Keith hits a Grand Slam Home Run
Discussion in 'Dirty Deeds Industries' started by M14 EBR, May 21, 2025.
  1. May 21, 2025 at 6:23 AM
    M14 EBR
    M14 EBR [OP] Oh No, Rex Kramer!
    Several years ago I was shopping for a bolt on cat-back exhaust for my 5.7L RCSB, someone recommended Dirty Deeds. I contacted Keith and explained that I wanted the performance gains without gaining much volume. He went to work and crammed as much muffler as he could fit into a tight space.
    Because of the SOS Performance rear only leveling kit I had to cut 24" off my single factory tail pipe... this proved too much for the standard Helmholtz resonator, so Keith provided an oversized drone killing resonator.
    It sounds almost stock at idle and cruising, and it roars a lot like NASCAR when I floor it. Performance from idle to top end is improved, I could not be happier with the results.
  2. May 24, 2025 at 6:08 AM
    M14 EBR
    I am finally looking into upgrading the exhaust on my 2002 4.7L regular cab long bed using Keith's stainless 20" partial bolt on kit, and I would like to see pictures of that system installed with a focus on how the tail pipe is attached.
