  1. May 16, 2025 at 4:52 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    People don’t ever listen to me when I say 6112 is a million times better than the 5100 then they get blown away when they upgrade.
  2. May 16, 2025 at 5:05 PM
    Steve Land
    Steve Land New Member
    2006 Tundra double cab
    Does anyone know where to get a carpet kit for a 2006 double cab?
  3. May 16, 2025 at 6:17 PM
    Those old control arms look like they came off the Titanic. Yikes.
  4. May 16, 2025 at 6:30 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Don't feel bad, people dont listen to me when I say the Wheelers Offroad AAL > Icon AAL
  5. May 16, 2025 at 6:47 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Might have to go pick that one up I sent. I have the icon and I like it.
    oscardog86 likes this.
  6. May 16, 2025 at 6:51 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yeah I imagine the icon pairs well with your shocks, especially since you don't have a camper shell
    khooiii[QUOTED] likes this.
  7. May 16, 2025 at 6:57 PM
    bdbrown528
    bdbrown528 New Member
    2002 Tundra Sr5
    Swapped in a pair of CVJ axles to be done with them once and for all. Went with the "Best" option since OEM Remans aren't available anymore.
    Once they were put back on before I put the wheels on I did a spin check. The passenger was nice and smooth but the drivers required a good bit of force to turn. Both axles torqued to 174ft lbs. I thought maybe a rotor was dragging so I pulled the pads on both sides and no difference. Is that typical for the front diff to have one drag harder than the other? Or is this likely the source of my odd vibration I can't seem to find?
    bmf4069 and oscardog86 like this.
  8. May 16, 2025 at 7:14 PM
    shifty` NOT A NU JACK! NU JACK, NU JACK!
  9. May 16, 2025 at 7:15 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
  10. May 16, 2025 at 7:19 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Holy shit I think I just saw a ghost
  11. May 16, 2025 at 7:25 PM
    And I'm saying don't waste money on AAL at all. Just buy new leaf packs. I wish I had done that.
  12. May 16, 2025 at 7:29 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    BroHon and FrenchToasty like this.
  13. May 16, 2025 at 10:30 PM
    bdbrown528
    2002 Tundra Sr5
    When I loosen the axle nut to just over hand tight it spins nice and free. Anything more than that or close to torque specs and it really doesn't want to turn. I'm really hoping it's not a bad bearing... Not looking forward to doing that job.
    Updating in case anyone runs into this same issue:
    It turned out to be the dust shield that goes on the backside of the wheel hub. I thought that I had it set flush but turns out it was raised a bit at the bottom where it's tough to see by the LBJ. I pulled it out and set it back in nice and flush this time. No more binding!
  14. May 17, 2025 at 12:52 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    So are you all scrubbing and painting them not that they've stayed looking like this 20 years?!
    455h0le_dachshund likes this.
  15. May 17, 2025 at 5:03 AM
    BroHon
    BroHon What day is it?
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    Always impressed with what little effort it takes (less that 2-3 minutes) to bring them back. Factors: MI climate, low level of oxidation. Follow this up with a ceramic of your choice and your good for at least 6-8mo.
    Neo, sportbike37, bmf4069 and 12 others like this.
  16. May 17, 2025 at 5:06 AM
    In my case yes I did paint it. But it barely had any rust being in the south. It is a little worse now and needs a fresh coat. That picture is from 2019.
  17. May 17, 2025 at 5:17 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    I havent painted my trucks naughty bits yet, but i keep threatening to. Its ‘usually’ cleaner than my recent pics. Still havent washed the truck since t2s, but its been rinsed a couple times.
  18. May 17, 2025 at 5:46 AM
    Mine has never been scrubbed or painted. Some other frame porn for you….
    txagg, bmf4069, matkes77 and 10 others like this.
  19. May 17, 2025 at 6:16 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    She's a beaut Clark!
    Not an option in the Midwest to.protect from the cities "buy a new vehicle program" when they spread salt. Just another maintenance item but still better than a new car payment. Need to by a reliable bucket to drive in the winter that I don't love as much as the Tundra.
    G_unit3000 and 455h0le_dachshund like this.
  20. May 17, 2025 at 6:34 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  21. May 17, 2025 at 6:54 AM
    pirates712
    pirates712 New Member
    Rochester NY
    2000 V8 AC 4x4
    Which is correct? When in took them off they were installed with the dish facing out, but it seems like it should be the other way with a smaller gap between the washer and bushing. FSM doesn't seem to specify
  22. May 17, 2025 at 7:05 AM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
    Parts diagram shows it but FSM doesn't. Weid.
  23. May 17, 2025 at 7:13 AM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    You didn't replace axle seals did you? I'm not sure I ever tried spinning tires as a test after replacing the CVs on my Tacoma, so I'm not sure if it's normal. Haven't done it yet on the Tundra. Only reason for my question is that I just did work on the rear axle of my trailer (old Ford truckbed trailer), and I had the same issue. One side spun freely, the other side wouldn't budge an inch once the axle nuts were torqued. I have to assume it's been this way for years, but the axle seal was actually not completely seated. It stuck out enough that when torqued, the axle was right up against the metal edge of the seal, and couldn't be spun by hand, at least without the tire on giving that extra leverage. The tire would spin when I pulled the trailer with my truck, obviously, but I guess there must have been a ton of drag. With how tight those seals sit in the housing, there's no way I pulled it out when I was pulling the axle shafts, so it must have been that way before.
    G_unit3000 likes this.
  24. May 17, 2025 at 7:55 AM
    ToyotaDude
    ToyotaDude Member
    Estimated with two 20 year old vehicles as DDs have saved over $150,000 not rebuying every 7 years at inflated costs even without including costs of loans ... given a new truck is like $50,000 now and somewhere inbetween $50k and that sticker 7-10 years ago.
    oscardog86 and The Black Mamba like this.
  25. May 17, 2025 at 8:11 AM
    Jack McCarthy My work anxiety is my morning alarm clock
    If you could only buy OEM parts for a vehicle indefinitely, you’d be set for life.
  26. May 17, 2025 at 10:45 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    I don’t get it man, I live in the desert and my truck lives in the garage and my frame doesn’t even look like that.
  27. May 17, 2025 at 11:10 AM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    Looks like a replacement frame.
  28. May 17, 2025 at 11:24 AM
    At least the frames were treatable. Nowadays with thinner gauged boxed frames from bow to stern, it’s incredibly difficult to prevent rust to some degree inside the frame. All part of planned obsolescence I guess.
  29. May 17, 2025 at 11:45 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Psh! I bought new Alcan leaf packs and still had to add a leaf :rofl:
  30. May 17, 2025 at 12:31 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Doesn't look like Lamin X makes a film for 00-02 bummer. That's where I got the yellow for Elvira.
    BroHon[QUOTED] likes this.
