TRD Pro Grille Letters
Discussion in '2.5 Gen Tundras (2014-2021)' started by Travo60, May 16, 2025.
  1. May 16, 2025 at 3:19 PM
    Travo60
    Travo60 [OP] New Member
    Travis
    Austin, TX
    2018 Limited CM Cement
    My “TOYOTA” letters on my OEM grille have seen better days after the Texas heat has beat them down. Anyone know of a vendor that sells the letters? Apparently they just stick on with double sided tape. Any leads are appreciated.
  2. May 16, 2025 at 4:02 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    RobertD likes this.
  3. May 16, 2025 at 4:04 PM
    biebs96
    PA
    I bought vinyl cut decals off of eBay for like $19.
    Came with two pairs. First set lasted about 3 years. Replaced with the second this past fall.
    Just a thought.. could be a cheap alternative.
    RobertD likes this.
  4. May 16, 2025 at 4:08 PM
    Travo60[QUOTED][OP] likes this.
  5. May 16, 2025 at 4:08 PM
    Travo60
    Travis
    Austin, TX
    I actually received these today in the mail, ha! They are quality, but I don’t think for this application as they require screws to secure to the grille.
  6. May 16, 2025 at 4:10 PM
    Travo60
    Travis
    Austin, TX
    I was eyeballing something similar from TVD vinyls. Do they allow for the silver to pole through from side? It looks great.
    TacomaTRD4x402 likes this.
  7. May 16, 2025 at 4:17 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    This is what those OEM letters look like removed from the grille
    I pulled mine and had them painted when I installed my grille.
    As @Tundra234 stated, they have pins that guide them into the holes, and they are stuck on with double-sided tape.
    2c403352-0d90-40e8-837b-5c0d5d74133d_49e8460ffaa67e8f8096824defb3c6d67b9bfeb4.jpgf42730ee-8395-4284-a8e9-5b6aed9daf2d_914e86ae489afa6d92fd93561bc225d02a9eebc0.jpg5f689e5a-1916-4f4b-80c9-f361baf038c3_1879076d6b941d9a2d0f310e5ec580a15b823128.jpg9bf5de74-a577-4660-950d-ca78f1918aad_cbe641ce253b2fc775bf0ecd382f85f0d7842eba.jpg
  8. May 16, 2025 at 4:23 PM
    TacomaTRD4x402
    Southern California
    Rich at TVD is great :thumbsup: His products are great quality and for sure to last a long time. He hooked me up with several decals. If you're just wanting to add vinyl over your current letters, I'd get em from TVD.
  9. May 16, 2025 at 4:42 PM
    biebs96
    PA
    So it’s funny, mine is a fake Pro grille, so all of the letters are attached to a solid oddly shaped back piece.
    I removed them, painted the whole “assembly” of letters matte black to match the grill surround. Then installed the decals.
    Travo60[QUOTED][OP] and RobertD like this.
  10. May 16, 2025 at 7:41 PM
    Travo60
    Travis
    Austin, TX
    Looks good, did you just stick them back on the tape or apply new? Maybe I just plasti dip or paint the ones I have to avoid a headache. Did you do a rattle can or something more refined?
  11. May 16, 2025 at 7:42 PM
    Travo60
    Travis
    Austin, TX
    Wow, no wonder it looks so clean
    biebs96[QUOTED] likes this.
  12. May 16, 2025 at 7:51 PM
    biebs96
    PA
    it all depends on your budget, and also what OEM color can be obtained.
    For me the $30 project was worth it.
  13. May 16, 2025 at 8:53 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    In 2015 Toyota didn't make a TRD Pro grille with a MGM surround.
    I had to buy a white one and have it painted locally.
    I pulled the insert out of the surround, flossed the letters off the insert, and had them painted too.
    946664a6-5a94-43cb-bb03-32c2b0f30c41_bb9f927d28cb5627658243fe7643b2a2f94b7ead.jpg5f689e5a-1916-4f4b-80c9-f361baf038c3_1879076d6b941d9a2d0f310e5ec580a15b823128.jpg
    I used 3m molding tape to stick them back on.
    Took a lot of tape cutting and trimming.
    It has held for 10 years.
    Amazon.com: 3M Super-Strength Molding Tape, 1/2 in x 15 ft, High Strength Double-Sided Adhesive, Permanently Attaches Side Moldings, Trim and Emblems to Interior and Exterior of Vehicles (03614) : Automotive
