Tie rod ends?
Discussion in '1st Gen Tundras (2000-2006)' started by DJS Tundra, Apr 22, 2023.
  1. Apr 22, 2023 at 7:02 PM
    DJS Tundra
    DJS Tundra [OP] Lots to learn
    South Alabama
    2002 White Lmt 4x4
    Ok so I know i posted earlier about maybe selling the tundra but before I do that had to repair steering rack bushings and while in the process of replacing those I discovered my tie rods are about shot one inner and both outer.
    Do you guys stay OEM which I’m fine on the outer as I can get them for around $45-$50 a piece but the OEM inners are around the $180 mark.
    Most aftermarket inners are way cheaper like the TRQ, Detroit axle, Sankei 555, moog etc they range from $20 to $40 a piece.
    Anyway anyone had good results with aftermarket inner tie rods?
  2. Apr 22, 2023 at 7:12 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Tie rods I haven't heard of issues with, for the aftermarket ones.
    I've run sankei on my civic and moog on my corolla. Granted these are their older made in japan stock (for the moog), which may not be the case anymore if they've switched suppliers.
    I'd probably go with sankei.
  3. Apr 22, 2023 at 7:13 PM
    He can correct me if I'm wrong, but I feel like I remember @KNABORES saying he installed MOOG and they're doing OK, but maybe I'm nuts
    KNABORES and DJS Tundra[OP] like this.
  4. Apr 22, 2023 at 7:14 PM
    I’ve been running Moogs for 5 years now on the inner tie rods. No issues.
  5. Apr 22, 2023 at 7:17 PM
    DJS Tundra
    South Alabama
    2002 White Lmt 4x4
    I like the sound of that
    I was worried these were going to be an OEM only item like LBJs.
  6. Apr 22, 2023 at 7:18 PM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    I put TRW outer tie rods in back in 2019 and they've held up great. I still need to replace the passenger side inner tie rod as it's got some play
    DJS Tundra[OP] likes this.
  7. Apr 22, 2023 at 7:20 PM
    There was a thread on here ... here it is: https://www.tundras.com/threads/corner-of-shame-oem-minus-or-plus.122591/
    I wasn't going nuts. KNABORES said to avoid Mevotech, they went to shit fast, but MOOG was OK.
    MOOG isn't the same company it used to be, some of their stuff definitely isn't good quality anymore, but I've seen enough people say the tie rod ends are alright. I used to swear by their offerings.
    Anyway, reference that thread for what is and isn't safe to go OEM for parts. General rule of thumb is, if it has electricity going thru it, you really want to buy OEM from a legitimate vendor, not scAmazon, not fleaBay, not WallyWurld. And lower ball joints always OEM. There are some exceptions. That thread covers 'em.
  8. Apr 22, 2023 at 7:26 PM
    DJS Tundra
    South Alabama
    2002 White Lmt 4x4
    Good deal
    Thank you sir
  9. Apr 22, 2023 at 7:33 PM
    Just be careful putting them on or taking the old ones off. There’s a flat spot on the steering rack itself you need to hold still with a wrench while you torque the old ones off or the new ones on. Steering rack needs to stay stationary and not twist with the inner tie rod. You’ll know what I mean when you pull off the dust boots and expose it.
  10. Apr 22, 2023 at 7:43 PM
    DJS Tundra
    South Alabama
    2002 White Lmt 4x4
    Thanks for the heads up.
    I had an absolute nightmare of a time changing the bushings on the rack today so definitely don’t wanna mess anything up.
    Jack McCarthy likes this.
  11. Apr 22, 2023 at 8:03 PM
    Lupe
    Lupe New Member
    Lupe
    2006 Tundra
    58 ome ones online for them at boch toyota south
  12. Apr 22, 2023 at 8:53 PM
    Mevotech is trash. Moog is hit or miss. The outer tie rods have held up well for several years.
    The Black Mamba, shifty` and blenton like this.
  13. Apr 23, 2023 at 2:19 AM
    blenton
    blenton New Member
    This has been my experience as well.
  14. May 19, 2023 at 6:07 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    While changing my LBJs today I noticed one of my outer tie rods was no good. Bought a replacement from O’reillys (hopefully the consensus on those is that they are decent, if not it I will replace just needed something right away), while getting the nut loose my inner tie rod did spin a little. Is it normal for it to be able spin freely? I know the inner has a ball joint. Hopefully I didn’t screw my self
  15. May 19, 2023 at 6:13 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Yes. Inner tie rod has a ball & socket design.
    Unless the inner was loose, it'll be fine.
  16. May 19, 2023 at 6:24 PM
    805Tundra
    Ben
    Central Coast
    Thanks!
  17. May 19, 2023 at 7:23 PM
    You’ll still need an alignment
    805Tundra and shifty` like this.
  18. Sep 27, 2023 at 1:58 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Any updates here, Iv been running Moog for about 40K miles and I started to get a clunk noise while reversing out of my driveway. Need to replace but OEM is about $100+ EACH.
    Is 40K miles good or bad? Should I go with Moog again? (I am lifted 2.5 inches on 33s)
  19. Sep 27, 2023 at 1:59 PM
    40k is better than the 1k I got outta my Moog TREs
    The Black Mamba likes this.
  20. Sep 27, 2023 at 2:08 PM
    What about the inner tie rods? I think mine need to be replaced. I went OEM on the outers in 2019.
    What are the steps for replacing the inner tie rods?
  21. Sep 27, 2023 at 2:12 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    One of my original Moogs when I did my lift had a hole in the boot and lasted about 20min so my replacement lasted 40K. Based on the above they are hit and miss.
  22. Sep 27, 2023 at 2:13 PM
    Inners were pretty easy. They just spin on and off. Pull the outer from the knuckle, unscrew from the inner. Remove the boot. Then unscrew the inner from the steering rack. Need a big skinny crescent or the correct large wrench to loosen and tighten the inner. There's a shield on it that makes it tough to get a bigger wrench on there.
  23. Sep 27, 2023 at 2:24 PM
    What brand inner did you go with?
  24. Sep 27, 2023 at 2:37 PM
    Moog I think :crapstorm:
  25. Sep 28, 2023 at 2:25 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    One side of mine is moog, the other is unbranded. The moog one leaks. Still seems tight and no issues so I just grease it every once in a while.
  26. May 22, 2025 at 8:29 AM
    Dirt Ferguson
    Dirt Ferguson New Member
    Daniel
    Northern California
    04 SR5 AC 4X4 V8
    Does a new OEM rack and pinion
    44250-0C041
    come with inner TREs already on it?
    Or do the inner and outer TREs need to be purchased separately from the rack?
  27. May 22, 2025 at 10:14 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Dirt Ferguson[QUOTED] likes this.
  28. May 22, 2025 at 10:56 AM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    Just did mine 2 weeks ago. The outers are separate (was about $65 each)
  29. May 22, 2025 at 4:06 PM
    TnPlowboy
    TnPlowboy New Member
    2004 Tundra SR5 AC 4.7L 4WD, Tow Package: Blue Marlin Pearl
    OEM Inner Tie Rods are included with the new OEM Rack but not the OTRs.
    Double check the part # for your steering gear. We have the same year and model and my OEM Rack was 44250-0C030. I have a spreadsheet listing the racks and part #s for all the 1st Gen Tundras and Sequoias. I'll try to pull it up and see what the Scooby is. Do you have the tow package?
  30. May 22, 2025 at 4:36 PM
    TnPlowboy
    Looks like 44250-0C030 is for 2003-2006 Tundras equipped without a rear stabilizer bar.
    44250-0C041 fits 2003-2006 Tundras and 2001-2007 Sequoias with the rear stabilizer bar.
    Not sure of the actual differences between the racks maybe someone else here knows because from all accounts, they are different.
