OEM Fog Lights or Worth Upgrading?
Discussion in '2.5 Gen Tundras (2014-2021)' started by NickB23, May 21, 2025.
  1. May 21, 2025 at 7:17 PM
    NickB23
    NickB23 [OP] New Member
    Hey I recently picked up a 2017 Tundra limited. Im assuming the fog lights are burned out (unless there’s a secret switch I’m missing) because they wont automatically come on with the headlights.
    I’m struggling with visibility at night when taking turns. Do the OEM bulbs do a good enough job or should I upgrade to something else?
    No real plans to off road the truck any time soon Im just looking for something to help me see better on the road.
    Thanks!
    Corndog123 likes this.
  2. May 21, 2025 at 7:20 PM
    Have you checked your stalk for the fog light position on the steering column? Can you see the actual OEM fog lights?
    bulldog93 and Corndog123 like this.
  3. May 21, 2025 at 7:25 PM
    RobertD
    Robert
    DFW, Texas
    The fog lights don't automatically come on with the stock set up. Check your user manual for how to turn them on and confirm if they are burned out before you mess with replacing.
  4. May 21, 2025 at 7:26 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Upgrade to oem led fogs is an awesome and cheap Upgrade
  5. May 21, 2025 at 7:55 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    You can find your manual here.
    You don't need to make an account.
    Toyota Manuals and Warranties | Toyota Owners
    Fog light fuse is under the hood.
    8615d53f-6d67-4076-935b-9b7805cc6e13_73e4ae4d50bac0fba2a44347e47aa641b4162af3.png3a5d38cb-addb-4860-b556-f502a5211a39_88e3f873becc0aa1e7faff550dae632bf1b88413.png
  6. May 21, 2025 at 7:57 PM
    Tundrav82019
    Tundrav82019 I have all the duckies
    Leo
    2019 Tundra Limited TRD Off Road
    They have OEM LED bulb replacements for the halogen ones 2017 comes with. Just make sure you get a quality bulb to help convert from halogen to LED. Same thing can be done for the headlights without replacing the entire stock unit. Got mine off Amazon and took a little, but worked well.
    NickB23[OP] and 1lowlife like this.
  7. May 21, 2025 at 8:02 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
  8. May 21, 2025 at 8:18 PM
    NickB23
    1lowlife[QUOTED] likes this.
  9. May 21, 2025 at 8:19 PM
    NickB23
    Definitely interested in doing the LED fogs now. Do you remember the brand you went with?
  10. May 21, 2025 at 8:56 PM
    Tundrav82019
    Leo
  11. May 21, 2025 at 8:59 PM
    Tundrav82019
    Leo
    https://a.co/d/igkRjkg
    double check fit and your head light bulb, but I think it was these two I used and worked very very well
    NickB23[OP] likes this.
  12. May 21, 2025 at 9:00 PM
    Tundrav82019
    Leo
    For the fog lights they are Omni directional, but for the headlight bulb there is a up and down! Haha I installed mine upside down and was blinding people for a while and had to swap em. Check/test prior to putting it all back together. The grill had to be removed to remove headlight housing to install light bulb. Fog lights are pretty easy without much removal.
    the third brake light and reverse lights they make similar models and really light up stuff! Most plug in play.
  13. May 22, 2025 at 3:17 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
  14. May 22, 2025 at 3:17 AM
    Corndog123
    Sam
    Tennessee
    Welcome from TN!! And if you are wanting to upgrade anyway, I'd say go for it. It's pretty easy to do and I love mine!
  15. May 22, 2025 at 6:35 AM
    scrogs22us
    scrogs22us New Member
    jason
    2019 Toyota Tundra SR
    I saw "fog lights" and wanted to ask - So i just got a 2019 SR - and I wanted to put fog lamps in. I got a kit, with the correct blubs and the wiring came with it -there is Fog lamp fuse - good, there was already wiring in the truck. However, I installed them and it does not work - what can I do?
  16. May 22, 2025 at 6:40 AM
    NickB23
    Awesome thanks! Excited to finally see where I’m turning.
  17. May 22, 2025 at 6:41 AM
    NickB23
    Which set did you end up installing?
    Corndog123[QUOTED] likes this.
  18. May 22, 2025 at 6:59 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    Diode Dynamics SS3 Pro Max fogs work great. They are far more powerful than your headlights. Get ahold of @memario1214 . He'll get you hooked up.
    sonofdad and memario1214 like this.
  19. May 22, 2025 at 7:17 AM
    Corndog123
    Sam
    Tennessee
    I just went to an LED bulb.
    sumosam1 and NickB23[QUOTED][OP] like this.
  20. Jun 1, 2025 at 9:04 PM
    737fixer
    737fixer New Member
    To your original question. I live in the city and want the fog lights on all the time purely for the safety aspect of more lights for the idiot turning left in front of you. I went with the OEM LED and they are perfect for this. You can leave them on all the time without bothering anyone, but their light output is minimal to just ok if using them for actual driving. While aftermarket like Ridgid and Diode Dynamics are incredible for offroad or open highway they should be turned off when driving in public. Yes, the OEM absolutely light up the area directly in front of your truck but it's comparing a household 40w light bulb vs a 100w.
    BillyB likes this.
  21. Jul 25, 2025 at 11:11 AM
    Do you have the white with amber backlight or the yellow?
  22. Jul 25, 2025 at 11:24 AM
    KH1414
    KH1414 New Member
    Kenny
    2019 SR5 TSS
    Alpharex tails, RC nerf steps, TRD Pro rear sway, Klearz 3rd brake smoked lense
    I went with OEM LED and they have been great
  23. Jul 25, 2025 at 11:25 AM
    The OEM LED fogs are weak compared to some of the aftermarket.
  24. Jul 25, 2025 at 11:49 AM
    KH1414
    KH1414 New Member
    Kenny
    2019 SR5 TSS
    No doubt, but paired with the Pro LED headlights they’re all I need
  25. Jul 25, 2025 at 12:21 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    I have the white, I believe in the fog pattern. Maybe drive pattern. Can't remember. No backlight, they are a few years old.
  26. Jul 25, 2025 at 12:34 PM
    Gotcha. I'm considering replacing my Rigids with a set. $$$ though since I have 4 of them.
  27. Jul 25, 2025 at 12:58 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    I ripped my stock fogs out almost immediately as the they're brutally weak. Being I wasn't planning on running them on residential streets I replaced them with Rigid D2's for times when a person really needs extra light. One of the best upgrades i've done.
  28. Jul 25, 2025 at 3:23 PM
    Mountaineer
    Mountaineer New Member
    TN
    2019 MGM Platinum
    I can vouch for the Diode Dynamics SS3 Max fogs. I used to think my factory LED fogs were pretty good, but then drove some cars with noticeable better lighting. The SS3's have a wider pattern and much brighter. They aren't cheap, but I've come to appreciate better lighting as I've gotten older.
