General Supercharger Thread
  1. May 20, 2025 at 6:10 AM
    nags
    nags New Member
    Going on a year of waiting. Hopefully they get it done. I was told the front drive shafts were not passing QC and they were re-making them and then going to test again.
    Hawk373[QUOTED], Mdl and reywcms like this.
  2. May 20, 2025 at 6:50 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    What’s the upside of waiting a year for them? I know of 2 members here that had to ship their blowers back for repair after like a year.
  3. May 20, 2025 at 6:51 AM
    nags
    nags New Member
    It's a friend that ordered it and specifically wanted the Whipple. Now that we know he's going to be upgraded to the new/larger model at no charge... He's waiting.
    Mdl likes this.
  4. May 20, 2025 at 6:52 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Whipple people are such fanboys :rofl:;)
    j_supra, Mdl, WinterWarlock21 and 7 others like this.
  5. May 20, 2025 at 6:58 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    :stirthepot::rofl:
  6. May 20, 2025 at 9:04 AM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Wasn't Whipple the name of the guy in the Charmin toilet paper commercial?
    Mdl likes this.
  7. May 20, 2025 at 9:22 AM
    AZTundra
    Paul
    Phoenix, AZ
    Question for the group. So I installed the RCF throttle body on Sunday with the prospeed adapter. Started the truck and it idled fine and sounded normal. Today was the first drive after it was installed. I am getting a whistling sound that starts around 2k rpms, but seems to go away under or above that mark. I highly doubt there is a gap or anything where the air tube connects to the airbox or throttle body based on how tight it was to get on. Does anyone else have this? Maybe it’s just from sucking more air in through the aem filter producing the whistle and nothing to worry about or cause for concern. I did have a similar whistle before this, but only when the engine was cold and you were giving it very light throttle when taking off, once the engine was warmed it went away. The prior whistle was more subtle. Is there anything I should be concerned about here or am I just worrying about nothing? Guess I could try swapping filters and see if that changes anything.
    Mdl and HulkSmurf14 like this.
  8. May 20, 2025 at 9:31 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    The whistle sound is more due to the TRD accelerator and SABM in the airbox...I too have it...almost like a turbo whistle under 3k RPMs...totally normal; you're just breathing so much easier now.
  9. May 20, 2025 at 9:37 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Tripleconpanna, bflooks, Mdl and 3 others like this.
  10. May 20, 2025 at 9:38 AM
    HulkSmurf14
    2014 Tundra Limited
    Woowooooo! Only for decoration!
  11. May 20, 2025 at 9:40 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    It's normal, like @HulkSmurf14 said, as you increase the air that gets in, you also increase the noise. My wife's Sequoia does it with the TRD intake and airflow accelerator.
    Mdl, AZTundra[QUOTED] and HulkSmurf14 like this.
  12. May 20, 2025 at 9:43 AM
    AZTundra
    Paul
    Phoenix, AZ
    Thanks for the confirmation. I did the accelerator, but have not installed the SABM yet. Sounds like that may amplify it a bit more. Good to know. I feel like I know every inch of the truck and the sounds it makes so anytime something changes I start to wonder.
  13. May 20, 2025 at 9:56 AM
    Silver17
    Eastern PA
    What you’re hearing is the manufacturing of raw Japanese-American horsepowers.
  14. May 20, 2025 at 11:12 AM
    snivilous
    SW UT
    There's a LOT that goes into the aerodynamics of the intake system. The throttle body I've been developing has a very nasty (to me) whistle which is high on the priority list to sort out. Flip side is, different intake configurations (even as simple as how far is the intake tube from the throttle body inside of the rubber coupler) can completely change the noise. OEMs spend a lot of effort to eliminate intake noise which is why you often see weird things like boxes that plug into the intake or odd features---and which explains why an aftermarket intake can make the sound of the truck drastically different.
    Good chance you could change a number of components and it would eliminate or change the noise.
  15. May 20, 2025 at 11:21 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Lucky me, no noise lol
  16. May 20, 2025 at 11:27 AM
    bflooks
    bflooks New Member
    Metrowest MA
  17. May 20, 2025 at 11:30 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Ya’ll need louder exhausts or louder shocks lol
  18. May 20, 2025 at 12:03 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I didn't notice a whistle when I had it on. Could be the configuration I have as you said.
    Side note: throttle body blades arrive this afternoon. Will go over them this evening.
    :fingerscrossed:
  19. May 20, 2025 at 12:23 PM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Tripleconpanna likes this.
  20. May 20, 2025 at 12:31 PM
    snivilous
    SW UT
    That's good to know, mine was insanely loud, then took my single tube with long couplers and welded a new tube with some angle to it and shorter couplers and it cut the whistle down 50% but still noticeable.
    HulkSmurf14, AZTundra and Mdl[QUOTED] like this.
  21. May 20, 2025 at 2:59 PM
    AZTundra
    Paul
    Phoenix, AZ
    Stopped by DynoComp on my way home from work today. They got me down for a tune revision on June 4th. Just want to ensure no tweaks are needed. Curious to see what improvements there are with the throttle body. I’ll keep you all posted after the session.
  22. May 20, 2025 at 9:50 PM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub,
    I assume the stock steel mesh throttle body gasket isn't used with the SC? I thought I read that can contribute to throttle whistling.
    Mdl likes this.
  23. May 20, 2025 at 10:50 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Most just get rid of it.
    mustang67408 and HulkSmurf14 like this.
