O2 sensor part number
Discussion in '1st Gen Tundras (2000-2006)' started by CC80guy, May 8, 2025.
  1. May 8, 2025 at 8:19 AM
    CC80guy
    CC80guy [OP] New Member
    Larry
    Lehighton, PA
    Bank 1 sensor 2, 2001, 4.7 V8, 4WD, AC cab, Denso part number?
  2. May 8, 2025 at 8:23 AM
    www.densoautoparts.com is your source. Bookmark it, great, easy to use part finder.
    Upstream is universal. 4WD downstream are different than 2WD. Here are the 'Direct Fit' (i.e. non-universal) part numbers. I recommend replacing in pairs, but ... you do you. Note, I believe the downstream use a basic gasket, and I don't know if the Denso part will come with it.
  3. May 8, 2025 at 8:35 AM
    CC80guy
    Larry
    Lehighton, PA
    Thanks, much appreciated.
  4. May 12, 2025 at 10:09 AM
    CC80guy
    Larry
    Lehighton, PA
    Soooooo, the Denso sensor arrived Saturday and this morning I gathered all the tools I thought I might need, laid my cardboard under the truck, flopped on the ground, crawled under the truck, turned on the shoplight and behold,,,,,,,,,,,,,,, a friggin mess!!! Wouldn't ya just love to beat on some nimrods with a 2x4!?
    KNABORES likes this.
  5. May 12, 2025 at 10:45 AM
    Obviously the person who did that didn't have any nuts. Double entendre intentional.
  6. May 12, 2025 at 10:51 AM
    Kalannar97
    Kalannar97 New Member
    Michael
    Hillsboro, TN
    2003 Red Tundra SR5 2wd AC V-8 LSD ABS
    New Frame (Recall in 2019), added 17" 4-Runner Snowflake Rims
    Looks like what I need done to both of my downstream O2 sensors. But that is an awful weld job. Pretty sure I could do a better job and I don't know how to weld.
  7. May 12, 2025 at 12:54 PM
    CC80guy
    Larry
    Lehighton, PA
    The bugger has a hex nut so I'm assuming (I know, I know) that it unscrews. IF it does unscrew, any educated guess as to what might fit? The upstream sensor?
  8. May 13, 2025 at 5:09 AM
    Kalannar97
    Michael
    Hillsboro, TN
    There are O2 Sensor sockets that you can get. There are two types, one is a socket that is slotted for the wire and the other is a open end wrench that attaches to your breaker bar. Not sure what size it is off hand.
  9. May 13, 2025 at 5:12 AM
    CC80guy
    Larry
    Lehighton, PA
    Probably wasn't clear enough. I wasn't asking what wrench fits (I have em all) but what sensor might fit.
  10. May 13, 2025 at 5:19 AM
    I'd pop that sensor out, grind the weld boogers off, and get back to the original OEM bung plate. I clearly see the studs are still there. You may need to clean the threads and get a new sensor gasket, but it'd take you back to stock.
  11. May 13, 2025 at 5:21 AM
    Kalannar97
    Michael
    Hillsboro, TN
    My bad. It looks like the upstream sensor listed above in @shifty` post listing the different O2 sensors. Is this picture of the one on the pipe off the manifold?
  12. May 13, 2025 at 6:32 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    If it’s the 22mm/7/8 in. hex nut you’re asking about, those are upstream, like big hex nut in pic below.The downstream are held in place normally with 2 nuts threaded on exhaust bolts. Appears a previous owner used upstream on downstream if I’m understanding correctly :crazy:
  13. May 13, 2025 at 6:56 AM
    CC80guy
    Larry
    Lehighton, PA
    Optical illusion, there are no studs. What you probably see are weld boogers. Am I correct that the upstream and downstream plugs are different?
  14. May 13, 2025 at 7:32 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    As I mentioned in the post just above yours, the upstream has a 22mm hex bolt like the one your showing and a downstream has 2 bolts welded in the exhaust where 2 nuts hold it on....picture was attached of upstream/downstream for your 2001.
  15. May 13, 2025 at 7:32 AM
    CC80guy
    Larry
    Lehighton, PA
    Here the bugger is; threaded like the upstream but with a plug like the downstream. And no numbers or codes of any kind stamped on it.
  16. May 13, 2025 at 7:34 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Is there a part number anywhere on that sensor ?
  17. May 13, 2025 at 7:51 AM
    CC80guy
    Larry
    Lehighton, PA
    See above.
    I found a match, Denso 234-4622. Since I'm too close to my inspection date I'm going to give it a shot and order one.
    BubbaW[QUOTED] likes this.
  18. May 14, 2025 at 9:40 AM
    CC80guy
    Larry
    Lehighton, PA
    I installed the new one today and reset the code so time will tell.
    UPDATE: Took a long drive over the mountain, shopped a couple places, hit the Diner, and dropped a return off at UPS - no CEL so looks like maybe that fixed it.
