Front levelling kit for a 2025 Tundra 1794 TRD Off Road
Discussion in 'Suspension' started by Trapperlee, May 15, 2025.
  1. May 15, 2025 at 5:51 AM
    Trapperlee
    Trapperlee [OP] New Member
    2025 Midnight Black Tundra 1794 TRD Off Road
    I just installed my plow rigging for a 2025 Tundra 1794 TRD Off Road (7-1/2' Boss HTX V-plow). I believe that the recommendation for the plow is a 1" lift. Any recommendations for who sells a 1" front levelling kit? I am considering the Rough Country 1.75" lift (front only)? Mainly looking to just take some of the rake off the front and get close to level with the rear. I am staying with stock size tires. 95% of my driving is local and on road, the other 5% I am travelling fairly smooth dirt roads on trips to the NMW's carrying 3-400# of gear.
  2. May 15, 2025 at 9:59 AM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra LB
    None
  3. May 15, 2025 at 1:23 PM
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    Cornfed suspension sells a front 1”
  4. May 15, 2025 at 4:40 PM
    JollyRogers
    JollyRogers New Member
    South Louisiana
    2025 Lunar Rock Tundra 1794 TRD
    My plan is to do the bilstein 5100 adjustable heights
  5. May 15, 2025 at 4:43 PM
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    Fabtech 1.5”
  6. May 15, 2025 at 4:44 PM
    ToyotaBeast
    ToyotaBeast New Member
    I would recommend the Bilstein 6112 kit with a plow. That is what i run. I got a lot of sag with the plow on factory springs but not anymore.
