Start/Stop moving forward if EPA removes mandate
Discussion in '3rd Gen Tundras (2022+)' started by TundraChuck, May 12, 2025.
  1. May 12, 2025 at 6:56 PM
    TundraChuck
    TundraChuck [OP] New Member
    Charles
    2023 Tundra SR5
    On the heels of the EPA director's mentioning the uselessness of the start/stop feature of American vehicles and the potential desire to do away with the mandate, would it be optimistic to hope that Toyota will give us an option to software disable Start/Stop if we so desire? I'd been meaning to look into the various rigs on the switch itself, but if the EPA lifts the requirement, would Toyota relent and give us the option to permanently disable it. Is it something that is even possible?
    ETA:
    https://www.roadandtrack.com/news/a64745676/epa-fixing-startstop-tech-department-admin-says/
  2. May 12, 2025 at 7:22 PM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Assume you mean new vehicles going forward. Doubtful Toyota would do anything for existing vehicles.
    If the aftermarket can do it, Toyota can do it better.
    Could they? Sure.
    Would they? is the question.
  3. May 12, 2025 at 7:35 PM
    Maine TRD PRO
    Maine TRD PRO New Member
    2023 Ice Cap Tundra TRD PRO(Rioja Red interior)
    Start/Stop is great with the Hybrid. Wouldnt like it otherwise
  4. May 12, 2025 at 7:44 PM
    savage24x
    savage24x New Member
    2025 Hybrid 1794 6.5
    Picked up my hybrid today. First time owning a stop/start vehicle. Doesn't bother me whatsoever. Very different system compared to the straight gassers, would bet the main complaints come from straight gas engines.
  5. May 12, 2025 at 7:57 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    No big deal, cost me $20 to eliminate mine, works great since day one.
  6. May 12, 2025 at 8:06 PM
    Didn't know the challenger hellcat has start/stop feature. Guess you need all the fuel economy help with 800hp. :rofl::rofl::rofl:
  7. May 12, 2025 at 8:08 PM
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    It is different for us hybrid owners. We don't have that little starter kicking in when we release the brake. We have a big electric motor that starts it at idle speed/rpm. It is almost unnoticeable. No loud whirr and no pinion gear kicking in. The only time the regular starter is used is the first time you start the truck after filling it up. I guess they do that just to insure it is working in case it is needed for as a backup.
    Leo's first and Tundrastruck91 like this.
  8. May 12, 2025 at 8:31 PM
    Starman2112
    Starman2112 New Member
    I would guess a few things. The mandate would only last 3 years at most. Second, California would probably keep it which means car manufaturers if they want to sell in California would have to keep it which means they would all... keep it. Hard to go against the 4th largest economy in the world :)
  9. May 12, 2025 at 9:03 PM
    SDtrueblue
    SDtrueblue New Member
    Marco
    '25 Tundra Limited TRD Midnight Black
    King 2.5's
    I thought I would hate the feature, but it’s not that inconvenient. On my Limited, you REALLY have to to hard press the brake to engage it at a stop light. It’s easy just to light foot the brake and not have it shut the truck down. When I’ve used it though, it’s only been at red lights that I know take a minute or more to turn green. I’m not sure of the actual mpg benefit of using it but I’m only saying that it’s easy to ignore it if you want to.
    Tom976, vtown76 and Tundrastruck91 like this.
  10. May 13, 2025 at 2:37 AM
    wing-2
    wing-2 New Member
    I would not expect anything to change. These vehicles are sold globally. There is a massive amount of cost that goes into the development and implementation of this system. And, it could all change in four years.
    motogon, vtown76 and Cpl_Punishment like this.
  11. May 13, 2025 at 4:43 AM
    Petro
    Petro New Member
    2019 Tundra SR5 TRD OR Crewmax
    Certainly happy my vehicle doesn't have that annoying feature.
    All these mandates do is add unnecessary costs and potential failure points.
  12. May 13, 2025 at 5:16 AM
    I would need to drive a hybrid vehicle to really have an educated opinion.
    My Subaru has auto on/off and it's turned off every time.
    Cpl_Punishment, Leo's first and Petro like this.
  13. May 13, 2025 at 6:08 AM
    Maine TRD PRO
    I like it because it’s providing a mode of power when the engine is off. When a stop light turns green I’m already half way across the intersection when the engine turns on, not waiting for it to turn on to move. Also if you’re on a flat road going 50 you can usually let off the gas for half a second to let the engine turn off and then can apply the gas again to let it drive in electric. It’ll go for 2ish miles before it has to turn on the engine to charge if you do it right. Not to mention it’s an electric A/C and I don’t have to worry about how hard I’m pressing the brakes or not.
    gdisarray and ColoradoTJ[QUOTED] like this.
  14. May 13, 2025 at 6:11 AM
    Definitely some benefits with the hybrid.
    My wife's Subaru usually shuts off just before the light turns green and saves 3 seconds of fuel. :rofl:
  15. May 13, 2025 at 6:17 AM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    I have the 3.4 gas motor, non hybrid. If I recall correctly on the hybrid when you take off from a standing start, the electric motor is used solely for drive up to approximately 18 mph then the gas motor kicks in. Doesn’t the starter activate at that time to fire the gas motor, or is there some kind of clutch system that fires it like push starting a manual transmission car ? Or is the gas motor electronically disabled under certain circumstances such as standing start..?
  16. May 13, 2025 at 6:24 AM
    dklehman
    dklehman New Member
    Darin
    2024 sr5 Tundra
    As easy as it is to use or not use the start / stop feature. I don't know why anyone would complain about the system on the 3rd gen tundra, other than you like to complain about things that are not really an issue just to complain.
    sandiegosteve likes this.
  17. May 13, 2025 at 6:27 AM
    Maine TRD PRO
    it is not based on speed. It’s all power demand. I can manipulate to drive in all electric at 50mph in the right circumstances.
    Idk how the starter works exactly but it’s very smooth and seamless. Never waiting for it and half the time can’t even tell when it’s shutting off or turning on. I was a skeptic but I love it
    Soupbean77[QUOTED] likes this.
  18. May 13, 2025 at 6:30 AM
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    I drive my wife's new Venza (discontinued again....) and it has the start-stop feature, being a hybrid.
    Honestly, I think hybrid has come a long way since the first Prius.
    Back then I drove one, did not impress me, as the tech seems, rough around the edges and just overall not well thought out.
    Even drove friend's BMW X1, and that start-stop nearly give me a heart attack when I stopped at the red light, thought I did something wrong and stalled the car or killed it (I was still driving manual back then so I thought the clutch went out or something)...
    But now, I think with years of fine-tuning, Toyota has this start-stop on hybrid pretty much rounded up and honestly, we talked about if we get a next Toyota SUV, it will have to be a hybrid, not only to save some gas while sitting in traffic (which is known in Houston), but overall the electric to gas to electric switch over is just so smooth now.
    And yes, the hybrid electric motor is a good low speed/rpm starting, not to be waiting for gas engine to kick in which could result in a bit of a delay. Hybrid just, rolls, and then kicks in.
    However, I am still learning how to service a hybrid vehicle, oil change is one thing, I am not so sure of the others, wouldn't touch the batteries, but am not sure if any other maintenance schedule/item(s) would be any different....
  19. May 13, 2025 at 7:14 AM
    gdisarray
    No the starter doesn't activate. Once the electric motor is being used to take off it actually is used to start the engine. The "real" starter with the bendix is not used to start the engine. It is there for backup.
  20. May 13, 2025 at 8:31 AM
    Linuxrules
    Linuxrules New Member
    2024 Tundra
  21. May 13, 2025 at 9:03 AM
    SDtrueblue
    Marco
    King 2.5's
    I've been in vehicles where it shuts the car off automatically at a light. Yes, that is annoying AF!!
    But on my '25 (non-hybrid), you have to press the brake HARD to engage it to shut off the truck, so it's not as automatic as it sounds. It's very easy to just keep the truck running if one wants to, which I think is a very good compromise.
  22. May 13, 2025 at 9:13 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    If peoples cars are off & the light turns green, they may just need a bit of a push.
    kirkb likes this.
  23. May 13, 2025 at 9:19 AM
    JayDee
    JayDee New Member
    But you do still have that "Warning" light lit up like there is something wrong. They should change it so that the Auto-Stop indication only comes on when it's enabled and be Green (or Gray) instead of Amber.
  24. May 13, 2025 at 9:22 AM
    JayDee
    JayDee New Member
    Yes, I do that in mine as well but then you still have the issue of the engine stopping (and most of the time immediately restarting) whenever you shift into park. Not to mention the amber "warning" light as I've already mentioned.
    Retroboy1989 likes this.
  25. May 13, 2025 at 9:25 AM
    DRP
    DRP Old Member
    Dave
    My driving style is such that the engine rarely shuts off at stop signs/lights but the shutting off randomly when placed into park is a head scratcher.
  26. May 13, 2025 at 10:44 AM
    JayDee
    JayDee New Member
    It only does it if the Auto-Stop is left on. Park is the equivalent of mashing the brake hard when stopped. What's really stupid is that 90% of the time the truck immediately restarts because I guess it thinks the battery is too low for the amount of electrical draw. Toyota definitely needs to fix the software on this issue. It's just adding extra wear to the engine.
    PNW Tundra Mike likes this.
  27. May 13, 2025 at 10:58 AM
    DRP
    DRP Old Member
    Dave
    Mine is totally random on the park thing. Some times it does most of the time it doesn't. Agree it would be a nice fix to have but won't hold my breath.
  28. May 13, 2025 at 11:01 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    I don't complain as much as curse when I forget to turn this stupid feature off. If I can't make it routine maybe I'll get one of the auto switches that turns it off for me.
  29. May 13, 2025 at 11:07 AM
    Breathing Borla
    Northern Illinois
    my wife's hybrid Sienna has it, its not bad
    I CANT STAND IT on my non hybrid tundra, its on the pre-flight checklist to turn that off every time
  30. May 13, 2025 at 11:53 AM
    Maine TRD PRO
    one of my favorite things about it that I wish it did more of is…..
    when you first start the truck. If you put it in drive within the first 2-3 minutes of starting it. It will use the hybrid battery for more power instead of spooling up the turbos. It won’t use the turbos until it’s warmed up. It will only use the hybrid power that way if the battery is too charged which is rare or when the truck is just started. I wish it was a little more liberal in its battery deployment.
