PSA Trans Fluid Level
Discussion in '2.5 Gen Tundras (2014-2021)' started by DCRB4X4, May 19, 2025.
  1. May 19, 2025 at 4:30 AM
    DCRB4X4
    DCRB4X4 [OP] New Member
    BLACK 2015 DCRB SR5 4X4
    5100's front, spacer rear
    If you have a Tundra that you are not 100% sure of the trans fluid level, check it!
    Drain and fill this weekend and mine was 1.5 Qts low.
    Plenty of info on the web.
    I put it off too long after buying a used truck.
  2. May 19, 2025 at 4:51 PM
    SoTexTundra
    SoTexTundra New Member
    19 DC TRD OFF-ROAD
    I have a thread just above yours where i did my first drain and fill after cooler install and flush and I only drained out 3 quarts
  3. May 19, 2025 at 5:55 PM
    Mr Badwrench
    Mr Badwrench New Member
    I've read, only read, that the Tacomas were being delivered with low trans fluid in 2016. If it is true, it is probably not just the Tacomas. I hope I haven't been driving with a low fluid level. I sure haven't checked.
    Was it 1.5 quarts or pints? You did say quarts, I am hoping you meant pints.
  4. May 20, 2025 at 10:02 AM
    DCRB4X4
    Nope,
    1.5 qts
