  1. May 22, 2025 at 6:17 PM
    Jack McCarthy My work anxiety is my morning alarm clock
    Yes and no. Mostly along the edge of the front seat, especially since I pulled the overhead to see where it might be originating. I still couldn’t tell due to the foam in the way between the headliner and metal roof in front.
    Somehow it pools in the headliner then comes out in a stream when I take a curve or stop backing up or moving forward.
  2. May 22, 2025 at 7:29 PM
    What's that process like? I've never donated either.
  3. May 22, 2025 at 7:30 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    they lured me into a van with a sugar cookie.
  4. May 23, 2025 at 7:12 AM
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    New LBJ, and Eibach/Dobinson installed. Still needs to settle. Will need to add a spring pack out back.
    -Before i think was= 19.75 or 20"
    After=22.5 ( pre-settle) about even on both sides.
    Hoping it settles a inch or so. Still need to do OTR and alignment. Got called away on Kerosene spill in Columbus , OH. BIG THANKS TO @w666
    Before:
    After:
    Voss, M14 EBR, Hutcheson and 10 others like this.
  5. May 23, 2025 at 7:35 AM
    mcharfauros
    mcharfauros Hafa Adai
    MO
    06 AC SR5 4X4
    Dumb Truck Thangs
    15% Off everything but rack systems.
    SOFTOPPER
  6. May 23, 2025 at 7:40 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    who? Soft topper.
  7. May 23, 2025 at 8:08 AM
    shifty` NOT A NU JACK! NU JACK, NU JACK!
    One of the best-looking RCLB on this forum. Looks good, will be curious where it settles out.
    For platelets/plasma, there's two methods I've seen:
    LifeSouth poked one arm, pulled out blood, separated by a machine, then red blood pumped back in. I flow pretty well and was able to knock it out the two times I did platelets with them in 30-40 mins. This was years ago, so process may've changed.
    Red Cross pokes both arms, one is a supply line, the other is return line. The process is a bit more streamlined, because the machine is taking out, separating, and pumping back in with a little saline, all in one linear pattern. Platelets supposedly only takes 35-45 mins, plasma and platelets (which I did) is 90-120 mins. I got hooked up around 12:25 and was walking out the door at 2:05ish after eating some sugary snacks and having a bottled water.
    I stopped donating with Red Cross because their phone nagging to come in and donate was unbearable, and no amount of asking them to remove me worked. I finally told them I intend to work on full sleeve tattoos in the coming year, and wouldn't be able to donate, "so just stop calling". I was donating with Life South for a long time because our office sponsored the drives, and it was convenient.
    I recently went back to Red Cross because of my wife's medical diagnosis (I think I told you and a few of the other guys about that whole situation). I guess I didn't realize or remember how critical AB type blood is, we're universal donors (for A/B/AB/O) on plasma and platelets, after going online and doing research, clearly it's a bigger issue than whole red blood these days, so ... I figured "what the hell", and ponied up.
    While I was there, one of the staff mentioned Red Cross now has this Specialized Donor Program. You get $50 (roughly a buck a minute) just to go in for a physical to see if you're eligible. If eligible, they'll call you in for draws, and pay $200+ for the 1-2 hour procedure, and there's some procedures that are longer (3-5 hour) which pay up to $350. They let you donate once every 56 days, and a donation renews your eligibility, which will expire 90 days after your last donation. But when you go in to be re-screened for eligibility, they still pay you $50 for your time.
    Seems like a good way to do some good and add some slush money for hobbies etc. But the donation locations where you can participate are limited. Just so happens there's one in ATL, and it just so happens to be the location where I usually donate.
  8. May 23, 2025 at 8:09 AM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    Looking for the OEM pads for 13WL brake upgrade. Is the above still the correct part# (#04465-AZ200)? I don't see that part number under the "replaces" section when searching Toyota parts site. The pads that I do have are 04465-35290 (green check mark saying it fits my 2002) in my cart to order but I'm guessing I should just look up whatever the newest pads for a 2004 instead?
  9. May 23, 2025 at 8:13 AM
    PS @FirstGenVol - Just blood donations, it's one arm, you squeeze a ball while your body dumps blood into the bag. Anything helps, so if you don't have time for the other stuff that's 45min+, go give blood. Especially if you're an O type, AB+ types are highly sought after too, since you're A and B compatible (that's why they're always bugging me for anything I'll give)
    I can usually fill a full bag in 5-6 minutes for red blood only, it takes longer to hook up and remove than it does for me to donate. My wife is a slow bleeder, she takes 10-12 mins/bag.
    I've NEVER had an issue with anyone at Red Cross missing a vein, blowing out a vein, or other stuff. Compare that to my experience with about 1 in 4 nurses who've ever hooked me up at a doc office or lab who always seem to screw me over somehow, and ... well. I guess it's what you'd expect, these people at Red Cross are jabbing people all day long, but I've been donating since high school, and can't recall a single time when anyone with Red Cross specifically (or Life South) caused me any grief with their jabbing.
    FirstGenVol and Kalannar97 like this.
  10. May 23, 2025 at 8:19 AM
    mcharfauros
    MO
    06 AC SR5 4X4
    Dumb Truck Thangs
    Correct Softopper
  11. May 23, 2025 at 8:38 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  12. May 23, 2025 at 9:25 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  13. May 23, 2025 at 9:26 AM
    Sugar cookie you say? :monocle:
    If they were blood letting instead of using your blood for saving lives, one might think it was attempted murder.
  14. May 23, 2025 at 9:34 AM
    Dblock500
    DMV
    Getting 20% tint done on the front windows right now. They measured my windows at about 80% stock already, doesn't have any film on it. Curious if thats the case/typical for others.
    Side note: While waiting around in the lobby, they have the 11" floating Alpine and the display looks pretty impressive as well as the UI. The AX6000 Sony pales in comparison in terms of display (figuratively and literally)
    G_unit3000 and oscardog86 like this.
  15. May 23, 2025 at 10:10 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Definitely changed my reasons for giving blood but it brings back memories of first time giving blood.
    Back in my Jr College days, early 70’s, a few of us would head up from NW Jr College to Memphis on Fri evening after classes. We’d donate blood, they’d give us $20 and off we went. First destination was Steels liquor store, Como Ms. Needless to say that bought us a few bottles of Boones Farm. Yeah, I wasted parents money going to Jr College but had a hell of a time doing it.
  16. May 23, 2025 at 11:12 AM
    Nicklovin
    Nicklovin Yap Yap
    Huntington Beach, CA
    00’ 4.7 AC 4x4 - GFC
    Love me some shiny chrome wheels :D
    MooreKen likes this.
  17. May 23, 2025 at 12:09 PM
    BroHon
    BroHon What day is it?
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    Now that brings back some memories :rofl:
    BubbaW[QUOTED] likes this.
  18. May 23, 2025 at 12:26 PM
    taranovich92
    taranovich92 300K mile club
    New Smyrna Beach, FL
    2003 Tundra T3 Edition
    Airaid cold-air intake, Airaid throttle body spacer, JBA headers w/ cats, Northeastern stainless resonator, MBRP 3" res-back exhaust, Eibach struts & springs @ 3", Suspension Maxx extended front links, SPC upper control arms, OME rear shocks, Husky Spring heavy duty leafs, 2" block in the rear, TRD rear sway bar, 1.25" wheel spacers, Nitto TerraGrappler G3 285/70/17, Apple CarPlay, CB radio, Randy Ellis Design front bar, Hella 500 rally lights, Mini LED projector headlights, Trailrunner Customs fogs, SkidRow Offroad skid plate, 333 Fab steering rack clamp.
    Installed 333 Fab steering rack clamp, new Nitto TerraGrappler G3's 285/70/17, new front door speakers & tweeters, and had to add the heritage stripe on the unpainted fender.
    Voss, bmf4069, oscardog86 and 12 others like this.
  19. May 23, 2025 at 12:35 PM
    For the front clamp, notice any significant difference in turning response/tightness, beyond "perceived" response?
    Did you need to clamp the rack in place while you popped the old clamp off and installed the new one, to keep it from shifting?
  20. May 23, 2025 at 12:36 PM
  21. May 23, 2025 at 12:39 PM
    taranovich92
    The steering does feel tighter, maybe I'm just imagining things. I was able to keep the other two bolts tight and just remove the old clamp, though I might have to loosen all of the rack bolts but that wasn't the case.
  22. May 23, 2025 at 12:44 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  23. May 23, 2025 at 12:59 PM
    Too skinny for me.
    I can't find my photoshop of my truck with the thicker heritage stripes.
    I want to do something like the T100 rally truck in GT Horizon. Especially on the hood. If I could find that hood decal tomorrow, I'd buy it and install it ASAP. I love it. The striping from the rear back would just be bonus.
  24. May 23, 2025 at 1:00 PM
    Here we are. I was tinkering with two different thoughts. I think the flare being white is cooler.
  25. May 23, 2025 at 1:11 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    My vote is for the top pic. Keep the flare white
  26. May 23, 2025 at 1:54 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Truck has been sitting all week after a PCV crankcase trouble shoot last week. Just not driving much.
    Today I walked out and saw a new puddle on my driveway.
    Looked underneath and the front diff was coated in fluid... Red, not stinky. Not gear oil. Turns out transmission fluid.
    Looks like it's coming from the driver side hose where the transmission cooler/warmer line is attached to the lower radiator.
    Is it common for these to leak/ replace hose? Clamp? Both?
    Guess I'll be replacing some things and checking the fluid..
    PXL_20250523_202149449.jpg PXL_20250523_204100657.jpg PXL_20250523_204358797.jpg PXL_20250523_205002931.jpg
    Voss, oscardog86 and G_unit3000 like this.
  27. May 23, 2025 at 2:15 PM
    EyeSpyA1stGenTundra
    EyeSpyA1stGenTundra New Member
    Eric
    Looking for my future 1st Gen Tundra
    this. this is what I want - with those decals - (just double cab)
  28. May 23, 2025 at 2:28 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    How old is that radiator? Might be time to swap for a new one.
    shifty` likes this.
  29. May 23, 2025 at 2:36 PM
    Softopper
    Softopper New Member
    Heck yeah! 15% everything except racks! Now until 05/26/25. Let us know if you have any questions!
    SHOP NOW:https://softopper.com/
  30. May 23, 2025 at 3:06 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Radiator is 2 months and 2000 miles old. I am really hoping it's not the fitting and that it's the hose/clamp...
    How would you tell the difference? To my eyes the radiator, threads, and hexes on the fitting are dry "up steam" of the hose on the fitting, such that the leak looks to be coming from where the hose clamps to the fitting...
    G_unit3000 likes this.
