Factory AUX Switches
Discussion in '3rd Gen Tundras (2022+)' started by LB-1889, May 16, 2025.
  1. May 16, 2025 at 6:47 AM
    LB-1889
    LB-1889 [OP] New Member
    ETA: Understood that there are aftermarket options for switches, this post is for the factory switches.
    Found this over on a Tacoma forum. I have two open spots that I would like to fill and am wondering if anyone are running these.
    Questions...
    1. Are these self latching?
    2. Are there issues installing these in existing openings? Possibles keyed for a specific opening, might be able to be modified.
    3. Wiring connector to convert to aftermarket wiring items?
    Part Number for switches...
    84485-AK010 AUX1 Switch
    84485-AK020 AUX2 Switch
    84485-AK030 AUX3 Switch
    Some AUX Wire harness part numbers out there...
    PT948-35450 AUX Wire Harness
    PT948-35402 AUX Wire Harness
    sudobash likes this.
  2. May 16, 2025 at 7:27 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Following
  3. May 16, 2025 at 7:29 AM
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    That’s my pic from this forum
  4. May 16, 2025 at 7:40 AM
    LB-1889
  5. May 16, 2025 at 7:48 AM
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    I also continue to post on TW. Yes, I’ve completed the install in my truck.
    1. Are these self latching? YES
    2. Are there issues installing these in existing openings? Possibles keyed for a specific opening, might be able to be modified. All OEM are indexed or keyed, desired opening will require minimal trimming
    3. Wiring connector to convert to aftermarket wiring items? All switches added are wired to aftermarket components
    NewImprovedRon likes this.
  6. May 16, 2025 at 7:54 AM
    LB-1889
    What harness did you use for the to go from the switch to the aftermarket item?
  7. May 16, 2025 at 7:55 AM
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    Tundra owners do not need the AUX harnesses. Only Tacomas and 4Runners with AUX switches pre installed require them.
  8. May 16, 2025 at 8:09 AM
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    This TW thread has more switch content
    https://www.tacomaworld.com/threads/unused-connectors.838194/page-5
    My build thread also has some of this info. I source Aliexpress for the connector and pins to build my own harness. They are more cost effective for the connectors than OEM part numbers.
  9. May 16, 2025 at 8:16 AM
    LB-1889
    Thanks, sorry was taking about the connector, not necessary the existing harnesses that are pre-built into the Tacoma's. Which you cleared up.
    Siblue[QUOTED] likes this.
  10. May 16, 2025 at 2:42 PM
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    FYI the part # listed in the OP are wrong, just fat fingered.
    84485-AK010
    84485-AK020
    84485-AK030
  11. May 16, 2025 at 3:05 PM
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    OP PN are correct
    Historically they began as
    84484-35010
    84484-35020
    84484-35030
    All 3 are superseded with correct PNs
    AUX4 is still showing up as 84484-AK040,but ran out of available blanks
  12. May 16, 2025 at 3:10 PM
    LionsFan20
    Josh
    24 Tundra
    The OP has them listed as 88485-AK010....and so on
    Siblue likes this.
  13. May 16, 2025 at 3:11 PM
    LB-1889
    I corrected them in the original post, thanks.
  14. May 17, 2025 at 9:18 AM
    Hammertimerrrr
    Hammertimerrrr New Member
    2024 MGM Limited OR
    Thanks for the info, this is a project I need to tackle. At a minimum I’d like to put my marker lights (always on now) and WeBoost on aux switches and like to do as much OEM a possible.
  15. May 17, 2025 at 1:54 PM
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    FYI for 22-24 owners these switches illuminate white
    sudobash, Hammertimerrrr and kirkb like this.
  16. May 18, 2025 at 2:26 AM
    wing-2
    wing-2 New Member
    Nice information. Thanks.
