Tow mileage abysmal
Discussion in '3rd Gen Tundras (2022+)' started by ansel123, May 13, 2025.
  1. May 13, 2025 at 9:25 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Well that escalated quickly.
  2. May 13, 2025 at 9:28 AM
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    Wait, what was OP's original question again?
    ZappBrannigan likes this.
  3. May 13, 2025 at 9:31 AM
    DRP
    DRP Old Member
    Dave
    Pretty sure it was about tire sizeo_O:thumbsup:
  4. May 13, 2025 at 9:32 AM
    BlackNBlu
    Rich
    MN
    You sure it wasn't oil related?
  5. May 13, 2025 at 9:38 AM
    JayDee
    JayDee New Member
    I towed a similar sized box across the country from Atlanta to Denver and averaged 7-8MPG in my Gen1 Tundra with 4.7L V8. Without towing it would get 13MPG city/hwy didn't matter. So, I would say your MPG was pretty dang good.
    It seems only diesel trucks get decent towing MPG.
  6. May 13, 2025 at 9:41 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    When i added my tall bed cap i dropped from 17-18 to 15-16mpg (some of that is because it sounds better, so i load the throttle a little more). Towing an 18ft lowboy & tractor (mostly under 65mph) i got 14.4mpg. Towed a 10ft popup from NM (mostly below 75mph) and got about 14mpg. I’ve gotta be off road with lots of idleing & 4low to get worse than 13.5. Stock tires & gears i was at least 2mpg better than the other tx boys to t2s.
    the truth is, if you use 100hp it costs 100hp worth of fuel. Volumetric efficiency hasnt really been an issue in 30 years, and fuel only has so much energy. A turbo engine might be able to suck out a bit more VE, but youre gonna need octane to get there. Stick a block of wood behind the gas pedal & only give yourself 100hp to play with & you’ll get better mileage.
    stage 2 driver mod requires attention and planning & makes tires & brakes last longer.
    hagrid likes this.
  7. May 13, 2025 at 10:03 AM
    Breathing Borla
    AZ
    what your towing also matters, when I bought my new trailer a year or so ago, it was so much better, not only newer better wheel bearings etc, but it also carried the boat A LOT lower then my old trailer so it tucks right down under the truck breaking the air.
    shorelandr boat trailers are awesome from what I have towed, really tow nice.
    12-13 is good MPG towing, no matter what IMO.
    GODZILLA likes this.
  8. May 13, 2025 at 10:10 AM
    Diesel fuel is at least 20% more efficient, and the people that own them get a slight advantage in this department. This is where it ends.
    For the first time since 2004, I have been seriously considering going back to a HD gas powered truck to my specs.
    Diesels are great until they develop leaks, egr/dpf/fueling issues that can cost 5-15k dollars a pop. Hell, took my truck in today for a leak that was "fixed" 5 tries ago. Getting old and I don't have the facilities to be pulling the top end of a diesel apart. Been down that road.
    My day has consisted of cleaning up oil stains off my driveway and now doing an early oil change on the Mustang so I can daily this.
    Looks like I need to pull out the gas powered pressure washer. Funny enough I need the truck to go get fuel. :frusty:
    Diesels are bad ass when everything is running great. When it's not, better man up and pull out the wallet...and try not shedding any tears.
  9. May 13, 2025 at 10:10 AM
    Breathing Borla
    AZ
    thats a big trailer for a 1/2 ton, wow.
    but short distance and white knuckles got it there, HA.
    I can't remember what my 2016 platinum crewmax was rated for but I think it was around there, my 2023 platinum crew is higher, but if I was towing that all the time, I would go bigger truck for sure, need lots of reserve
  10. May 13, 2025 at 10:11 AM
    Breathing Borla
    AZ
    around here they rape you on diesel fuel as well, especially in the winter, its way more pricey than gasoline
  11. May 13, 2025 at 10:29 AM
    Not here, thankfully.
    We use 87 octane which is mid grade here. 3.25.
    Diesel is 3.05 and premium is 3.50 ish.
  12. May 13, 2025 at 11:11 AM
    ansel123
    ansel123 [OP] New Member
    Sr5 2024
    Several
    I forgot lol
  13. May 13, 2025 at 11:14 AM
    Ghost Rider
    Ian
    Cypress, Texas
    Yea, that was my very first pull and very stupidly, thought, yea, rated for 11,000 lbs, this 9,000 lbs is easy peasy, fuck no.
    But yea, it was a very white knuckle 30 miles and slow, 55 mph right lane on the highway....
    Never again.
  14. May 13, 2025 at 11:15 AM
    Ghost Rider
    Ian
    Cypress, Texas
    I am sorry....:rofl::rofl::rofl::rofl:
    GODZILLA and ZappBrannigan like this.
  15. May 13, 2025 at 11:25 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    I haven't towed yet with my Tundra, but I had an F250 6.7 Diesel, & even with that, towing about 6 to 8k lbs. I could only get about 14mpg max. Towing more put me at 12mpg.
    So if OP is getting 12-13 with a Tundra I consider that really good.
    ColoradoTJ likes this.
  16. May 13, 2025 at 11:41 AM
    ansel123
    Sr5 2024
    Several
    My post was based on seeing people tow far heavier and bigger items. Guess 12-13 isnt so bad
  17. May 13, 2025 at 11:44 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Diesel has more energy per gram than gasoline, while Ethanol has less energy per gram. You’ll see those effects in your mileage to some extent.
  18. May 13, 2025 at 11:46 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Like I said, it’s better than I get empty.
    My gas tow truck got just about 9mpg at all times.
  19. May 13, 2025 at 12:02 PM
    Right? I thought it was very good mileage. I was lucky to get 7-8's with my 2012 Tundra.
    Ford Super Duty diesels do very well in the fuel economy and power when towing department.
    Raven67[QUOTED] likes this.
  20. May 13, 2025 at 12:07 PM
    #50
    Well I lucked out again. Simple fuel leak that the shop caused. No charge.
    Happy dance.
    This is what diesel owners do. Seems everything costs 2-5k.
  21. May 13, 2025 at 1:27 PM
    #51
    Linuxrules
    Linuxrules New Member
    2024 Tundra
    The whole reason for Diesels "back in the day" was three things:
    1. lasted for many miles 200k or 300k or whatever vs. typical gas engine lifespan of say 100k.
    2. mpg when towing wasn't *as big a difference*. say went from 20mpg to 17mpg for a diesel when a gas truck would go from 20mpg to like... 9mpg towing heavy stuff.
    3. torque
    Nowadays:
    1. kind of not a thing anymore (well ok mostly), gas engines can often break that 100k mark.
    2. well... this thread
    3. 479 lb/ft in my limited (because it's the cool blueprint color) is just fine. that is a number that only diesels could reach "back in the day" (I'm ignoring super charged v8's etc.)
    Not meant in anyway as bashing Diesels, just things have changed so you have more choices.
    Oh personal benefits for me: Diesels are usually a pretty big upcharge to the price of a truck and they are heavier so not great out in the sand dunes. Plus I can leave the truck running in a drive through.
  22. May 13, 2025 at 2:09 PM
    #52
    JRS
    JRS New Member
    2012 DCLB
    (2nd gen) 6.5MPG for 35' TT @8K
    :spending:
    Your #s sound good.
    blenton likes this.
  23. May 13, 2025 at 2:16 PM
    #53
    blenton
    blenton New Member
    Truth.
    I get better gas mileage pulling 7-10k lbs worth of material on a flat bed than I do pulling 2k lbs worth of empty enclosed trailer (or even my small 5x10 enclosed).
    Speed ravages fuel economy with an enclosed trailer. Keep it under 55 and you get decent mileage but you are still dragging a parachute. Above 62 mph and it drops like a rock. Most of the highways around me are 65 or 70 mph speed limits, no passing lane. These trucks have plenty of power to pull at those speed, just expect to pay for it at the pump.
    One of the great advantages of small displacement forced induction is an increase in available power and torque, but with lower initial losses from displacement. Putt around town without getting in to boost and you can eek out better fuel economy than the same vehicle with a larger motor. But at the end of they day, you need ‘x’ amount of energy to move ‘Z’ amount of work.
    Drive down the freeway and the aerodynamics are going to factor in more to your fuel economy, but as long as you can stay out of boost but within the powerband, you’re still coming out ahead. Hitch up a trailer and drag will now dictate the rate at which you motor deletes fuel from the gas tank. No two ways around it. I get virtually the same mileage pulling an enclosed trailer with my supercharged ‘13 tundra as I do with my bone stock ‘21 tundra. Same motor, same cab, same drivetrain.
    There are, however, ways to make small changes to your fuel economy that can add up to an appreciable amount. Don’t drive like a Jack rabbit. Feed the pedal before getting to a hill and slowing down. Drive slow-ish (I hate that one, but it’s true..). Manually select gears if the transmission starts hunting in and out of gears. Keep your tires properly inflated (I air up 5 psi or so when towing, more if towing heavy).
    The 3.5TT drivetrain is a stout setup with plenty of power. But it can’t beat physics. 12-13 mph is pretty acceptable for any tow rig I’ve pulled with, including kinda-modern diesels (5.9 and early 6.7 Cummins, 1st and 2nd Gen Dmax, 7.3 power stroke, etc).
  24. May 13, 2025 at 2:21 PM
    #54
    ansel123
    Sr5 2024
    Several
    I was in tow haul the entire time and drove 70 mph
  25. May 13, 2025 at 2:23 PM
    #55
    Breathing Borla
    AZ
    how heavy?
    I would say you're doing pretty damn good going that fast, with that trailer.
    BlackNBlu, blenton and GODZILLA like this.
  26. May 13, 2025 at 2:33 PM
    #56
    ansel123
    Sr5 2024
    Several
    Moderately heavy not sure of lbs but the truck pulled it easily
  27. May 13, 2025 at 2:40 PM
    #57
    18" TRD Off Road Wheels
    Yeah, the speed is doing more than the weight. Drop to 65, or 60 if you can stand it. You'll see improved economy.
    BlackNBlu and blenton like this.
  28. May 13, 2025 at 2:49 PM
    #58
    Breathing Borla
    AZ
    moderately heavy isn't saying much, this truck pulls damn near anything easy, its just the speed and wind resistance is going to cause fuel burn.
    with 479 @ 2,400 and 10 gears, it pulls awesome, and with that trailer I think your doing a lot better than you think you are.
  29. May 13, 2025 at 3:03 PM
    #59
    ansel123
    Sr5 2024
    Several
    On texas highways??? Not putting my life in danger for mpg lol
    ZappBrannigan and blenton like this.
  30. May 13, 2025 at 3:05 PM
    #60
    Breathing Borla
    AZ
    LOL, then why are we talking about this shit, just fill it, boost the fuck out of it and stay under the 81 the trailer tires are likely max rated for.
    :burnrubber:
