Beatsonic thoughts?
Discussion in 'Audio & Video' started by DaHawaiian, May 15, 2025.
  1. May 15, 2025 at 10:51 AM
    DaHawaiian
    DaHawaiian [OP] New Member
    3rd Gen TRD Pro
    Leveled, 35” tires, retractable tonneau, bed platform rack, TRD cold intake
    For a minor upgrade, anyone against the Beatsonic for the 3rd Gen with the JBL system?
  2. May 15, 2025 at 10:53 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Awesome bang for the buck, if youre expectations are realistic. This will give you a nice, all around, bump in sound but it is not a replacement for a full audio upgrade. I've had mine since it came out and its awesome
  3. May 15, 2025 at 10:55 AM
    DaHawaiian
    3rd Gen TRD Pro
    Thank you! Have you added any other equipment to the system?
  4. May 15, 2025 at 11:06 AM
    eddiefromcali
    Eddie
    100% Stock
    yeah, the "add a sub" kit from taco tunes. Running dual 10" subs on 1500w
    SilveradoSwap likes this.
  5. May 15, 2025 at 11:21 AM
    Wtundra2023
    Wtundra2023 Bad Weld Aficionado
    2023 Limited Tundra, 2014 Limited Sequoia
    If you are not planning on upgrading the other speakers in the system, its a pretty nice upgrade. If you are planning on upgrading the rest of the speakers, it can be a bit frustrating to re-balance them. The beatsonic is setup to work with the sensitivity levels and frequency responses of the existing system, if you upgrade the stock speakers you may run into an issue where find some of the speakers (tweeters mostly) are over driven and have to find ways to attenuate their volume separately.
    Kerplunk likes this.
  6. May 15, 2025 at 12:35 PM
    DaHawaiian
    3rd Gen TRD Pro
    What about just replacing the stock sub that truly does nothing anyways? Or are you just referring to the highs and mids?
  7. May 15, 2025 at 12:42 PM
    Wtundra2023
    Highs and mids. The stock sub is more or less unaffected.
  8. May 19, 2025 at 10:34 AM
    Derfla
    Derfla MUDBATH PRO
    2025 TRD PRO
    I love the Beatsonic mini amp. I took it a step further and upgraded the three dash speakers. The highs are now clearer and the fronts thump pretty damn good now. Here is the speaker comparison, it was plug and play:
    I’m satisfied with the way the system sounds with my 10” sub.
