  1. May 14, 2025 at 7:19 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Had a semi blow a tire on the freeway this morning right next to me. The tire shot right into my passenger door. Sounded like a shotgun went off next to my ear, thought my tire exploded. My right ear was ringing for about 15min. I pulled over and the truck kept driving
    got the DOT number and license plate number going to call the trucking company tomorrow, see if they can do anything
    oscardog86, Filthyphil and Voss like this.
  2. May 14, 2025 at 7:34 PM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    Technical hit & run, file a police report. It'll provide backup when you file a claim against the trucking company.
  3. May 14, 2025 at 9:31 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Damn that’s a bummer way to start the day.
    MooreKen and oscardog86 like this.
  4. May 14, 2025 at 9:49 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Have stretched em like taco BSM about .75" with rolled edge clamps but really they are too small to stretch like those trucks. Porsche 930 boots or similar are apparently a fix as they are large enough to stretch but usually it's needed for steeper angles.
    https://www.tundras.com/posts/3451375
  5. May 14, 2025 at 10:00 PM
    ToyotaDude
    ToyotaDude Member
  6. May 14, 2025 at 10:00 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I assumed they were the same boots, just longer axles. I suppose one could always get longer boots? haha
    Either way, I'd assume the technique could still be applied
  7. May 14, 2025 at 10:05 PM
    ToyotaDude
    ToyotaDude Member
    I wish they were. Thought it was solution for my steep angles and put a little stretch on em but they still rub. After studying it a ton and speaking with folks like CVJ came up with all the info summarized here. Hoping it helps others...
    The Kartek and Allpros are bigger so can put the stretch on em.
  8. May 15, 2025 at 4:12 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I always think about this happening when I'm next to a semi for more than a few seconds. I figure it's pretty unlikely to happen but I guess it's gotta happen to someone.
    Probably couldn't hurt to do another drain and fill soon. Mine drained out exactly one gallon of fluid last time I did it. For your sake, make sure you look up the drain plug torque spec though, or whatever it was that mangled your first transmission pan. :boink:
  9. May 15, 2025 at 5:49 AM
    Kalannar97
    Kalannar97 New Member
    Michael
    Hillsboro, TN
    2003 Red Tundra SR5 2wd AC V-8 LSD ABS
    New Frame (Recall in 2019), added 17" 4-Runner Snowflake Rims
    That sucks man. I hope you can get them to pay for the repairs.
    Around here, between Nashville and Chattanooga, I swear people slow down when they pass semis on the interstate. I'll be following someone at 75-80 and they drop to almost 70 as they pass the semi. I always speed up, if I can, so I spend as little time next to them as possible. Too many times I see them just weave slightly into my lane and just a touch from them will ruin my day.
  10. May 15, 2025 at 8:24 AM
    BroHon
    BroHon What day is it?
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    First time working (truck) in the new garage, first time truck has ever even been IN a garage! Yesterday was a good day ;)
    Fixed/Adjusted my over tight parking brakes (got super hot on the trip to the new crib)
    sportbike37, NUDRAT, shifty` and 12 others like this.
  11. May 15, 2025 at 8:31 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    I dont mind a little sag.
    bmf4069, BroHon and oscardog86 like this.
  12. May 15, 2025 at 10:42 AM
    Way to trigger my PTSD.
  13. May 15, 2025 at 11:05 AM
    Kalannar97
    Michael
    Hillsboro, TN
    I'm jealous of all of these clean looking axles.
    G_unit3000, bmf4069, PNW15 and 2 others like this.
  14. May 15, 2025 at 11:26 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Update I lost a visor on the highway today LOL.
  15. May 15, 2025 at 11:40 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    So 3 out of 4 recommended?
  16. May 15, 2025 at 12:31 PM
    That's a passing score.
    bmf4069, khooiii and PNW15 like this.
  17. May 15, 2025 at 2:12 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    When we gonna do your leaf packs?
  18. May 15, 2025 at 2:18 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Feel better now?
  19. May 15, 2025 at 2:20 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    That was fast... Did you forget to clean the surface before applying the adhesive?
    I've had the stick-on visors on my Tacoma and currently on my 03. They're fine and all, but I've got the in-chanel weather tech visors on my 06 and they're pretty badass.
    G_unit3000 likes this.
  20. May 15, 2025 at 2:41 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    AVS for the win next time
    abcinv likes this.
  21. May 15, 2025 at 2:50 PM
    Kalannar97
    Michael
    Hillsboro, TN
    Still looks better than mine.
  22. May 15, 2025 at 3:11 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    No I cleaned them and applied adhesion promoter.
    The avs stick ons really aren’t any different than these except price. I figured I’d try stick on, but guess I’ll go back to in channel.
  23. May 15, 2025 at 3:14 PM
    pirates712
    pirates712 New Member
    Rochester NY
    2000 V8 AC 4x4
    After 15 years, these 5100s did not want to come out
  24. May 15, 2025 at 3:34 PM
    Dang. Report back on the 6112 upgrade!
  25. May 15, 2025 at 3:49 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Must be the stick on they use then or application. 04 Tundra been on 9 yrs and Highlander 8 yrs.
    G_unit3000 and The Black Mamba like this.
  26. May 15, 2025 at 3:50 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    They don’t make em like they used to I guess lol. I’ve had AVS on previous trucks no issues, but I’ve had a buddy lose two of his before. Oh well.
  27. May 15, 2025 at 4:32 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    I can speak to this upgrade, as I did it this winter. Maybe I can find a link, as I discussed it already somewhere..
    oscardog86 and KNABORES[QUOTED] like this.
  28. May 15, 2025 at 4:33 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Was about to do some deep cleaning with the pressure washer but it's broken apparently. I guess I'll just use the hose with the spray gun attachment.
    Did some hammering while I'm in there.
  29. May 15, 2025 at 4:44 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    oscardog86, khooiii, bmf4069 and 2 others like this.
  30. May 15, 2025 at 5:48 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    txagg, Nicklovin, G_unit3000 and 6 others like this.
