Not showing Temperature on consul on start up.
Discussion in '3rd Gen Tundras (2022+)' started by R100rs, Apr 17, 2025.
  1. Apr 17, 2025 at 10:45 AM
    R100rs
    R100rs [OP] New Member
    2022 sr5 off road
    For the last two weeks or so when I start my 2022 SR5 the temperature does not light up on the consul. The only thing that light up is Auto (which is the setting I have always left it at). If I try to turn on the AC or windshield defrost nothing happens. After about 30 seconds to a minute the set temp comes on and then the AC or windshield defrost becomes functional if selected. Anyone else had this problem? thanks
  2. May 18, 2025 at 6:22 AM
    riironman
    riironman New Member
    2024 blueprint platinum hybrid
    Mine is doing the same thing and it's stuck on defrost. I just hit 36000 miles...this is going to cost me if they have to rip my dash apart
  3. May 18, 2025 at 4:51 PM
    sudobash
    sudobash New Member
    This seems to be an issue across multiple years and multiple trims, both i-FORCE & i-FORCE MAX. Several Sequoia owners are also complaining about this issue. Hopefully it's an easy fix and/or a LSC/SSC is issued for it.
  4. May 18, 2025 at 4:55 PM
    riironman
    Hopefully.... i can't find a way to reset the system either
  5. May 18, 2025 at 5:17 PM
    sudobash
    sudobash New Member
    Do not reset anything. Take it to the dealer so they can diagnose and get information to Toyota. Being that this appears to be a more widespread issue, the more data Toyota has, the better.
  6. May 18, 2025 at 5:41 PM
    riironman
    I get that problem is...out of warranty. Just hit 36.5k
    sudobash[QUOTED] likes this.
  7. May 18, 2025 at 5:45 PM
    sudobash
    sudobash New Member
    They can still troubleshoot and get data to Toyota. It could end up being a more prominent issue that needs to a recall or LSC/SSC.
    Tundrastruck91 likes this.
