Squirrel Emergency
Discussion in '1st Gen Tundras (2000-2006)' started by Rogue Dog, May 19, 2025 at 1:48 PM.
  1. May 19, 2025 at 1:48 PM
    Rogue Dog
    Rogue Dog [OP] New Member
    Monday
    2000 Tundra TRD
    Dear new friends,
    First post and unfortunately I have to cut right to the chase. A life may be at stake!
    There is a squirrel in my truck, and I think he’s stuck in there. I think he’s a baby and his momma abandoned him because he got stuck. For the sake of urgency, let’s assume that I’m correct that the squirrel is stuck and not just hiding. Either way he needs to come out.
    Can you guys help me figure out how I can access the area where he’s stuck? Please see the highlighted portion of the photos. I can hear him squeaking right behind the metal. When I stick my head into the cab, I hear him kind of behind the glove box, or on the inside of the front of the door frame (above the hinge, about level with the glove box/antenna).
    Sorry in advance, but I have almost no mechanical knowledge. But I have some basic tools and know how to tinker, so maybe you guys can point me in the right direction.
    Thanks and stay frosty.
    RD
  2. May 19, 2025 at 2:20 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    If Rocky the squirrel is in that area of first picture, my first thought is he possibly made inside the truck thru the duct pipe, lack of better word, that’s under the windshield cowl area passenger side. If he’s there, you’ll have to remove blower motor and hopefully he’s on top of the squirrel cage, no pun intended.
    The duct opening I'm speaking of and showing, is right under "My two suspects". In fact, if you do find you have to deal with area and take the cowl off, the "My two suspects" are places one needs to address for water leakage to the inside.
  3. May 19, 2025 at 3:11 PM
    shifty` All my rowdy friends have settled down
    You can drop the fan motor (3 x 10mm bolts) and probably reach up in. These pics I just took while cleaning out my fan motor under the glove box. The grey background in the yellow box is the cowl. Don't break the red flapper/bar in red.
  4. May 19, 2025 at 3:57 PM
    bfunke
    bfunke Tundra Curmudgeon
    Is he behind the cowl cover? Wipers, few screws and some push pin fasteners. If you remove expect some to break but also good time to waterproof cowl clips.
  5. May 19, 2025 at 5:07 PM
    Rogue Dog
    Monday
    2000 Tundra TRD
    Wow, thanks so much guys! These look like some great places to start. I’ll get my hands dirty after work and see what happens.
    BubbaW, incidentally I’m also getting the occasional drips onto the passenger floor mat, probably through the route you’re describing there. An infamous problem I guess? Maybe I can gather some intel for the dripping while I’m on the squirrel mission.
    I went home at lunch and he was still squeaking, so hopefully I’ll get there in time.
    BubbaW likes this.
  6. May 19, 2025 at 5:08 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Keep us posted plz.
  7. May 19, 2025 at 5:25 PM
    EmergencyMaximum
    EmergencyMaximum New Member
    Wait for it to die so it won't try to escape when you reach in. Remember, squirrels are just rats with furry tails.
    JasonC. and OldGuy03 like this.
  8. May 19, 2025 at 6:18 PM
    Infamous leaks are covered in great detail here, including the passenger side cowl leak: https://www.tundras.com/threads/definitive-2000-2006-cab-area-rain-water-leak-thread.70464/
  9. May 19, 2025 at 6:28 PM
    TheBeast
    TheBeast The Beach
    see if you can remove the cabin air filter and check inside the vent. easy to do before unbolting the whole truck
  10. May 19, 2025 at 6:40 PM
    Mr Badwrench
    Mr Badwrench New Member
    I don't know that the early Tundras have a cabin air filter.
    OP: wear a welding glove and safety glasses if you're going to try to pull it out alive.
  11. May 19, 2025 at 7:21 PM
    They don’t.
  12. May 19, 2025 at 7:56 PM
    SoCal_Erik
    SoCal_Erik New Member
    2023 SR5 Sport 4x4, 2016 4Runner
    Following for a good outcome.
    BlackNBlu and 14crwmaxltd like this.
  13. May 20, 2025 at 5:19 AM
    rouxster70
    rouxster70 New Member
    04ac2wdv65spd
    Yo what’s up with Pepe the squirrel??
    BlackNBlu likes this.
  14. May 20, 2025 at 6:09 AM
    TRDGoodness
    TRDGoodness Not new, but not old either
    East Coast
    Ram 2500 Tradesman 6.4L gas; ZF 8 spd Transmission
    I had the chance to grab a squirrel running across the ground. It was pretty cool to hold, but, OP, this is good advice. Their teeth are sharp for sure.
    Smart critters though. Pretty amazing when to observe. Watch Mark Rober's YT channel with his Squirrel Maze 1.0 and 2.0. Very entertaining.
  15. May 20, 2025 at 7:32 AM
    Mr Badwrench
    I got bit while at the Grand Canyon :D Everyone laughed at me and I had to pay to get my blood, a lot of it, cleaned out of the rental car.
    TRDGoodness[QUOTED] and OldGuy03 like this.
  16. May 20, 2025 at 8:43 AM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    I was bitten by a rat once, when I was in my early 20's. I ended up with severe blood poisoning that required a course of very powerful antibiotics to reverse. All good in the end and I made a full recovery with no time in the hospital even though I was advised I should go. But being bulletproof and that I had a hot date the next day I just sucked it up. Do be careful with the little critter.
  17. May 20, 2025 at 9:27 AM
    TRDGoodness
    East Coast
    :D Where did it get you? Mine was on the thumb and index.
    When I let mine go, it ran down the yard a ways, stopped, turned around and if it could scream and yell at me, that was what it was doing in its chittery voice! LOL!
  18. May 20, 2025 at 9:28 AM
    TRDGoodness
    East Coast
    Yeah, rats and mice are not to be played with. That one always bothers me because there are a lot near where I live.
    Squirrels are a little cleaner. Still had to get an antibiotic, but not as bad as rats. Glad you didn't have any bad after affects.
    Tripleconpanna likes this.
  19. May 20, 2025 at 12:26 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L “Best Cab”/AC Limited 52k mi
    RIP, OP. We done tolt you to wear gloves. Also if OP's wife reads this, we have a very strict classifieds policy, after you get OP's blood out of the interior don't just go posting the truck for sale on this thread.
  20. May 20, 2025 at 12:34 PM
    TRDGoodness
    East Coast
    Well, that was a drastic turn! :rofl:
  21. May 20, 2025 at 12:57 PM
    EmergencyMaximum
    He was plenty warned.
    #1499, so close to the great 1500!
  22. May 20, 2025 at 1:07 PM
  23. May 20, 2025 at 2:18 PM
    bfunke
  24. May 20, 2025 at 2:19 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Let the little baby out….
    Tripleconpanna and ColoradoTJ like this.
  25. May 20, 2025 at 3:56 PM
    chunk
    chunk New Member
  26. May 20, 2025 at 4:40 PM
    Mr Badwrench
    Right on the forearm, of all places. I was bleeding like a stuck pig and it was 110 degrees out. It was miserable. I was going to sit down on a rock and it got me, wasn't even trying to feed it lol. Damned thing!
  27. May 20, 2025 at 5:18 PM
    When one gets bit by a squirrel, what's the treatment? Does that require a rabies shot?
  28. May 20, 2025 at 5:29 PM
    TRDGoodness
    East Coast
    Ouch! That sounds miserable! The forearm is also not the hardest part of the arm.
  29. May 20, 2025 at 5:32 PM
    Could be worse. Could’ve bit your 3rd leg instead of your 4 arm.
  30. May 20, 2025 at 5:33 PM
    TRDGoodness
    East Coast
    I LOVE that song! I didn't think of that quicker! LOL!
    No, when I went in to the urgent care (all I could get at the time), they said that squirrels very, very rarely carry rabies. It isn't that they can't but usually if they get bit by something that has rabies, the attack is so bad that the squirrel is dead in just a few minutes to an hour or so.
    The dr said he didn't remember ever seeing rabies from squirrel to human.
    Of course, the funny part of this is:
    When I came back home, and was walking around the property, I saw what looked like that squirrel. Dead. Laying by one of the buildings.
    I started panicking and wondering if I should go with it. Come to find out, it wasn't that one because it was too big. I know because I saw the one that bit me as it ran next to the dead one. :D
