SOLVED! Belt Squeak/Squeal (Not Belt/Tensioner/Idler Pulley)
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Capema00, Jan 14, 2023.
  1. Mar 3, 2024 at 7:28 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Good luck! I'm going to have to address mine at some point soon.
  2. Mar 3, 2024 at 5:58 PM
    Gunshipgator
    Gunshipgator New Member
    ‘10 Sequoia
    Bilstein shocks and exhaust bypass
    So I think you can swap the alternator from the front, but you’ve got to remove fan shroud, PS pump, etc. Alternatively (ahem), I think you can replace just the pulley without removing the alternator. Going to look into this further, as mines still producing but is just noisy.
  3. Mar 12, 2025 at 5:29 PM
    NWPirate
    Zach
    WA
    My chirp is back, with 75k miles now.
    Does anyone know what Toyota calls the fan clutch? It's not coming up on a parts search
  4. Mar 12, 2025 at 8:26 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Thingy?? :notsure:
    NWPirate[QUOTED] likes this.
  5. Mar 12, 2025 at 8:31 PM
    Tripleconpanna
    NWPirate and AZTundra like this.
  6. Mar 12, 2025 at 9:26 PM
    NWPirate
    Zach
    WA
    :fistbump:
    Yep, putting together a big list to order this weekend.
    I've used Serra Toyota before, they're running the 25% off sale too
  7. May 22, 2025 at 7:55 AM
    kbmcruiser
    kbmcruiser New Member
    KMack
    2016 White Tundra TRD 4x4
