Elevate Racks with Bakflip MX-4
Discussion in 'Tonneau Covers, Caps and Shells' started by SD Surfer, Jan 5, 2023.
  1. Jan 31, 2025 at 8:22 AM
    #61
    tahoetund
    tahoetund New Member
    2024 Platinum iForce Max, Lunar
    Medium and high height allow me to open cover, low just barely blocks. All heights still have perfect camera vis.
  2. Jan 31, 2025 at 8:35 AM
    #62
    euroshowoff
    euroshowoff New Member
    Ronnie
    2024 Limited
    perfect thanks. do you think the yakima overhaul would work on the elevate tslots? not sure if you cross shopped each.
  3. Jan 31, 2025 at 10:48 AM
    #63
    biebs96
    PA
    do you have a link for them?
  4. Jan 31, 2025 at 11:06 AM
    #64
    tahoetund
    I don’t think the Yakimas are T slots, but I haven’t personally had any experience
  5. Feb 16, 2025 at 3:56 PM
    #65
    Bigbadpoppa
    Bigbadpoppa New Member
    subscribing. I'm in the same boat.
    MX4 (newer version with didn't need to drop OEM rail)
    Now I'm looking for a rack, where I can still open up the tonneau cover. Quick release is ideal, since I won't be running the rack unless i'm camping or hauling bicycles. Has anyone done this with the Rhino setup? That intrigued me cause of the quick release, even though it runs low, if it means i can take them off quickly, that might suffice. But i only see it on the RetraPro setups with the prebuilt slots, not for the MX4 setup?
    Elevate seems to be a strong option though too still. Has anyone installed this wit the "newer" MX4 setup 2024+ where you don't need to drop the OEM rails?
    decisions decisions...
  6. Feb 16, 2025 at 4:47 PM
    #66
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    I was between Yamuna and rhino. I like the low profile to help protect what I’ll be putting on the bars from the wind. Maybe not protect, but you know. Now I’m looking at Thule options as I get a deal on their stuff. If I end up getting annoyed with low bars I could always order the elevate rack parts later.
  7. Feb 18, 2025 at 4:14 PM
    #67
    Bigbadpoppa
    i can't seem to find a Thule option that works with the MX4, nor a Yakima (the ones they show go onto a different setup).
  8. Feb 18, 2025 at 5:46 PM
    #68
    Ipaddick
    Ipaddick New Member
    Canada
    Yeah. Doesn’t appear Thule has a quick release.
    I’ll be getting the elevate track system that works with bakflip. Then you get
    1 x Yakima SkyLine Towers (with New Covers) (Set of 4)
    1 x Yakima Inch JetStream - Black (Pair)
    1 x Yakima 4 Pack SKS Cores
    2 x Yakima Landing Pad 26 (Set of 2)
    that will work with quick release.
    MAC25Tundra likes this.
  9. Feb 19, 2025 at 9:41 AM
    #69
    Bigbadpoppa
    I didn't realize the elevate rails are universal for other brands, great to know! I might just get the rail first and slowly build it up. Handy to just have the T rails to tie things down sometimes.
  10. Feb 24, 2025 at 6:23 AM
    #70
    beer30
    beer30 New Member
    I was able to order the rails and mounting hardware individually from etrailer.com, since it was showing out of stock at Real Truck
  11. Mar 10, 2025 at 3:21 AM
    #71
    supermike
    supermike New Member
    2424 Tundra
    so does the elevate TS rails work with the 2024 newly redesigned MX4 cover? the one don't use the drop bracket? thanks...
  12. Mar 22, 2025 at 5:25 AM
    #72
    beer30
    beer30 New Member
    I'll let you know in a few weeks whenever I install.
    You still have to use the drop bracket.
    No need to buy the Toyota bracket for the rails unless you're not using the cover.
    I just wedged the elevate rails under the factory cover rails.
  13. May 17, 2025 at 8:36 AM
    #73
    BeeManChook
    BeeManChook New Member
    2025 Black Tundra SR
    Anyone using the Elevate rails under the newer OEM tonneau cover with the newer clips. still work ok?
  14. May 17, 2025 at 9:09 AM
    #74
    beer30
    beer30 New Member
    I had to remove the gasket to make them fit, which in turn allows water intrusion.
  15. May 17, 2025 at 9:32 AM
    #75
    BeeManChook
    I guess there'd be nothing stopping me using some silicone caulk?
  16. May 17, 2025 at 9:45 AM
    #76
    BeeManChook
    Did you go with the Yakima Overhaul and elevate ts? Anyone tried this and can you open the mx4 under the overhaul without removing it? Could use the elevate rack but like the 500lb rating on the overhaul...
  17. May 17, 2025 at 10:13 AM
    #77
    beer30
    beer30 New Member
    Maybe sikaflex would be better, didn't think about it honestly.
