Applying the Born in Texas Built by Texans decal
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by LunarRoverVehicle, May 22, 2025 at 1:26 PM.
  1. May 22, 2025 at 1:26 PM
    LunarRoverVehicle
    LunarRoverVehicle [OP] LRV
    Clover, SC
    2021 Tundra Lunar Rock TRD PRO
    Stock
    Yes… I’m five years late… but, I am loving my San Antonio built 2021 Tundra! I received my Texas Toyota Tundra decals today. Is there any trick to application? Seems to have top and back layer to the decal. Is it pre-cut between the protective sheets? Thank you for any response to what might be either redundant and/or obvious to some. Jim
  2. May 22, 2025 at 2:01 PM
    EmergencyMaximum
    I've seen gang do water spray on the surface before applying,but that was tinting film. Might work for decals too?
  3. May 22, 2025 at 2:13 PM
    LunarRoverVehicle
    Clover, SC
    Stock
    I have been assured there is no special “process.” It is actually a sticker sandwiched between two protective layers. Merely peel off the top layer with the sticker. Position to desired location. Evenly apply pressure to the sticker. Then peel back top layer. (Kind like how they do screen protectors.) (Prep area with alcohol to ensure clean and dust free.)
  4. May 22, 2025 at 2:19 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    :worthless:
  5. May 22, 2025 at 7:30 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I do use a credit card or firm plastic type scraper to smooth out any bubbles and push from the center to the edge for a clean application
  6. May 24, 2025 at 10:11 PM
    LunarRoverVehicle
    Clover, SC
    Stock
    Yes, thank you! Came out perfect!
    Leo's first and Tripleconpanna like this.
  7. May 24, 2025 at 10:28 PM
    CoffeeAddict
    CoffeeAddict New Member
    2016 Tundra CrewMax
    Where do you get these? Mine wore out years ago. The TSS stickers aren’t looking great either.
