Bed fan
Discussion in '3rd Gen Tundras (2022+)' started by Sodamo, May 24, 2025.
  1. May 24, 2025 at 4:09 PM
    Sodamo
    Sodamo [OP] New Member
    Big Island Hawaii
    2024 1784 Crewmax hybrid
    I’d like to install a 12vdc fan in my capped bed. Would need a live (not switched) 12v feed.
    My searches came up short, likely me. My Leer cap has 3rd brake light but pretty certain not a live feed but will check. Current thinking is to mount near cab, but that could change.
    Any suggestions appreciated. Thinking of a fan with either remote or even iphone controlled. Haven’t found one yet
  2. May 24, 2025 at 4:10 PM
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    Might be easier to go with a makita or Milwaukee cordless fan
  3. May 24, 2025 at 10:24 PM
    Sodamo
    Big Island Hawaii
  4. May 25, 2025 at 4:16 AM
    Retired...finally
    I just bought a 140 mm 12V fan to put on a dog crate. I wired a cigarette adapter so it can be used in the truck while driving or plug into a lithium iron battery I use to run my telescope. Even though the fan is supposed to work at 13.8 VDC, it didn't work at 13.6. I had to add a 5 ohm resistor in series to bring the voltage down to 12 volts for reliable operation.
    So, beware that some of these brushless fans were designed at computer cooling fans where the power supply put out very close to 12 volts and they may not operate properly at the voltage our trucks produce while running. If you intend on running the fan only while the truck is off you should be good voltage wise. Now, the 1 amp draw is another story.
    Sodamo[OP] likes this.
  5. May 25, 2025 at 4:43 AM
    Adam B
    Adam B New Member
    2022 Tundra TRD OFF-RD LIMITED- Green & 2024 Tundra TRD OFF-RD LIMITED- Silver
    I bought this https://www.amazon.ca/dp/B09XMWSN1D?th=1 three years ago for fly in fishing trips. Lasts around 3 days on low, super quiet, used as a charger, has a hangar, use the things every day. Honestly couldn't be happier with this purchase.
    Sodamo[QUOTED][OP] likes this.
  6. May 25, 2025 at 5:13 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
  7. May 25, 2025 at 8:27 AM
    estebanoss
    estebanoss New Member
    '23 Limited 4x4 TRD OR
    Considered this as well for the truck bed portion of my Go Fast. Wiring a cigarette outlet from the battery or something similar was best I could come up with, like a dometic DC hardwire style to simultaneously power the Dometic in the back.
    …Ended up with USB rechargeable fans for the truck when my dogs were in there and a portable battery to run the dometic on solar.
  8. May 25, 2025 at 10:16 AM
    Sodamo
    Big Island Hawaii
    Thanks for sharing.
  9. May 27, 2025 at 8:28 PM
    Sodamo
    Big Island Hawaii
  10. May 27, 2025 at 8:38 PM
    If you feel up to cutting a hole in your cap; get a maxxair fan. I got one that sucks and blows and electric hood deployment. Like @Retired...finally said, some of these don’t like a voltage variation. I got a buck boost controller that you can dial in your voltage
    estebanoss and Retired...finally like this.
  11. May 28, 2025 at 8:38 AM
    GREENPUS
    GREENPUS New Member
    Scott
    2024 Black Tundra Limited TRD Off-Road
    I'd buy that
    Raven67[QUOTED] likes this.
  12. Jun 22, 2025 at 1:19 PM
    Sodamo
    Big Island Hawaii
    Not sure how effective, but installed today
  13. Jun 22, 2025 at 3:03 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    It’s switched with the ignition but there’s a good size charging line in the 7-pin trailer plug/adapter you can tap into easily.
