Pictures of leveled or lifted 2022+ Tundras
Discussion in '3rd Gen Tundras (2022+)' started by randomquickness, Jan 16, 2022.
  1. Jan 16, 2022 at 2:53 PM
    randomquickness
    randomquickness [OP] New Member
    I know there are plenty on the streets now. Lets use this thread to post pictures and please include details of what lift/level products are installed.
    offshore2005 and oxlsu40 like this.
  2. Jan 16, 2022 at 8:17 PM
    brichoux
    brichoux New Member
    I used this front leveling kit for the Gen 2 and it worked well. I’m going to add 1” to the back as soon as it’s available. 35” x 11.5” Toyos and they fit well.
  3. Apr 12, 2022 at 8:03 AM
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    2022 Tundra SR5 TRD OR CM 6.5
    Not sure how this thread got so neglected. Here are my details.
    Westcott Designs 3" front level only (Did not install 1/2" shim plate in the kit so we netted 2 1/4" of lift in the front) Truck is mostly leveled. Sits still sits 1/4" higher in the rear.
    Kit found here: https://westcottdesigns.net/product/2022-toyota-tundra-front-only-preload-collar-lift-kit-new/
    Measurements taken from center of wheel to bottom of fender liner.
    Before
    Rear: 23 3/4"
    Front: 21 1/4"
    After
    Rear: 23 3/4"
    Front: 23 1/2"
    With Toyo Open Country AT3 35x12.5r18 Load D on 18x9 +18
    She rides excellent, and ride comfort with just the front level alone is not very noticeable at all in my opinion. Rides very much like stock with possibly a tad bit more stiffness. Although I'm very happy with how she turned out, I personally would like a bit more wheel well space. So I bit the bullet and purchased the full 3/1 kit from Westcott. Once it arrives and installed I will update with more photos showing the difference from the full 3/1 kit and front level alone. Basically we'll be installing the rear 1" spacer, along with adding the 1/2" shims to the front that we originally left off, along with any bump stops and shock extensions necessary.
  4. Apr 12, 2022 at 2:39 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    I wanted to go with Westcott front only lift, but when I called Westcott and spoke to Eric, asked if I can use just the front lift preload without the shim to fit 18x9 +20 and 35x12.5. He said it wouldn't clear on the TRD sports and I need to do the full 3/1 kit. :(
    I like the look of just front lift alone on TRD offroad. Want just enough lift to clear 35's on fronts. May as well just wait for coilovers, wheels aren't coming for another 5-7 months.
  5. Apr 12, 2022 at 3:06 PM
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    Dang! That's a long wait for wheels. Seeing that the Sport is only 1/2" lower that the Off-road. I think it would still clear. I netted 2 1/4" of lift in the front without the top shim.
    35s seems to be clearing for people running just the rough country 1.75" front level. Oh well, I'm sure coilovers are coming soon. I'm going to the full 3/1 just because I like the extra wheel well space. Not to mention it also looks really good from the pictures I've seen.
    Sadly I had to buy the full 3/1 kit from Westcott, since they don't sell just the rear. So I'll be selling just the front part of that kit if anyone on here is interested. Located in Washington. Will part out the front preload collar/shims/bump stops (everything you need to level the front) for dirt cheap. I'll create a marketplace thread when the full kit arrives.
  6. Apr 12, 2022 at 4:08 PM
    Rwaters
    Rwaters New Member
    2022 Tundra TRD SR5 Crewmax
    Old Gen 2” leveling kit. 18x9 +18 with 275/70 Cooper M/T
  7. Apr 12, 2022 at 5:04 PM
    offshore2005
    offshore2005 New Member
    TEXAS
    2022 Tundra Limited 4x4 RC leveling kit and 295/65/20 Cooper STT PROs
    I will post some photos Friday. I will be putting on a RC leveling kit with 295/65/20 tires. Still deciding between Cooper STT Pros or Toyo open country R/T.
  8. Apr 13, 2022 at 4:40 AM
    Benji31
    Benji31 New Member
    Ontario, Canada
    2023 TRD off road
    Go with the Toyo’s
  9. Apr 13, 2022 at 5:39 PM
    roboots21
    roboots21 New Member
    2022 MGM Tundra Limited DC
    Westcott 3"/1" on Cooper AT3 XLT 285/65/20 with Mayhem Rampage 20x9 18mm offset wheels
    9OH1 and ToyoTundra89 like this.
  10. Apr 13, 2022 at 5:45 PM
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    That's a good lookin truck!
  11. Apr 13, 2022 at 5:48 PM
    roboots21
    Thanks! Peep your take-off mud flaps installed on it too! lol
    ToyoTundra89[QUOTED] likes this.
  12. Apr 15, 2022 at 3:00 PM
    offshore2005
    TEXAS
    Finally had the RC leveling kit put on and 295/65/20 Cooper STT Pros. I think it looks more like a truck finally. Monday she will get the ceramic coating and soon a bed cover. I added the tape measure so you can see the before and after with level and tires C21E71B0-3428-40A6-934D-4B56B4F198DB.jpg 9E943577-707C-45C5-8561-3138F8A1001F.jpg 11489F31-064D-4937-89A8-10AF5FBC54D5.jpg 32BBC0DC-4E1B-49DB-82E9-D99785D6C265.jpg
    csmobley and Justinfro like this.
  13. Sep 30, 2022 at 4:03 PM
    Carolinahrguy
    Carolinahrguy New Member
    Carolinahrguy
    2022 SR5 Crewmax
    @ToyoTundra89 Nice truck man. Hey, when you did the lift, did you notice any difference in gas mileage? Was that before or after the bigger wheels/tires? Hate to be that dude, but I commute an hour to work 1 way haha!
  14. Sep 30, 2022 at 4:13 PM
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    Little to no affect on gas mileage with just the lift level. I could still get the dash to show 21/22mpg.. as long as I reset the trip once on the hwy lol. You'll only see the effect on mpg with the larger wheels/tires. It'll be about 2 to 3 mpg loss with 35s.
    Carolinahrguy[QUOTED] likes this.
  15. May 22, 2025 at 11:19 AM
    Ati25
    Ati25 New Member
    Bilstien 5100’s front and rear with 2 inch dobbinson heavy duty coil springs
  16. May 22, 2025 at 6:57 PM
    lapoolboy
    lapoolboy New Member
  17. May 22, 2025 at 7:13 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Next, RC 1.75" level on front, then 1/2" cornfed spacer in rear. 285/65r20 Nitto Recon Grapplers. 20241011_155426 (1).jpg
    Blufin and BlackNBlu like this.
  18. May 22, 2025 at 7:38 PM
    DontTazeMeBro
    DontTazeMeBro New Member
    2022 Platinum MGM
    2022 platinum hybrid. 3/1 wescott lift for avs/air suspension. 17” scs +20 wheels with 35”x12.5” toyo tires
  19. May 22, 2025 at 8:00 PM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Yeah....my 2016 sits a bit low in the Ass End.
    Pretty sure it's due to the aftermarket bumper.
    Need to get off my ass and fix it...been to fixated on the Magnuson lately.
  20. May 22, 2025 at 8:46 PM
    akira
    akira 25 Tundra Limited TRD OffRoad
    San Diego
    JJcksn12 and Dfrink like this.
  21. May 23, 2025 at 10:52 AM
    Ati25
    Ati25 New Member
    (Complete Update) Installed Bilstein 5100's front and rear with Dobbinson 2" Heavy duty coil Springs and I'm currently running Nitto G3 load-e tires 275-65-R20.
    1. It rides much better now, before a little jumpy with the load E's but feels more planted now, at highway speeds of 75 MPH felt good and on two lanes with Bumby roads felt good too
    (Not as smooth as when it had OEM tires but still very comfortable)
    2. Towing is much more pleasant not nearly as much Squat, hooked up my boat and much better, will hook up camper next.
    3. (Cost)- Here is a break down.
    Billstein 5100's Front and Rear from Tire Rack shipped 523.87
    Dobbinson Springs 2-Inch lift, 550-770Lb from MUDIFY.com shipped 374.51
    Installation 525.00
    Alignment 141.23 At Toyota
    4. Ride Height
    Before lift Truck sat at 36-3/4 front and 38-3/4 in the rear.
    Now it sits almost at 39" in the front and 41" in the rear.
    (Side Note) If you want it leveled, I would go with the Dobinson 1" heavy duty coil springs but if you tow 2" is perfect
  22. May 23, 2025 at 6:16 PM
    Huckwheat
    Huckwheat New Member
    Scott
    Adirondacks
    2025 MGM Platinum Hybrid TRD
    Well done!
  23. May 25, 2025 at 8:53 AM
    MikroT
    MikroT New Member
    Dom
    2024 Tundra Hybrid
    Love the casual torch / flame thrower chilling in the bed - is that what it is?
  24. May 25, 2025 at 12:41 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Eibach pro truck leveling kit front and rear. Rear lift not adjustable about 1-1.5in, front is adjusted to lowest setting. Drives great for half year so far. Love it
    Half Assed likes this.
  25. May 25, 2025 at 1:58 PM
    JJcksn12
    JJcksn12 New Member
    Jay
    2025 MBM Limited TRD OR
    3” TRD Suspension Lift
    I believe that is an antenna of some sort
  26. May 25, 2025 at 4:44 PM
    Baile2ke
    Baile2ke New Member
    2025 Tundra SR5 with TRD 3” Lift
    IMG_1379.jpg 285/75 R20 with factory TRD lift
    MAC25Tundra, Dfrink and JJcksn12 like this.
  27. May 27, 2025 at 3:31 PM
    Oudlose
    Oudlose New Member
    2023 SR5 tundra 4x4
    Readylift 3inch 35 12.50 20 /20×9 +12
    Paul499 likes this.
  28. May 27, 2025 at 3:32 PM
    Oudlose
    Oudlose New Member
    2023 SR5 tundra 4x4
    3 inch ready lift, +12 offset 20x9 vision wheels, nitro 35 12.50 20
  29. May 28, 2025 at 7:38 PM
    work truck
    work truck Work Truck Duck
    Aaron
    Ontario Ca
    2023 Tundra Sr5 metallic crew 6.5
    nice stance. I’m on the fence between dobinsons HD 1” and 2” rear springs. When you took your rear measurements how much weight did you have in the back of the truck including diamond back? Thanks
  30. May 28, 2025 at 9:06 PM
    AZxp
    AZxp New Member
    '23 on 3.ohs and dirty sevens
    Little lift, 37s and trimming
