WHy did YOU crawl unde your truck with a cutting torch and a needle scaler yesterday?
Discussion in '1st Gen Tundras (2000-2006)' started by ericryder, May 13, 2025.
  1. May 13, 2025 at 7:36 AM
    ericryder
    ericryder [OP] Nailbender
    Eric
    HILLSBOROUGH
    '04 SR5 3.4 5 speed access cab
    Head unit and door speakers aluminum ladder rack
    Driving home on Mother's Day, my truck took a little hop as I went around a 90 degree corner. Glanced in the side mirror at my missing wheel, did a quick check that it wasn't one of my primary tires :) and thanked goodness that the guy behind me hadn't been tailgating. Torched off the weldnuts, sanded/primed and installed a $55 AMZ hoist. Knocked off all the rust I could reach and FluidFilmed everything that was orange. FWIW, my frame appears to have received the Toyota coating job, and is in decent shape.
    The Black Mamba likes this.
  2. May 13, 2025 at 8:15 AM
    That was a tough read, but I think I've got it now. Your spare tire fell off due to a rusted retainer (pictured) and you replaced it. But you still believe the rest of your frame is fine. OK :thumbsup:
  3. May 13, 2025 at 9:06 AM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    eh...
    Frame got coated by Toyota and is in good shape huh....
    Still believe in the Easter Bunny and Santa Claus ?
  4. May 13, 2025 at 12:16 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I had to cut my spare lifting cable off with bolt cutters (thankfully before it fell out while driving, and also thankfully it didn't fall on my face after I cut the cable!). The I had to use a grinder to remove the rusty useless crank assembly, the treat the cross member with rust converter and rust encapsulator before installing a new unit. I have three vehicles with this design, so now I make a point of dropping the spare and greasing the cable and crank at least once a year.
  5. May 13, 2025 at 4:26 PM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    Lol
  6. May 14, 2025 at 5:20 PM
    The coating is great. The frame underneath the coating has been and is still rotting away to dust. You just can't see it, because the coating is great. Sorry about your luck....
    G_unit3000 likes this.
