aFe CONTROL Rear Sway Bar
Discussion in '3rd Gen Tundras (2022+)' started by Toyota559, May 30, 2023.
  1. Mar 25, 2025 at 6:27 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I've used Whiteline before...decent stuff. I actually scored an AFE for $200 :bananadance:
    Soupbean77 and Kap1 like this.
  2. Mar 25, 2025 at 11:05 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    How? It's like double on their website!
  3. Mar 25, 2025 at 11:40 AM
    eddiefromcali
    Eddie
    100% Stock
    Mustve fallen off the truck
  4. Mar 25, 2025 at 6:01 PM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    And increase oversteer….
  5. Apr 4, 2025 at 12:37 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Hi All - so i got the AFE rear sway bar installed. I'm thinking of getting it moved from soft setting to medium or firm - to try and see if results will be different or better.
    The rear sway bar is attached to OEM end links. My truck only has about 1 inch lift in the back, and i'm not doing any off-roading.
    Is there any reason for me to upgrade my OEM rear end links to these?
    My guess is that if i set the rear sway bar to firm setting, my OEM end links will fail eventually or wont be able to handle it? And i need these beefier ones form Core 4x4?
    Tundra Texan likes this.
  6. Apr 4, 2025 at 6:03 AM
    David713
    David713 New Member
    2023 Tundra Platinum
    King shocks, TRD UCAs, Hellwig rear bar, 295/60-20 tires on 20x9 Sparcos
    I have my rear Helwig bar set full stiff. I drive it pretty hard and the setting works best for me. Not sure why all the concern about the stock rear end links since aftermarket rear bars are still smaller than the front sway bar and it uses similar links.
    Kap1 likes this.
  7. May 18, 2025 at 10:16 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    An update, had shop move the end links on my rear AFE bar to stuffest setting and it's ok so far. Turns well
  8. May 19, 2025 at 4:02 AM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Yeah....I really dont see the benefit of switching from the factory sway bar.
    Normally in a truck that you take off road you're looking for more independant suspension not less.
    They used to make sway bar disconnects. They may still make them but I dont have an interest in them. I didnt buy my truck with the intention to offroad it.
    Just pull a couple pins and tie back the sway bar and you get true independent suspension.
  9. May 19, 2025 at 8:13 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    To each their own.
    I don't off-road my truck. I drive city streets and highway, so improving handling and reducing body lean was my goal
    Tundra Texan[QUOTED] likes this.
  10. May 19, 2025 at 8:20 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    I agree with the not off roading the Tundra.
    It's just way to heavy and big for any kind of real off roading.
  11. May 19, 2025 at 9:58 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Interesting.
    There was no such thing as an adjustable sway bar back in my hardcore wheeling days.
    I can definitely see the advantage of a system like that.
  12. May 19, 2025 at 10:05 AM
    MRweeka
    MRweeka Validator
    Savvon
    Atlanta, Georgia
    2023 Tundra
    SDHQ Mounts Rough country Seats
    A rear sway bar that is more stiff than OEM will reduce understeer.
  13. May 19, 2025 at 10:08 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Which of course is more of an issue on the street.
