Tundra Double Cab Partial Seat Delete + Fridge Platform Build
Discussion in '2.5 Gen Tundras (2014-2021)' started by Lemonjuice, May 13, 2025 at 9:36 PM.
  1. May 13, 2025 at 9:36 PM
    Lemonjuice
    Lemonjuice [OP] New Member
    2021 Tundra TRD Pro Double Cab
    Just wanted to share a custom fridge mount I built for the rear seat area of my Tundra Double Cab. It holds my Iceco APL35 perfectly with room to spare, and the front passenger seat still fully reclines.
    This project started with one main goal: keep it clean and reversible.
    - No cutting, drilling, or permanent mods.
    - I used only factory mounting points from the original seat.
    I’ve always liked the @goosegear seat delete kits, but they don’t sell just the 40% section — you have to buy the 60% side first. I still wanted to retain two rear seats so I could carry passengers or my two dogs when camping, so Goose Gear wasn’t a viable option.
    With this setup, I can run the fridge full-time, still seat two rear passengers, or fold that side down for the dogs — super flexible without giving up space or usability.
    Mounting breakdown:
    - The rear panel is bolted to the factory car seat tether point (behind the headrest).
    - The platform base mounts directly to the OEM seat brackets — I removed the rubber pads and used 5/16” bolts in the factory holes.
    - Everything is completely reversible — no damage or permanent changes.
    - I carpeted the wood using sub box carpet for a clean, OEM-like finish.
    - I added a metal MOLLE panel (Amazon special), using 1/2” spacers to offset it from the rear panel for easy gear mounting.
    biebs96, j6y, Fergie and 2 others like this.
  2. May 13, 2025 at 9:40 PM
    Lemonjuice
    Also perfectly first a dog bed for long road trips!
  3. May 14, 2025 at 10:13 AM
    Fergie
    Fergie New Member
    Thats a damn clean build. I've considered something similar if I ever go back to a plain camper shell instead of my OVRLND.
    Do you have a specific link to that molle panel? Been wanting to add one behind the seats since doing the "fold down" mod.
    Solid work!
    Lemonjuice[OP] likes this.
  4. May 14, 2025 at 10:31 AM
    Lemonjuice
    I have a bed setup in my camper shell, which is why I needed the fridge mounted up front for easier access. Here’s a link to the panel I used—it’s originally designed for the back seat of a Ford F-150, but it’s a solid, well-built metal MOLLE panel. It is a bit pricey, so I’ll also include a similar, more budget-friendly option.
    https://www.amazon.com/dp/B0D1VGPYR3
    https://www.amazon.com/dp/B0BYJT6H4J
    j6y and Fergie like this.
  5. May 14, 2025 at 10:38 AM
    d33pt
    d33pt New Member
    I have a camper on my truck too, and it's nice to have the fridge in the cab because it's just noisy. I like what you did. I wish the 60/40 setup is in reverse because that's where my son sits. I may take out the 60 side though, because it's rare that I have someone else other than him in the back. That would make so much room back there.
  6. May 14, 2025 at 10:41 AM
    Fergie
    Fergie New Member
    Neither of my dipshit dogs would chill in the back though. The frenchie(wife's dog) rides in her lap mostly, or her own carseat/bed, and my Springer Spaniel rests with her head on the center console or watches out the window the entire ride.
    j6y and Lemonjuice[OP] like this.
  7. May 14, 2025 at 10:49 AM
    Lemonjuice
    One of mine uses it all the time, the other is too nosy looking out the window the whole time .
  8. May 14, 2025 at 10:52 AM
    Fergie
    Fergie New Member
    Did you keep the jack and tool pouch in the same spot? Still have access to it or no?
  9. May 14, 2025 at 11:24 AM
    Lemonjuice
    Yes there’s still access to the old jack and tool. I didn’t want to have to cut out the old jack mount because it’s riveted into the floor of the truck so I just left it all.
  10. May 14, 2025 at 11:43 AM
    EmergencyMaximum
    EmergencyMaximum New Member
    Why does that rear seat compartment remind me of a cargo plane! Such a good boah in the rear seat! Mine sleeps in the same bed! Looks great!
  11. May 15, 2025 at 4:21 PM
    j6y
    j6y Recovering Perfectionist
    16’ Moby Dick
    Nice work man, there aren't many double cab seat delete partial/full builds out there so its good to see.
    You've inspired me to share mine. I finished this up a few months back also with similar goals but ditched the seats for a full delete, main goal was to have loads of storage without impacting the pups headroom. I did however cut the jack holder out
    Still gotta add a molle and led strip on the underside of the overhang on the wall plus topper for the platform to make it comfy and easy to brush off
  12. May 15, 2025 at 4:45 PM
    Lemonjuice
    That’s a super clean build! I like how you implemented the sub there as well.
    j6y and EmergencyMaximum like this.
  13. May 15, 2025 at 7:59 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :101010:
    j6y[QUOTED] and EmergencyMaximum like this.
  14. May 15, 2025 at 8:06 PM
    EmergencyMaximum
    That does looks excellent! Mine's more uh, what's the word...rustic? I just took rear seat off and keep microwave and tool boxes there. Excellent area to keep everything dry if you dont haul passengers!(and besides, I can carry two up front)
    j6y likes this.
  15. May 15, 2025 at 9:49 PM
    d33pt
    d33pt New Member
    Does the bottom storage slide out like a drawer? Super clean set up.
  16. May 15, 2025 at 9:54 PM
    j6y
    16’ Moby Dick
    Thank you my friend, the sub was an experiment but it turned out pretty well and sounds great. Like your setup its all removable but just in an order and 6 bolts
    Also if you ever remove all the seats for some reason, I recommend adding sound proofing behind the rubber sound barrier, it knocks down the cab noise quite a bit.
  17. May 15, 2025 at 9:55 PM
    Lemonjuice
    Sound deadening is actually my next big project I think. Would you say just starting off with the back panel makes a big difference?
    j6y[QUOTED] likes this.
  18. May 15, 2025 at 10:00 PM
    j6y
    16’ Moby Dick
    Thanks!
    Yep, a draw on each side for quick access. The only kicker is that the draw width is limited by how thick the door card is but there isn't much you can do about that.
  19. May 15, 2025 at 10:02 PM
    d33pt
    d33pt New Member
    Right, I see what you mean. Good point. The door doesn't fully open 90 degrees. I would've built it and forgotten that and it would hit the door while opening. Measure twice cut once!
  20. May 15, 2025 at 10:10 PM
    j6y
    16’ Moby Dick
    Totally
    If you take the seats out it’s loud, sounds like a window is open! Once I added the foil matting and then closed cell over the top, then the factor plastic sheet and it cut the sound by 50-60%, then after adding the wall it was notable quieter than it was pre delete, so if you put back seats it will be even quieter.
    I’ve also done all the doors, floor and really considering the roof but I’m not that motivated to mess with the headliner atm.
  21. May 15, 2025 at 10:17 PM
    j6y
    16’ Moby Dick
    haha right! When mocking it up I was like what the hell am i going to do with a 20” wide draw but its not so bad. I considered modifying the door stops to get a full ‘open’ but instead made the top front cubbies to make up for it. Its been solid so far.
    Once i get the lighting in, probably stash an inverter behind the wall I’ll do a little write up.
