2nd Gen Rear Bumpers!
Discussion in '2nd Gen Tundras (2007-2013)' started by FlashCulprit, Dec 13, 2016.
  1. Mar 8, 2023 at 11:29 AM
    #121
    roxton
    roxton New Member
    Jeff
    2008 Nautical Blue SR5 Crewmax
    First Post. Might as well make it a good one.
    Anyone have a manufacturer for this bumper?
    My luck is it is a custom fab.
    It was installed on the Gen2 Russian Line-X Tundra many years ago.
    I really love the look. Like the profile.
    Comfort, TravisG and WVI like this.
  2. Sep 17, 2023 at 5:03 PM
    #122
    Dmaster509
    Dmaster509 New Member
    Jon
    08 Tundra Double Cab Limited
    Snug top cap, topper EZ lift, CCM catalytic converter/skid plate
    Has anyone seen a single swing arm (with a table) rear bumper for a 2nd Gen. I've found a brute force rear bumper for a 1st Gen but never seen one for a 2nd.
    Kiddnapped Tundra likes this.
  3. Jan 1, 2024 at 8:33 AM
    #123
    AlexFIA
    AlexFIA New Member
    Tundra Rock Warrior
    I've had an Iron Cross bumper for about 8 years and has been great. Customer service excellent.
  4. Feb 2, 2024 at 4:15 AM
    #124
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
  5. Mar 30, 2024 at 3:37 AM
    #125
    surffj62
    surffj62 New Member
    2011 DBL RW
    Expedition one bumper-
    Took about 12 weeks to show up (as advertised). Great to work with on phone etc.
    very well put together- very well packed out.
    I wasn’t happy about getting rear ended but I was happy to not pay the a body shop for some bs aftermarket bumper and using the insurance money for this instead!
    Biff's R, TheBeast, Deaner and 5 others like this.
  6. Mar 30, 2024 at 6:27 AM
    #126
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Looks great. I pity the next fool to rear end you!
  7. Apr 23, 2024 at 5:58 PM
    #127
    Douglasmstrain
    Douglasmstrain Love my job! Driving my Tundra over hill and dale.
    Doug
    Southwestern Oregon
    2010 Tundra double cab, 2021 Tundra Crew Max
    Good evening everyone, thanks in advance for any help. I think I've already got the answer by reading this thread. I am trying to solve the problem in the pic.
    If I keep dragging this on the ground it's going to break off. I'm looking at a rough country bumper for a 2014 on. This truck is a 2010.
    Any thoughts?
  8. Apr 23, 2024 at 7:32 PM
    #128
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Not to discourage you from going after market :D, but, I relocated mine when I snagged it on a rock.
    Could just be a stop gap for you.
    Also to directly answer your question, the 2014+ bumpers will bolt on no problem but the body lines do not line up so you can get rubbing between the bumper and the bedside. If you look at them the 2014+ all come to a point on the bottom where the 07-13 are more squared off.
    Mdl and Cruiserpilot like this.
  9. Apr 23, 2024 at 7:43 PM
    #129
    Douglasmstrain
    Doug
    Southwestern Oregon
    Thank you! That is a very clean solution you have. I have been going back and forth about the pointed portion of the 2014 plus models. The reason I'm thinking aftermarket is also because of the step. The older I get the more important that will become. I climb in and out of there all the time. How hard was it to make the change that you made? I might do that on an aftermarket bumper
  10. Apr 23, 2024 at 7:50 PM
    #130
    APalmTree
    Brandon
    SW Washington
    It took me maybe 30 mins all in. I dropped the spare, crawled under, and planned for about 15 mins then hit it with a 2" hole saw for the 7pin half of the plug and a dremel to trim the rest of the plastic for the 4pin half of the plug. It is held in there with the factory clip on the plastic. I did not get any good pictures but I made this markup for the cuts that I made. The purple line is the sheet metal 'frame' of the bumper under the plastic shell.
  11. Apr 23, 2024 at 8:02 PM
    #131
    Douglasmstrain
    Doug
    Southwestern Oregon
    So, this is what I'm going to do. I did order a new bumper. I went with a DV8. It's got a deeper step and I will cut the hole just like you did. Thank you so much for the post. Exactly what I needed
    APalmTree[QUOTED] likes this.
  12. Apr 28, 2024 at 12:16 PM
    #132
    Douglasmstrain
    Doug
    Southwestern Oregon
    PXL_20240427_214130635.MP.jpg PXL_20240427_221848451.jpg PXL_20240427_221852622.jpg PXL_20240428_190111499.jpg
    Really like this DV8 bumper. Super simple to install. Adapting it for the RV connector was definitely a challenge. Used a Milwaukee hole saw and a Milwaukee blade for my sawzall. Did the final final cutting to fit with a carbide bit in my air grinder.
  13. Apr 28, 2024 at 1:23 PM
    #133
    APalmTree
    Brandon
    SW Washington
    Looks like that took you a little more work than it took me :p. Finished product looks like it was meant to be there though good work!
  14. Oct 11, 2024 at 8:59 PM
    #134
    Bigblueintahoe
    Bigblueintahoe New Member
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    Great looking rig!
    surffj62[QUOTED] likes this.
  15. Oct 11, 2024 at 9:00 PM
    #135
    Bigblueintahoe
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    How do you like those wheels?
  16. Oct 22, 2024 at 4:12 PM
    #136
    briarpatch
    briarpatch New Member
    So....maybe I'm asking this in the wrong place.......but I want to replace my OEM bumper with another OEM bumper...albeit an aftermarket one. Has anyone purchased from a vendor for these that they got good fit and finish?
  17. Nov 23, 2024 at 9:46 PM
    #137
    Optic15
    Optic15 New Member
    SF Bay Area
    2011 White Tundra SR5
    Level kit Morimoto XB headlights & fog lights LED light bar behind bumper KMC XD wheels 18” 34” Cooper Discoverer tires Pioneer double din head unit 10” subwoofer - x2 Back up camera trunk latch
    Has anyone found a dual swing out aside from expedition one? Looking to not break the bank but also keep it somewhat slim. The expedition one bumper just seems to me a bit too bulky and heavy.
  18. Nov 23, 2024 at 10:05 PM
    #138
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    https://sobfabrication.com/
    Optic15[QUOTED] likes this.
  19. Dec 1, 2024 at 7:43 PM
    #139
    click
    click New Member
    SoCal- IE
    White 2008 Tundra 5.7 TRD dbl cab 2x4
    Installed a Nilight brand bumper today, purchased from Amazon because it disappeared from the Nilight website a week or so ago.
    it wasn’t easy to attach, but I managed. Also, when you open the tailgate it just barely lays on the bumper when fully down.
    Overall I’m really happy with it. I need to hook up the LED lights still, if anyone can point me to a resource for wiring them I’d appreciate it!
  20. Dec 1, 2024 at 8:11 PM
    #140
    PnwTundra07
    PnwTundra07 New Member
    Oregon
    2007 double cab limited
    Custom high clearance bumper i had my buddy build all welded to the stock hitch brackets
    TheBeast and Kiddnapped Tundra like this.
  21. Mar 11, 2025 at 5:04 PM
    #141
    APG
    APG New Member
    2007 Green Kevlar Limited CM 5.7 4x4 TRD
    Kevlar Paint AlphaRex LED Headlights Aftermarket tail-lights
    Bumper looks nice and price looks nice too lol. How bad is the tailgate issue? Did you do anything to mitigate it?
    For the lights: https://www.youtube.com/watch?v=ZVG7X-ae298
  22. Mar 11, 2025 at 6:55 PM
    #142
    APG
    APG New Member
    @vtdeuce Did you end up getting this bumper? I like the one piece design over the 3 piece
  23. Mar 18, 2025 at 4:53 AM
    #143
    grayscale
    grayscale New Member
    DFW
    2013 Tundra CM TSS 4X4 5.7FFV
    Anyone installed a 2.5 gen bumper? I know the contours on the bed are a little different, just curious if anyone had or even tried
  24. Apr 21, 2025 at 11:19 AM
    #144
    Deaner
    Deaner New Member
    Dean
    The Mac
    2010 Rock Warrior
    Installed this Expedition 1 bumper over the weekend. Going to mount the spare tire this week when I get some extra time, and install some Baja squadrons for extra light. I'm pretty happy with it!
    APG likes this.
  25. Apr 21, 2025 at 1:51 PM
    #145
    kyle11863
    kyle11863 Tundra Recovery Guy
    Kyle
    Big Bear CA
    1991 Toyota Pickup
    AllPro Rock Sliders Custom Short Travel Suspension Pretty Blue Lights Terraflex Hand Throttle Front and Rear Eaton E-Lockers Revolution 4.88s LCE Street Clutch Kit Mishimoto Radiator Lasfit Led Lights Mox Motors Rox Lights VoSwitch Switch Panel Lots of mud holding it all together
    Good news people that have been waiting for it, Coastal Offroad has come out with their new high clearance rear bumpers for the 2nd and 2.5 gen Tundras. Check them out at the link below and use code SOCALTOYOTAS for 5%. Maybe we will get a group buy going for them if there is enough interest.
    2nd gen:
    https://www.coastaloffroad.com/product-page/2nd-gen-tundra-high-clearance-rear-bumper-kit/
    2.5 gen:
    https://www.coastaloffroad.com/product-page/2-5-gen-tundra-high-clearance-rear-bumper-kit/
    They also added sliders as well:
    https://www.coastaloffroad.com/prod...ickout-rock-slider-weld-together-kit-bolt-on/
    TheBeast and siznarf like this.
  26. May 10, 2025 at 8:04 PM
    #146
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
    bought one of the cheap hooka bumpers years ago. they're cheap for a reason, but it served it's purpose. now, i am looking for an actual funcitonal bumper (one where those clevis mounts can actually be used for pulling, not just for holding clevis's). can anyone verify the durability of any of the bumpers or are they all just for looks?
    i like the look of the hooke, hammerhead, and the scorpio (?) that someone posted up. i already know you can't pull squat with a hooke, but what about the scorpio? i don't want tube and i'm not cutting my bedsides for the high clearance bumpers. this is a farm truck, but in bad weather, i often have to winch and pull vehicles in my driveway let alone the county roads.
    if there's nothing like the two above that are actually functional, then i'll end up with a ranch hand bumper.
  27. May 21, 2025 at 4:12 PM
    #147
    M14 EBR
    M14 EBR Oh No, Rex Kramer!
    The original rear bumper on my 2007 didn't look so great after 3 neglectful previous owners over a 10 year period and 270,000 miles, so I replaced it with this N-FAB T07RBS-H-TX.
