  1. May 18, 2025 at 5:35 PM
    AZTundra
    Paul
    Phoenix, AZ
    Installed the RCF throttle body from @armyoffoo this afternoon and threw on the TRD air flow accelerator while I was at it. You guys weren’t kidding about a tight fit with the magnuson air tube, what a pain to wrestle that onto the larger throttle body. I ended up using a little dawn dish soap for lubricant which helped, but still had to fight with it going on.
  2. May 18, 2025 at 6:15 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    :101010:
    BR73 likes this.
  3. May 18, 2025 at 6:24 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Not in the 2014-2017…maybe not 18 and 19 either (can’t recall when they added it exactly).
    ToyoMafia, BR73 and TacomaTRD4x402 like this.
  4. May 18, 2025 at 6:25 PM
    2020 I believe. I have it in mine.
    HulkSmurf14, Tripleconpanna and ATV25 like this.
  5. May 18, 2025 at 6:25 PM
    TacomaTRD4x402
    Southern California
    My '18 has it
  6. May 18, 2025 at 6:26 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    My 2020 SR5 has it
    Rakkasan likes this.
  7. May 18, 2025 at 6:27 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Ok, then it was part of the TSS additions (which included a LOT of new electronics) in 2018
  8. May 18, 2025 at 6:33 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Can confirm. It’s a 2018+ deal with the TSS front camera.
  9. May 18, 2025 at 6:35 PM
    Took it for the first drive and put about 20 miles on them. What a difference! When I went from a spacer lift to Toytecs, it was a night and day difference. Going from the Toytecs to the Bilsteins was like leaving a spacer kit again, but a whole lot better. These Bilsteins are a true "You get what you pay for" and Toytecs are no comparison to these. When Colton recommends a product, he knows what he's talking about. I felt a difference just backing out of the driveway. I could not be happier with this setup! @memario1214 @reywcms @HulkSmurf14 @Vendeta2k @TwistedTad @RainMan_PNW @Dr3wski @Dave8699
    Nbab23, OHwendTrd, Bowzer and 18 others like this.
  10. May 18, 2025 at 7:12 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Lol that's rad! Nice work knocking the install out and keep using them so they're broken in and settled! Purpose built stuff is absolutely amazing!
    Tripleconpanna and BR73 like this.
  11. May 18, 2025 at 7:59 PM
    Red-Barn
    Red-Barn New Member
    2016 SR5 DC TRD Off-Road
    OK thank you. Has anyone sorted out how to retro fit sensor and whatever else would be required?
  12. May 19, 2025 at 3:17 AM
    Bergy24
    Bergy24 New Member
    I keep putting off getting this. This would make it so much easier when the plate needs to be removed and installed. Were you able to leave the plate on when you swapped the hardware?
    BR73[QUOTED] likes this.
  13. May 19, 2025 at 3:52 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Yes I just installed the plate on the rear of the skid plate and that dang 5mm hex bolt in the center with the skid in place.I had stripped the 5mm hex when installing and knew I better swap it while I was changing the oil. Also put a wrench on the rest of the bolts to check for tightness and they were somewhat loose.:)
    Bergy24[QUOTED] likes this.
  14. May 19, 2025 at 5:01 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    I could be wrong but it sounded like @armyoffoo stripped the transmission level check bolt and @HulkSmurf14 you are referring to the front differential fill and drain bolts.
    HulkSmurf14[QUOTED] likes this.
  15. May 19, 2025 at 6:02 AM
    RainMan_PNW
    Casey
    Clark County, WA
    You would need the windshield camera, and I can only guess a new ECU, new CANBUS system, new instrument cluster and then all the new wires, wiring, and sensors that are associated with the 2018-2021 trucks that integrate with the newer ECU and CANBUS.
    The addition of TSS in 2018 competely changed a significant amount of the electrical systems.
    HulkSmurf14 and RobertD like this.
  16. May 19, 2025 at 6:08 AM
    HulkSmurf14
    2014 Tundra Limited
    Oh crap!! You're right! I had one thing in my mind but was reachung for the thing next to it...disregard for transmission, but it's still a better option for transfercase plug hardware...argh! I apologize! I k ow there's an Aussie group that has hex plugs available...I'll try to locate them...good catch!
    Gaston[QUOTED] and armyoffoo like this.
  17. May 19, 2025 at 7:13 AM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    Thank You.
    I should have did the same
  18. May 19, 2025 at 7:36 AM
    Red-Barn
    Red-Barn New Member
    OK thank you. I knew I should have searched harder for a 2021 before settling on a 2016. Obviously not a doable mod.
    BR73 likes this.
  19. May 19, 2025 at 7:39 AM
    RobertD
    Robert
    DFW, Texas
    Other option is to upgrade your headlights to the Pro LED headlights from Toyota and get the iHacker harness (search iHacker on the forum if you haven't stumbled across it yet). These leds are a massive improvement over stock just in normal low beam mode. You might find you don't need the auto high beams.
    Guess my 2018 may have this option but I have not felt like I need more light especially in areas where I'd be concerned about oncoming vehicles.
    Tundrastruck91 likes this.
  20. May 19, 2025 at 7:49 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Yeah
    I don’t know many people that use the auto high beam (myself included).
    Out on long straight stretches of highway they do “ok”
    But the the hills and woods and curvy country roads I spend most of my time on they don’t decide to flip until it’s too late.
    BR73 and RobertD[QUOTED] like this.
  21. May 19, 2025 at 8:07 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Nothing crazy, just a tire rotation yesterday. BUT, I plan on dropping off my second hand Icons for a rebuild and respring this week and just placed an order for new rear shocks to match! With baby number two coming in a month, the wife and I agreed that making the truck ride a little better would be a good use of money.
  22. May 19, 2025 at 8:13 AM
    KevAlv
    KevAlv New Member
    Houston, Texas
    2021 White TRD Sport
    Heated Leather Seats Flowmaster Super 50 Dual Exhaust Tint Bed Cover Chrome Steps & Handles Under Seat Storage
    Finally got the dual USB C in the mail. Installed it immediately in about 5 minutes. Glad I have modern connections now.
    Also, upgraded the dual USB A ports installed by the dealer on the back of the center console to this.
    I have both dual USB A ports if anyone is interested.
  23. May 19, 2025 at 9:20 AM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    All Toyotas had it in 2018, not just the Tundras.
  24. May 19, 2025 at 11:51 AM
    Bigdave120
    Bigdave120 New Member
    2020 Tundra TRD Sport
    I finally was able to get my new switch panel installed. I ended up sanding it down and repainting it to match a little better. I got rid of the cigarette light plug that was never going to be used and gained 2 switch spots for the seat heaters. Corey over at Black Cat Works did a great job with the panel.
    SOL, Jego, Boneskull420 and 11 others like this.
  25. May 19, 2025 at 11:53 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Welcome to the forum.
  26. May 19, 2025 at 11:55 AM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    Went to Overland Expo West and got to do some camping and light wheeling. Felt good. Truck was flawless. Even got 16mpg on the way home.
    GAknight, OHwendTrd, Fergie and 13 others like this.
  27. May 19, 2025 at 2:22 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    18 is when it was added with TSS
  28. May 19, 2025 at 2:24 PM
    ToyoMafia
    Magic carpet.
    Spod is Done! iCOM is pre wired and should be pretty easy to get in. IMG_0489.jpg IMG_0499.jpg
    Yota303, JCBerb, Jego and 14 others like this.
  29. May 19, 2025 at 2:29 PM
    Rakkasan
    Rakkasan New Member
    NorCal
    2020 Tundra- cement-crew max 4x4
    Spray in Bed liner, 2-10”subs/400w.amp, tailgate shock, Tinted windows, seat covers, dash cover, CatShield, Fuel D538 20”wheels, Husky custom floor mats, TSC tool chest, leather seat covers. Genuine Cooling systems transmission cooler, scan gauge OBD2
  30. May 19, 2025 at 2:32 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    BR73 likes this.
