2012 Toyota Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by ericgrimes, May 11, 2025.
  1. May 11, 2025 at 2:43 PM
    ericgrimes
    ericgrimes [OP] New Member
    2012 Tundra Double cab
    Stock
    Decided to go with 35’s instead of 33’s!! Also got new headlights, fogs and a light bar.
  2. May 11, 2025 at 2:55 PM
    Bigblueintahoe
    Bigblueintahoe New Member
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    Looks great!
    TheBeast likes this.
  3. May 12, 2025 at 10:44 AM
    minter66
    minter66 2007 TSS CrewMax
    Thats a great light bar, looks really good where you mounted it. Do you have a link and an install post by chance?
  4. May 12, 2025 at 11:11 AM
    ericgrimes
    Stock
    Hey how’s it going, for the light bar it’s a 20 inch baja design. And for mounting it above the front license plate I cut the fins to fit the light bar then secured it with nuts and bolts to the plastic. I haven’t had any issues with it and stays on there while off roading.
  5. May 12, 2025 at 7:02 PM
    mhalltnt
    mhalltnt New Member
    Where did you get the headlights?
  6. May 13, 2025 at 7:02 AM
    ericgrimes
    Stock
    I got them from alpharex headlights
  7. May 13, 2025 at 9:23 AM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    Looks great! What made you decide to go 35s instead of 33s?
  8. May 13, 2025 at 1:27 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    i can't wait to get rid of my 35s and go back to 33s
  9. May 13, 2025 at 1:40 PM
    ericgrimes
    Stock
    I like the look of 35’s more than 33’s personally it looks better
  10. May 13, 2025 at 1:59 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    well yeah but your steering components don't think so
  11. May 13, 2025 at 2:40 PM
    jalam321
    jalam321 New Member
    Just curious, why are you going from 35s back down to 33s?
  12. May 14, 2025 at 8:11 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    mpg and wear & tear. i don't need 35 toyo MTs to get where i'm going, and even though she sits in the driveway all week, the wear and tear on the steering components on an 18yo truck with 280K miles is tangible. i've always liked skinnier tires anyway. the only reason i have these 35s anyway is because i got a set of five on 17" wheels for $1500. they'll go over anything and definitely make up for not having a locker a bit, but i just don't need them. they look cool as hell, but
    MEGA VOL likes this.
