  1. May 22, 2025 at 3:51 AM
    Dakillacore
    Dakillacore Brake now, you Mickey Mouse-piece of shit!
    Georgia
    I think it looks good. The real question is do you like it.
  2. May 22, 2025 at 4:34 AM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    265/70R17
  3. May 22, 2025 at 5:29 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    My shift lever is now so sloppy that the overdrive button only works intermittently. So I guess it's time.
    This guy is in the shop for some leg repair.
  4. May 22, 2025 at 5:33 AM
    Damn. Someone must hate brontosauruses.
    JakeJake[QUOTED] likes this.
  5. May 22, 2025 at 5:40 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  6. May 22, 2025 at 6:06 AM
    Looks like we got Tonya Harding in the area.
  7. May 22, 2025 at 6:18 AM
    Dakillacore
    Georgia
    Nastiest part is when it sneezed on her. Yuck hah.
  8. May 22, 2025 at 6:20 AM
  9. May 22, 2025 at 6:27 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    What would Nancy Kerrigan do, huh? Nancy Kerrigan wouldn't give up. When things were looking their darkest Nancy Kerrigan fought to be the best. She wouldn't stop until she was number one. Uh, Stan. Nancy Kerrigan wouldn't settle for second best. Stan. She wouldn't quit until she brought home the gold. Stan! What? Nancy Kerrigan got the silver, dude. She came in second. Really? Yeah, dude. Oh, never mind, Jesus. Nancy Kerrigan sucks.
    bmf4069 and shifty`[QUOTED] like this.
  10. May 22, 2025 at 6:27 AM
    275's would look better. 285's would look best. I think you have the same wheels as me. They have the perfect backspace which is why I think I don't have the rubbing issues that others(mostly @shifty` ) complain about. That combined with the right caster alignment specs.
    Just noticed your truck is 2WD. So 33's might be overkill honestly. If you aren't taking it off pavement much, might be worth sticking with 275's.
  11. May 22, 2025 at 6:36 AM
    455h0le_dachshund likes this.
  12. May 22, 2025 at 6:52 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I have ~45k miles on my at3’s and I swear these things will go another 30-40k. This is by far my favorite tire.
    G_unit3000 and 455h0le_dachshund like this.
  13. May 22, 2025 at 6:54 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    You need a mini one for a hood ornament. Or some longhorns
  14. May 22, 2025 at 6:54 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
  15. May 22, 2025 at 7:16 AM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    I agree, I only run AT3's on my trucks, they wear forever, not noisy on the highway, and are great in the snow.
    khooiii[QUOTED] and Dakillacore like this.
  16. May 22, 2025 at 8:57 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Bought Tundra in 2009 w/113K miles, bought TOYO Open Country H/T II since it’s an asphalt princess. Have no reason to leave TOYO, great tire.
    Dakillacore likes this.
  17. May 22, 2025 at 10:13 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Cooper at3? Do we have the same tires?
  18. May 22, 2025 at 10:34 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    You've got the goofy 2000 year only OD button. You may be able to clean the contacts if wiggling the button makes the OD light flicker/flash. I think @Tundra2 replaced his whole stalk. I can't remember if it was due to the OD button or something else.
  19. May 22, 2025 at 10:43 AM
    255s>all others.
    The Black Mamba and Sirfive like this.
  20. May 22, 2025 at 10:45 AM
    Chicks like girth.
  21. May 22, 2025 at 10:55 AM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    Yep. The last set I had on for 8 years. Even then they still had enough tread for normal driving but I like a deeper cleat for snow (I plow) so I finally replaced them. Of course I don't take 90 degree curves at 50mph and scrub the edges off either. AT tires require a different approach to driving on backtop if you want to get mileage out of the tread.
  22. May 22, 2025 at 11:08 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Toyo sir
  23. May 22, 2025 at 11:10 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    295mm vs 10.5in
    Voss, Dakillacore and KNABORES like this.
  24. May 22, 2025 at 1:10 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    that’s what I’m thinking I don’t want 285s just a bit more height. I don’t really off-road just out to our sites
  25. May 22, 2025 at 2:12 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I replaced the entire stalk at first because the wiring was damaged INSIDE the gear shift lever somehow. Later on i replaced the bracket that often fails
  26. May 22, 2025 at 2:39 PM
    Neo
    Neo New Member
    Alabama
    2002 AC LTD 4x4 4.7 V8
    I just started seeing the (Parking) Brake Warning Light coming on under acceleration. It goes off as soon as I let off the gas. I checked the fluid level in the reservoir and it's well above minimum.
    The Parking Brake Switch and Pedal appear to be playing well and I can't see how acceleration could overcome the pedal return spring and allow the switch to move.
    Parking Brake Off
    Parking Brake Set
    Front pads and rotors were replaced 10/03/2024 and have just 7,000 miles on them. I'm wondering if the float in the reservoir is having trouble. Any pointers?
  27. May 22, 2025 at 2:40 PM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    My 2001 has it as well.
  28. May 22, 2025 at 3:25 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    Are exhausts still cool? Ive been debating a magnaflow or something
  29. May 22, 2025 at 3:37 PM
    As long as you drive a v8, they will always be cool.
    455h0le_dachshund and Sirfive like this.
  30. May 22, 2025 at 5:40 PM
    From the megathread, not applicable? :
    • E-Brake light stuck on: Wear on the parking brake pedal shaft and pin may cause the parking brake light to stay on, more info here.
    G_unit3000 and Neo[QUOTED] like this.
