Fogs ? On lifted 25?
Discussion in '3rd Gen Tundras (2022+)' started by SC SR5, May 13, 2025.
  1. May 13, 2025 at 4:19 PM
    SC SR5
    SC SR5 [OP] New Member
    2014 SR5 CM, 2025 Lifted Platinum
    RC coilovers/level shocks , 2014 Factory lift on the 2025 Platinum
    Seems like the factory removed the fogs when they lifted it , is there a plug and play to add? , 2025 lifted PlatinumIMG_9397.jpg
  2. May 13, 2025 at 5:19 PM
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    Yes, it’s a DOT compliance thing. The wiring harness is still in the fog light spot, just ouch the ones you want and wire them up.
    DesignerPat and SC SR5[OP] like this.
  3. May 13, 2025 at 6:19 PM
    Crowmag
    Crowmag New Member
    2025 Limited TRD OR W/TRD 3" Lift
    I used the OEM ones for mine since it was purchased lifted also. Easy install, be sure to mask off the chrome/painted areas on the sides where you remove the fog light bezel. Pretty much just lift and pry and it will pop off. A little harder to put back on, you have to bow it slightly to get the lip to go under the chrome piece.
    SC SR5[OP] likes this.
  4. May 13, 2025 at 6:48 PM
    SC SR5
    I’m only seeing a plastic filler piece ?
  5. May 14, 2025 at 6:16 AM
    Reubenski
    Reubenski New Member
    2025 Limited CM, TRD Off-road package, 3" lift
    Huckwheat and SC SR5[OP] like this.
  6. May 14, 2025 at 7:10 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Safer, yes. But...
    The OEM clear fog/driving/whatever they are supposed to be lights are just short of being useless as actual supplemental light.
    IMO of course.
  7. May 14, 2025 at 7:17 AM
    SC SR5
  8. May 14, 2025 at 7:19 AM
    Reubenski
    I will defer to your experience. I've never driven with them. I ended up using a DT splitter cable to connect my aftermarket fog lights to the light bar in my grill so they all run off the same switch. And then I wired that switch to a can bus reader and use my high beam stalk to use them all at once. The DD SS6 "fog" lights work really well for wide periphery illumination. Like high-speed ditch lights. And I get the forward throw from the 20-in light bar on the grill . I don't even really have fog lights anymore.
  9. May 14, 2025 at 7:19 AM
    Huckwheat
    Huckwheat New Member
    Scott
    Adirondacks
    2025 MGM Platinum Hybrid TRD
    I really like my Rigid's.
  10. May 14, 2025 at 9:44 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I just got my DD SS6's Fogs working on my NOT TUNDRA. I got them for the Tundra but traded the truck and kept them.
    When I used them on the Tundra, I had a bit more lift in the front and heavy weight in the back so they were aimed slightly higher than original. You can adjust that angle of the beam during install so blinding oncoming traffic shouldn't be a problem.
    I like them because most of the idiots that don't see you coming and want to pull out, will see you now with these yellow lights!
    If you have the means to get the BD fogs, I think those have a better cut off for DOT.
  11. May 14, 2025 at 9:47 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    me too. i'm in a 2.5gen and the fogs were all but useless. D2's on backcountry roads > running trash fogs on city streets
    Huckwheat[QUOTED] and SC SR5[OP] like this.
  12. May 14, 2025 at 10:00 AM
    SC SR5
    Actually I’m wondering if I should get the DDSS6s in yellow/amber instead of white?
  13. May 14, 2025 at 10:07 AM
    SC SR5
    Do they make them for the
    pic ? Did you get the $690 dollar ones?
  14. May 14, 2025 at 10:14 AM
    SC SR5
    Do they make them for the 2025s their website only goes to 23
  15. May 14, 2025 at 10:26 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Mine are the amber ones. They are basically 1/3 of the Gen 3 Light bar kit that DD sells. You can get them as floods or spots or amber floods. I like the yellow as it such a different yellow to the rest of the truck. Mine is light up like a Christmas tree but most of the lights are white so these really stand out.
  16. May 14, 2025 at 11:22 AM
    cody.tx
    cody.tx New Member
    i ended up installing the BD SAE fog kit - i like it
    DesignerPat, SnowToy and Huckwheat like this.
  17. May 14, 2025 at 3:38 PM
    Huckwheat
    Scott
    Adirondacks
    Yes, I have them on my '25 Platinum with the TRD lift. I paid $464 on Amazon. The price is always in flux, I have seen them even lower. Worth every penny. I had them on my 2.5 gen Pro as well, so easy decision for me.
    Sorry, no pic. I can snap one for you if you'd like.
    MAC25Tundra likes this.
