Help identifying Gasket/O-rings
Discussion in '2nd Gen Tundras (2007-2013)' started by fishyjohn, May 23, 2022.
  1. May 23, 2022 at 4:53 AM
    fishyjohn
    fishyjohn [OP] New Member
    2010 Double Cab 5.7 4x4
    Can anyone help my find the correct part number for the two o ring gaskets that sit between the oil filter housing and timing cover. They are the large black dot labeled "GASKET" in the center of this diagram.
    Thanks!
  2. May 23, 2022 at 4:59 AM
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    When it comes to parts there is only 1 name that comes to mind. Where ya at @Roman
    Roman likes this.
  3. May 23, 2022 at 12:03 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  4. May 23, 2022 at 12:12 PM
    fishyjohn
    Nice thank you. We had a pro o ring kit and got an almost identical set but it started leaking a week later. Crazy how those little micro differences can cause issues.
    Roman likes this.
  5. May 25, 2025 at 3:25 PM
    Bassfishinfool
    Bassfishinfool New Member
    Michael
    2007 silver tundra trd offroad
    Is this a common problem, I am pretty sure my truck is leaking like crazy there it's all over the bottom of my truck and saturated the rack and pinion
