Cause of my bad fuel mileage?
Discussion in '2nd Gen Tundras (2007-2013)' started by Cobi 2010, May 8, 2025.
  1. May 8, 2025 at 2:03 PM
    Cobi 2010
    Cobi 2010 [OP] New Member
    2011 Tundra limited 4x4
    My mileage around town is 10 to 11 mpg. The truck is running perfect. I drive mellow and the mpg use to be 14 to 16. I took it to toyota and they checked the computer and everything was ok. The truck has 62k miles and is like new. Could winterized fuel be the culprit. Any ideas out there
  2. May 8, 2025 at 2:23 PM
    You on a lift and 35s?
    grave likes this.
  3. May 8, 2025 at 2:35 PM
    Cobi 2010
    Nope stock tires and wheels
  4. May 8, 2025 at 3:41 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Well, good news, bad news. Burn the remaining fuel and refill with premium. Check your brakes to ensure nothing is dragging. Check vacuum lines and intske filter, just in case a rodent has stuffed your airbox with stuff.
    Fobroader and TheBeast like this.
  5. May 8, 2025 at 9:33 PM
    Rathesun
    Rathesun New Member
    Alaska
    2013 Tundra Double-cab 5.7L engine
    Nothing to lose if you add a fuel stabilizer and cleaner to remove moisture in the tank. I use Seafoan, and it does a good job. Just make sure that you use the right kind of Seafoam (read the label). I use it on my chainsaws, lawn tractor, and so on- when storing them for the winter. Now, where I live at (Alaska) alcohol-based fuels aren't sold at the pumps.
    chugs likes this.
  6. May 12, 2025 at 11:29 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    the quickest way from 14 to 10, ask me how i know
  7. May 12, 2025 at 11:36 AM
    Cobi 2010
    How do you know
  8. May 12, 2025 at 8:13 PM
    Cobi 2010
    Problem solved !!!! Premium non-ethanol fuel.
    DSLKSL likes this.
  9. May 13, 2025 at 10:01 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    i lifted my truck and put 35s on. worst decision
    chugs likes this.
  10. May 15, 2025 at 1:36 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Run a can of Royal Purple Max Clean next time you plan on driving through at least half a tank.
    k0diak8o8 likes this.
  11. May 15, 2025 at 1:41 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    I run 87 Et blend and still get 16-17 on the highway, 14-15 on the freeway.
  12. May 21, 2025 at 9:02 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    and enjoy that amazing .2MPG bump!
  13. May 21, 2025 at 10:02 AM
    Danny3737
    It gave me an extra 2.5 MPG in my 2004 Denali after the first can. Also smoothed out my idle.
  14. May 21, 2025 at 2:05 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    i used it in my old frontier a couple times and would get a 1mpg bump for a tank or two and then back to normal.
  15. May 21, 2025 at 2:24 PM
    Danny3737
    I never lost what I gained The reviews for it are unbelievable
  16. May 22, 2025 at 9:37 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    i'll give it a whirl this weekend. any issues with older, high-mileage vehicles? my '07 4.7 has 276K
  17. May 22, 2025 at 10:01 AM
    Danny3737
    No problems at all. Even works great on 2 stroke lawn equipment. Check out the reviews on Amazon, etc. Walmart has the best price. Usually around $12.99. 1 can does 20 gallons. Pour in to the tank, then fill up so it mixes up thoroughly. Hopefully it will help out some. If you have a tank, you may need a little more than one can. Just don’t add too much
