Need help. Installed radio and amp now error lights are on
Discussion in '2.5 Gen Tundras (2014-2021)' started by BrandonL812, May 23, 2025.
  1. May 23, 2025 at 4:52 AM
    BrandonL812
    BrandonL812 [OP] New Member
    Brandon
    2021 Tundra Platinum
    I just finished putting in an aftermarket radio and amp on my buddy’s 2015 SR5. Using idatalink maestro and t harness for the radio. Everything connected correctly but after i start the car these lights and message appeared.
    I’ve checked all the wiring and they are correct. Flashed the maestro RR correctly and swc is working. Obd plug for the maestro is plugged in and is showing vehicle info like doors opened.
    Is there something i missed?
    Please advise.
    I’ve remove negative battery terminal for 5 mins. No change.
  2. May 23, 2025 at 8:39 PM
    BrandonL812
    Brandon
    Problem SOLVED!!!
    End up doing a Zero point calibration using the paperclip method and all light went out..
    DoublePro, Yota303, panicman and 2 others like this.
