OEM Fog Lights or Worth Upgrading?
Discussion in '2.5 Gen Tundras (2014-2021)' started by NickB23, May 21, 2025 at 7:17 PM.
  1. May 21, 2025 at 7:17 PM
    NickB23
    NickB23 [OP] New Member
    Hey I recently picked up a 2017 Tundra limited. Im assuming the fog lights are burned out (unless there’s a secret switch I’m missing) because they wont automatically come on with the headlights.
    I’m struggling with visibility at night when taking turns. Do the OEM bulbs do a good enough job or should I upgrade to something else?
    No real plans to off road the truck any time soon Im just looking for something to help me see better on the road.
    Thanks!
    Corndog123 likes this.
  2. May 21, 2025 at 7:20 PM
    Have you checked your stalk for the fog light position on the steering column? Can you see the actual OEM fog lights?
  3. May 21, 2025 at 7:25 PM
    RobertD
    Robert
    DFW, Texas
    The fog lights don't automatically come on with the stock set up. Check your user manual for how to turn them on and confirm if they are burned out before you mess with replacing.
  4. May 21, 2025 at 7:26 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Upgrade to oem led fogs is an awesome and cheap Upgrade
  5. May 21, 2025 at 7:55 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    You can find your manual here.
    You don't need to make an account.
    Toyota Manuals and Warranties | Toyota Owners
    Fog light fuse is under the hood.
    8615d53f-6d67-4076-935b-9b7805cc6e13_73e4ae4d50bac0fba2a44347e47aa641b4162af3.png3a5d38cb-addb-4860-b556-f502a5211a39_88e3f873becc0aa1e7faff550dae632bf1b88413.png
  6. May 21, 2025 at 7:57 PM
    Tundrav82019
    Tundrav82019 New Member
    Leo
    2019 Tundra Limited TRD Off Road
    They have OEM LED bulb replacements for the halogen ones 2017 comes with. Just make sure you get a quality bulb to help convert from halogen to LED. Same thing can be done for the headlights without replacing the entire stock unit. Got mine off Amazon and took a little, but worked well.
    NickB23[OP] and 1lowlife like this.
  7. May 21, 2025 at 8:02 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    iHacker and Fobroader like this.
  8. May 21, 2025 at 8:18 PM
    NickB23
    1lowlife[QUOTED] likes this.
  9. May 21, 2025 at 8:19 PM
    NickB23
    Definitely interested in doing the LED fogs now. Do you remember the brand you went with?
  10. May 21, 2025 at 8:56 PM
    Tundrav82019
    Leo
  11. May 21, 2025 at 8:59 PM
    Tundrav82019
    Leo
    https://a.co/d/igkRjkg
    double check fit and your head light bulb, but I think it was these two I used and worked very very well
    NickB23[OP] likes this.
  12. May 21, 2025 at 9:00 PM
    Tundrav82019
    Leo
    For the fog lights they are Omni directional, but for the headlight bulb there is a up and down! Haha I installed mine upside down and was blinding people for a while and had to swap em. Check/test prior to putting it all back together. The grill had to be removed to remove headlight housing to install light bulb. Fog lights are pretty easy without much removal.
    the third brake light and reverse lights they make similar models and really light up stuff! Most plug in play.
  13. May 22, 2025 at 3:17 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
  14. May 22, 2025 at 3:17 AM
    Corndog123
    Sam
    Tennessee
    Welcome from TN!! And if you are wanting to upgrade anyway, I'd say go for it. It's pretty easy to do and I love mine!
  15. May 22, 2025 at 6:35 AM
    scrogs22us
    scrogs22us New Member
    Today
    jason
    2019 Toyota Tundra SR
    I saw "fog lights" and wanted to ask - So i just got a 2019 SR - and I wanted to put fog lamps in. I got a kit, with the correct blubs and the wiring came with it -there is Fog lamp fuse - good, there was already wiring in the truck. However, I installed them and it does not work - what can I do?
  16. May 22, 2025 at 6:40 AM
    NickB23
    Awesome thanks! Excited to finally see where I’m turning.
  17. May 22, 2025 at 6:41 AM
    NickB23
    Which set did you end up installing?
    Corndog123[QUOTED] likes this.
  18. May 22, 2025 at 6:59 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    Diode Dynamics SS3 Pro Max fogs work great. They are far more powerful than your headlights. Get ahold of @memario1214 . He'll get you hooked up.
    memario1214 likes this.
  19. May 22, 2025 at 7:17 AM
    Corndog123
    Sam
    Tennessee
    I just went to an LED bulb.
    NickB23[QUOTED][OP] likes this.
