  1. May 10, 2025 at 3:20 PM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    Today's mission:
    Wish me luck! Lol
  2. May 10, 2025 at 7:47 PM
    TheBeast
    TheBeast The Beach
    I have the same rotors. been good to me for the past 6 years
    OldGuy03 and Thumper_6119 like this.
  3. May 10, 2025 at 9:29 PM
    Thumper_6119
    All done. Got the pads and rotors changed out and the system bled. I'll bed them tomorrow.
    Got rained on twice, so I had to pause work a couple of times.
  4. May 11, 2025 at 1:35 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Rock warrior wheels
    295/70/17 NRG
  5. May 12, 2025 at 7:59 AM
    Shanet421
    San Diego,CA
  6. May 14, 2025 at 4:03 PM
    Je-fa-fa
    Je-fa-fa New Member
    Wednesday
    Jeff
    2013 Black Tundra RW Crewmax
    Replaced A/C system. (Compressor, condenser, trans cooler). $4,600.00. She's worth it though.
  7. May 14, 2025 at 4:07 PM
    zeekevin
    zeekevin New Member
    Holy cow that’s a lot
    OldGuy03 and Je-fa-fa[QUOTED] like this.
  8. May 14, 2025 at 7:40 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    yep, the condenser with built in tranny cooler is insanely expensive, probably half that labor bill (plus checking the level of the tranny)
    OldGuy03 likes this.
  9. May 14, 2025 at 7:47 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    Cleaned my TRD intake filter.
    Getting ready to pull the trigger on king front suspension….i already got the rears sitting in my garage.
    joseph_womack, TheBeast and OldGuy03 like this.
  10. May 15, 2025 at 5:44 AM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    I recharged my 13.5 yr old AC system over the last weekend. I used that AC Pro stuff and it couldn't have been easier. My AC was still working but just not as cold as it had been. Followed the video instructions and it couldn't have been easier. It takes less than 10 minutes. Just be sure to not over charge the system.....
    Thumper_6119 likes this.
  11. May 15, 2025 at 6:17 AM
    Thumper_6119
    I use AC Pro. Love it! It is sooo easy to use.
  12. May 15, 2025 at 9:22 AM
    bickz
    bickz New Member
    2017 Tundra Trd Pro
    Buddy of mine just picked up a super clean 2nd gen but it did come with a drop bracket lift. How can I tell if the cross member has been cut or not? He wants to remove it and put stock height suspension back on.
  13. May 15, 2025 at 9:56 AM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    I am not an expert on drop bracket lifts but in my quick google session it is the rear cross-member that mounts the LCA that needs to be cut for 4x4 trucks to remount the diff lower on the truck. I don't see CV axels in that picture so I don't think your buddies truck is 4x4 so it is not clear to me if it is required to cut the cross member on 2wd trucks.
    Red box is what is being cut in the video and the the one above the dudes head is the one I can see in your picture.
    My reference is this install video of a similar drop bracket lift... no personal knowledge here best advice would be have someone crawl under there and verify.
    https://www.youtube.com/watch?v=QSkqLZV3jwE
    Wynnded likes this.
  14. May 15, 2025 at 10:03 AM
    bickz
    bickz New Member
    2017 Tundra Trd Pro
    Appreciate the insight. Yes the truck is 2wd with a massive pro comp lift and fuel rims. It looks like a truck out of a 2010 wheel magazine. I told my buddy he just needs a monster energy sticker on his windows now lol. But in reality it’s a limited with the western interior and 80k miles so it’s a gem.
  15. May 15, 2025 at 11:45 AM
    rphass17
    rphass17 New Member
  16. May 15, 2025 at 4:48 PM
    zeekevin
    zeekevin New Member
    He could always remove the kit and find a used crossmember cut and have it welded back in. A few people I know went that route
  17. May 16, 2025 at 10:19 AM
    joseph_womack
    Joe
    Louisiana
    Yeah or just make one
  18. May 16, 2025 at 12:24 PM
    rphass17
    rphass17 New Member
    What is the fix for faded mirror plastic?
  19. May 16, 2025 at 12:56 PM
    joseph_womack
    Joe
    Louisiana
    like black plastic? There isn't really a permanent fix, you could either take a blow torch and heat it up real quick and it will restore the black (but doesn't last) or you could get a kit from like Cerekote or others and see how long that lasts
    rphass17[QUOTED] likes this.
  20. May 17, 2025 at 3:09 PM
    Bigblueintahoe
    Bigblueintahoe New Member
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    Nearing the 1 year mark of ownership. 10k miles down hopefully many more to go.
  21. May 17, 2025 at 3:11 PM
    Bigblueintahoe
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    And added the lasfit bed liner
  22. May 17, 2025 at 5:45 PM
    joseph_womack
    Joe
    Louisiana
    That looks slick with the spray in bed liner
  23. May 17, 2025 at 8:23 PM
    Bigblueintahoe
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    Thanks man!
    joseph_womack[QUOTED] likes this.
  24. May 17, 2025 at 9:36 PM
    joseph_womack
    Joe
    Louisiana
    also youre just breaking it in lol :burnrubber:
  25. May 18, 2025 at 7:35 AM
    Bigblueintahoe
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    lol I hope so! Took a while to find a one owner (before me) with low miles
  26. May 18, 2025 at 3:13 PM
    Thumper_6119
    I installed a Rockford Fosgate P300-8P 8" powered subwoofer today. New experience for me as I have not done anything like that yet.
    The remote gain control is dangling for a couple of days until the replacement compartment is delivered. The previous owner had a Pod trailer brake controller in that space and apparently disposed of the old compartment.
    That thing hasn't worked since I bought the truck, and I plan on installing a Redarc to replace it.
    I haven't dialed in the sub yet, but I'll get to that this evening. I have no need or desire to make my neighbors wet the bed from 3 blocks away; I just wanted a little more bass to round out my sound system. (Currently, I have a Kenwood DNX996XR Excelon Reference HU with Memphis Audio M-Class tweeters, component 6x9's, and 6.5's). It fit my budget for what I wanted, and my expectations are on par. I'll report back with some performance results once I test it and get it dialed in for my taste.
    OldGuy03 and joseph_womack like this.
  27. May 19, 2025 at 8:41 PM
    Bigblueintahoe
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
  28. May 19, 2025 at 10:00 PM
    joseph_womack
    Joe
    Louisiana
    Do you mind showing the underside of the cap? I was wondering if my factory cap is messed up and I just haven't gone to the parts store to check
  29. May 19, 2025 at 10:03 PM
    Bigblueintahoe
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    Do you want to see my factory cap or the trd cap?
  30. May 19, 2025 at 10:05 PM
    Bigblueintahoe
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    Do you have a picture of yours? I remember what it looks like since I just installed this one
