  1. May 20, 2025 at 7:35 AM
    KevAlv
    KevAlv New Member
    Houston, Texas
    2021 White TRD Sport
    Heated Leather Seats Flowmaster Super 50 Dual Exhaust Tint Bed Cover Chrome Steps & Handles Under Seat Storage
    I would have definitely gone this route, I think it looks MUCH cleaner. Unfortunately, the dealer drilled a hole (brand new truck mind you) where I have it installed. This is what was previously there:
    (not my pic, but same port)
    bulldog93 and BR73 like this.
  2. May 20, 2025 at 7:44 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    :eek:
    KevAlv[QUOTED] likes this.
  3. May 20, 2025 at 8:49 AM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
  4. May 20, 2025 at 11:23 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    I saved probably 2 grand in labor by being willing to trust my very average wrenching skills.
    With the help of YouTube... New pads, rotors, transfer case fluid replacement, a minor fix to the rear passenger window bracket were all very reasonable jobs to take on provided you have basic tools.
    Henry1jg, Rakkasan, bulldog93 and 5 others like this.
  5. May 20, 2025 at 11:38 AM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    Man the 2 door XJ's are getting tough to find these days...
    I have no concrete evidence in my truck that it keeps the filter cleaner, but that's the reasoning I use for having it. I cleaned the S&B filter for the first time when I had the snorkel installed which meant it had been installed and uncleaned for 5 years. I do run S&B's pre filter wrap as well, I've cleaned that about once a year, which hasn't changed since installing the snorkel two years ago. For time basis, I bought the truck in July 2018, the S&B was the first thing I installed in August 2018, and the snorkel was installed August of 2023.
  6. May 20, 2025 at 12:12 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
  7. May 20, 2025 at 3:25 PM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Checked all the bolts. Checked upper control arm and the 2 lower bolts (221ftlbs) all where they should be. Lower control arm and tie-rod look good. Cotter pin has no signs of moving. I didn’t have extra so I didn’t really want to take them out. The back and forth clunk noise is the steering column. So the whole thing is moving. The tie rod does have a bit of grease leak. So not sure if this is serious issue I should address, or just keep an eye on it? No noise while driving and turning. Thanks @BR73 and whoever else told me to check the bolts. I can’t find your reply.
  8. May 20, 2025 at 4:08 PM
    IEsurfer
    IEsurfer New Member
    jimbo
    Socal
    2005 tundra 4x4
    what side steps are those?
  9. May 20, 2025 at 4:28 PM
    SAGE63
    San Diego County
  10. May 20, 2025 at 4:29 PM
    IEsurfer
    IEsurfer New Member
    jimbo
    Socal
    2005 tundra 4x4
    Got my sob fabrication high clearance rear bumper with dual swing outs, rear suspension is deaver u748 leaf pack on coach builder plus 3 shackles sits a bit high but expecting it to settle (leaf pack is pretty much brand new)
  11. May 20, 2025 at 6:17 PM
    Fergie
    Fergie New Member
    Travis is solid and his work is phenomenal. Got to check his build out last year and am dumbfounded by how well thought out it all was.
  12. May 20, 2025 at 7:26 PM
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    21 Platnum, also.
  13. May 20, 2025 at 7:45 PM
    ToyoMafia
    Magic carpet.
  14. May 20, 2025 at 8:03 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I haven’t really been on lately but I finally hit the first milestone. Not a single repair and only maintenance has been done. As expected from this truck though :thumbsup:
  15. May 21, 2025 at 12:23 AM
    roxysdad
    roxysdad New Member
    Gold Country, CA
    2021 DC MGM 4x4 SR5
    Added the loncky steering wheel cover and my favorite phone holder from Proclip
    steering wheel cover is fantastic and makes the wheel so much better to use - something so important because I use it every time I drive the truck!
  16. May 21, 2025 at 3:31 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles +2 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light
    Is the steering wheel cover one that has to be sewn and if so how was that process?
    ToyoMafia likes this.
  17. May 21, 2025 at 4:04 AM
    roxysdad
    roxysdad New Member
    Gold Country, CA
    2021 DC MGM 4x4 SR5
    Yes sewn, and no, Not terrible. There is a thread somewhere with more details and methods. For the most part i followed the printout from the manufacturer. It’s just a point of lining it up as best you can, then threading the needle through the sewn in loops on the cover. Tedious if you aren’t patient, but I found it fun and a little bit of “sweat equity”. The payoff if totally worth it!
  18. May 21, 2025 at 4:14 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    Did you use any of the 2-sided tape? I bought one but still haven't installed it yet
    bulldog93 likes this.
  19. May 21, 2025 at 4:19 AM
    roxysdad
    roxysdad New Member
    Gold Country, CA
    2021 DC MGM 4x4 SR5
    Not all. Just like 20 1-2 inch strips positioned throughout
    pay particular attention to where your thumbs go when driving and have tape there for sure. There’s this recess area on the wheel that needs tape at like 3 and 9 position
    also it helps to take off the two trim pieces and the airbag. Made the install way easier
    bulldog93 and BR73[QUOTED] like this.
  20. May 21, 2025 at 4:37 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    Heck yeah thanks for the info
  21. May 21, 2025 at 4:55 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Nice! Down & Up?
  22. May 21, 2025 at 5:06 AM
    ToyoMafia
    Magic carpet.
    Yes. Works great. Now I have the same trim package as a rav4.
    Only downside is it doesn’t have a safety stop built in so presumably it will crush little fingers. I did not test so I have no skin in that fight.
  23. May 21, 2025 at 5:11 AM
    KevAlv
    KevAlv New Member
    Houston, Texas
    Nice surprise when I got to work this morning.
  24. May 21, 2025 at 5:29 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    Wonder how we made it all these years without the anti-pinch on power windows? I installed the master up / down and leave the override on so I have completed control of the window operation....lol
    ToyoMafia[QUOTED] likes this.
  25. May 21, 2025 at 5:30 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Hybrid
    Henry1jg likes this.
  26. May 21, 2025 at 5:31 AM
    ToyoMafia
    Magic carpet.
    I don’t have little ones anymore. My youngest sits shotgun most the time unless momma is on board. I didn’t install the rears because I’m never back there. I think it will work just fine.
  27. May 21, 2025 at 6:07 AM
    atc250r
    atc250r New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    They're some sort of Toyota ones. I almost pulled them off yesterday but decided to get a few things done on the boat before it goes in the water since it's going to be raining the next few days. I can get you a better picture if you want.
  28. May 21, 2025 at 7:18 AM
    CO.Tundra
    CO.Tundra New Member
    Taylor
    2019 White Tundra
    Coach Builder 1” shim, +2 Shackles. 285/75r18 AT3
    Originally had some BD XL’s mounted to SDHQ brackets thought they were a little to big up on the hood. Replaced with S2’s and had the XLs sitting around, so I decided to do some surgery and whip up a quick bracket. Used a hand hack saw to trim away the blocks in the grill. I can’t say that I’ve seen this done before but I think it turned out pretty slick. Also did a little chop chop on the BM in prep for 37’s and Methods going on Friday. Don't mind the welds.....o_O
  29. May 21, 2025 at 7:22 AM
    HulkSmurf14
    2014 Tundra Limited
    Nice execution!
    CO.Tundra likes this.
  30. May 21, 2025 at 9:15 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    YESSIR! That's what we like to hear
