was full of shit but when I removed the bottom shiplap for the plumber, I realized the wall was added. So my wife is all excited now.
    Anyboo, plumber did his job and had a bit of a scare when the tankless water heater sensed that the pipes needed more hot water or something and sent it all up to the bathroom. I heard a "whoosh" downstairs and then saw him hauling ass to get his shop vac.
    He did a great job though.
    I went ahead and shored up the support under the floor... at least I think I did that. :D
    I thought he'd just hook up the pipes and shit and I'd install the valve - I calculated that because of the additional shiplap I'd probably need to add another inch. I was pretty happy when he came downstairs and asked me if I had any one-inch scrap wood (Past Joel kept scraps).
    He didn't center the shower spout so I moved it over an inch...
    The shower base calls for a 1/4 of wiggle room next to the walls. I didn't think about it when I measured where the drain was and screwed up. Most installs would be you put the pan down next to the studs and then add 1/4 inch shims above. My idea was to remove the bottom pieces of shiplap and put a piece of mold proof drywall (I had a scrap piece) in its place. I put it in the test it out and it gives me a perfect 1/4 inch.
    And this is where it stands. Going to cut a little more drywall around the perimeter of where I want to put the shower, lightly sand the paint in the room, then put a couple of coats of mold proof primer on. Hoping to start laying GoBoard next week.
  8. May 24, 2025 at 4:00 AM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    Nothing at home this weekend buuut,visiting my Mom in NH so the laundry list is fairly small.
    Going to flush/descale the combi tankless unit, replace hot&cold feeds for the clothes washer with braided SS hoses, cut down a shit load of saplings, fix a kitchen cabinet hinge, hang 1'X10' shelf in a closet ,fix a grab bar in the shower and God only knows what else comes to her mind:rolleyes:
    Have a great Memorial day weekend Boyz,remember the one's who gave all for us to enjoy our freedoms :thumbsup:
    OldGuy03, rmeyer7, woods and 3 others like this.
  9. May 24, 2025 at 4:09 PM
    rmeyer7
    rmeyer7 New Member
    Roy
    I continued my shower repair project with some pretty strong chemical cleaning today, so while the fumes were being aired out I focused my attention on the kitchen. Our butcher block countertops are never used for any cutting, so I decided to refinish them with something more permanent than the wax I had used in the past. Cleaned them up, sanded down to bare wood, then put on some one-coat poly. Should protect them a bit better from the occasional spills they're subjected to.
    Haven't done the counters next to the stove or the sink yet, waiting until these are fully cured so I have a place to put all the stuff that's on those other counters.
  10. May 24, 2025 at 5:47 PM
    Waterlox is, hands-down, the best sealant you’re gonna find for butcher block. It’s what we had on ours for quite a while but we do cut on the block, so we sanded it off and just oil it now. But highly recommend. Not even red wine would soak into the wood.
  11. May 24, 2025 at 6:24 PM
    Florida AF
    Logan
    North Florida
    In another episode of "what in the bugs life..."
    I took the fam to a farmers market and spent too much on random things again. My wife will be trying duck eggs for the first time here soon... then we invited our neighbors (two who have no one and two who are always helping us) over for dinner tomorrow. So we prepped the back porch and got to cleaning. I also got my extension cord up that was used to run my camper for the last year... I was snipping wire ties when I damn near interrupted this guys lunch...
  12. May 24, 2025 at 6:54 PM
    TaquitoBandito
    Joel (AKA Bif)
    So how'd it squish?
  13. May 24, 2025 at 7:01 PM
    Florida AF
    Logan
    North Florida
    I took the pic, verified it was a good guy and went around him.... t was a good jump scare though!
    OldGuy03, Blufin, BroHon and 6 others like this.
  14. May 24, 2025 at 7:01 PM
    TaquitoBandito
    Joel (AKA Bif)
    Yeah, I bet!
  15. May 24, 2025 at 7:14 PM
    Those are the good guys. Wolf spider. Looks like he’s eating a Florida Giant Katydid? That wing doesn’t quite look right though. Looks more like the back-end of a mantis.
  16. May 24, 2025 at 8:29 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I love watching spiders
    When they aren’t crawling on me (or a threat of doing so)
  17. May 25, 2025 at 3:40 AM
    Florida AF
    Logan
    North Florida
    I call them leaf bugs but not 100% sure. I'll look up the first thing you posted. It's definitely not a mantis.
    I don't care for them but if they are not in my porch or home I try to leave them alone. I typically only kill the ones on my water station because there are too many to move and I don't have time to verify each one. Plus the banana spiders are there and that's a nope for me.
    But typically I just get my jump scare and move on lol
  18. May 25, 2025 at 3:46 AM
    Florida AF
    Logan
    North Florida
    So at first look I thought it was a huntsman. Now I'm thinking it's a white banded fishing spider. Not a spider guy so using lens for initial looks
    And the big is in fact a katydid. Didn't know them by that name!
  19. May 25, 2025 at 3:57 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    That deck spindle @ 1.5" really lets you know how big that boy is. We have wolf spiders, but their legs aren't nearly as beefy as that guy.
    Our population gets somewhat culled up here in MI, but I just discovered that some have "anti-freeze" qualities to their blood!
    Amazing hahaha
  20. May 25, 2025 at 4:06 AM
    Florida AF
    Logan
    North Florida
    Yeah he is not on lf the smaller ones for sure lol. He gave me a good startle as I was just moving along cutting zip ties and almost grabbed him. I haven't seen one like him in recollection, but this property has brought on a whole slew of new insects and birds for me to see compared to usual.
    I was shocked when I was in Michigan and saw the bugs up there. I assumed with the snow y'all would have hardly any....which in fact... Is not the case lol. Guess we know why now
    shifty`, T-Rex266 and TaquitoBandito like this.
  21. May 25, 2025 at 5:30 AM
    Definitely white banded fishing spider, my bad. Huntsman spiders aren’t super common and have way more gangly legs. Fishing spider and wolf spiders have similar body types in comparison. I saw the shield on the thorax and thought wolf.
    Apparently the confusion is common with those guys. Wolf is Lycosidae (now that explains the Lycos search engine name from way back when - any internet veterans remember Lycos?!), Fishing is Pisauridae.
    From Google’s AI output generated from search input on the differences:
    “Dolomedes, is a genus of fishing spiders, which belong to the family Pisauridae. While Lycosidae (wolf spiders) and Pisauridae are closely related and both considered lycosoid families, Dolomedes can be distinguished from wolf spiders by their smaller posterior median eyes and two-row eye arrangement, as well as their aquatic adaptations…”
    Florida AF[QUOTED] and T-Rex266 like this.
  22. May 25, 2025 at 5:56 PM
    rmeyer7
    rmeyer7 New Member
    Roy
    My shower project is working out as I had hoped. It came completely clean after a few rounds of a heavy duty cleaner. Re-grouted today. Needs a few days to fully set, then it will be time for the tile & grout sealer and caulk. I just wish the cleaner I used was able to get the pan back to bright white. Can't find anything that will do that (so far).
    I'll leave a before pic here but WARNING, IT IS GROSS. Click at your own risk!
    While I was at it, I fixed the grout behind the countertop I was working on. The pic I posted the other day was bothering me...I had knocked the grout loose a couple years ago when I took out the original countertops to replace them, and finally fixed the damage today.
    NWPirate, BroHon, Fotnot and 5 others like this.
  23. May 25, 2025 at 6:25 PM
    Woah! A land line! Man, you don't see those damn things anymore.
    TaquitoBandito likes this.
  24. May 25, 2025 at 6:30 PM
    rmeyer7
    rmeyer7 New Member
    Roy
    Haha, yeah, that picture is how I tell you my house was built in the '90s without telling you my house was built in the '90s.
  25. May 25, 2025 at 6:30 PM
    Florida AF
    Logan
    North Florida
    Today was a comical day at the house and thankfully I took one photo but officially I took no photos.
    We stopped at our neighbors the other day and found out they had no plans today. We invited them over for a cookout. Next thing you know, I ended up meeting some new neighbors and the list grew a little longer (all approved before "kick off").
    I dont know if I shared with yall, but we are the youngest full timers on our block by.... A LOT!
    Food was ready and my back patio was cleaned and prepped... neighbors rolled in on UTVs and their vehicles and we broke bread over camp chairs, folding chairs and plastic tables. I heard stories about my house and the evolution that brought it to what it is today as well as got the town gossip... lol.. small towns are awesome.
    So we didnt do any improvements today other than memories, but I heard all about land lines, satellites, RV porches and how fiber changed the game but some people wont use it... LOL...
  26. May 25, 2025 at 6:31 PM
    Florida AF
    Logan
    North Florida
    I cut my lines off and put up blanks over them for now. Ripped the outside stuff off early on in my purchase. I still chuckle at seeing them and then wish I could run ethernet there... damn builders and their line staples preventing me from using them as wire pulls lol.
  27. May 25, 2025 at 6:34 PM
    TaquitoBandito
    Joel (AKA Bif)
    No judgement from me - here was our Master before I took it apart...
    This is NASTY.
    Nice job on yours :fistbump:
    woods, Fotnot, oddhours and 1 other person like this.
  28. May 25, 2025 at 6:36 PM
    TaquitoBandito
    Joel (AKA Bif)
    I took out ours that was in the kitchen and used the box to mount our Echo Hub. This house had those things everywhere.
    shifty`[QUOTED] likes this.
  29. May 25, 2025 at 6:37 PM
    rmeyer7
    rmeyer7 New Member
    Roy
    Thanks, honestly we're just trying to fix things like this and then sell our current house. If it were a forever home I would have gutted the shower, ripped out the tub next to it and redone the whole bathroom. But it just needs to be functional and look good for some new owners to decide what they want to do with it.
    woods and TaquitoBandito[QUOTED] like this.
  30. May 25, 2025 at 6:40 PM
    TaquitoBandito
    Joel (AKA Bif)
    I understand that completely. Also, have you tried Bar Keepers Friend on it with a scrubber (nothing too abrasive)?
