Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. Feb 26, 2025 at 4:36 PM
    #5431
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
  2. Mar 9, 2025 at 2:19 PM
    #5432
    New monthly client. Not horrible to start with. He had a lot of paint splatter on his hood, I went ahead and polished out for him, along with the entire hood - no charge for the polish since he’s now a monthly client and little things go a long way, like doing the engine bay too
  3. Mar 9, 2025 at 2:22 PM
    #5433
    Finished
  4. Mar 10, 2025 at 9:30 AM
    #5434
    briarpatch
    briarpatch New Member
    Hand sanitizer
  5. Mar 10, 2025 at 2:36 PM
    #5435
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    I did not know that. Thanks Briar.
  6. Mar 11, 2025 at 6:40 AM
    #5436
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR10
    @briarpatch Is there any need to "top" Jescar Ultralock+? I usually end with griots 3 in 1 ceramic. Thanks!
  7. Mar 18, 2025 at 9:35 AM
    #5437
    briarpatch
    At the initial application.....no....unless you prefer the look of a standard wax......and I've used Colorlock for that. As for your maintenance routine, I typically top it with Armour Detail Amplify.....prolongs the protection, maintains the gloss and slickness
    cartage1 and oddhours[QUOTED] like this.
  8. May 12, 2025 at 2:35 PM
    #5438
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    Any recommendations for a flexible pressure washer hose? I have this inner struggle where I want to use a pressure washer at times but always end up getting pissed off because the damn hose is so stiff and gets caught on everything.
    eddiefromcali likes this.
  9. May 12, 2025 at 3:35 PM
    #5439
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
  10. May 13, 2025 at 1:27 PM
    #5440
    BC Tundra
    BC Tundra New Member
    Anyone know of a product and/or detailing trick that will restore the black vinyl trim on the B pillars? I understand this is removable and fairly inexpensive to buy replacement vinyl, but I have stick-on rain guards that have been applied (partially) on top of this so I'd rather not have to deal with that issue if there's a way to treat the vinyl. It's faded and spotted and just looks bad, whereas the rest of the actual plastic anywhere on the truck still looks fantastic and makes that vinyl trim stick out even more. It's a 2020 SR5 Crewmax fyi.
  11. May 13, 2025 at 7:54 PM
    #5441
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    What color is your truck? Consider removing them all together since they're painted underneath the same color as your truck?
    OldGuy03 likes this.
  12. May 13, 2025 at 8:08 PM
    #5442
    RobertD
    Robert
    DFW, Texas
    But his rain guards are attached over the top. So he would have to cut or trim the piece trapped or fully remove the rain guards (which he doesn't seem to want to do or he would probably just get new vinyl to wrap the pillar).
    I personally like having the pillar black so I hope he finds a way to get his clean.
    Fotnot[QUOTED] likes this.
  13. May 13, 2025 at 8:12 PM
    #5443
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I wasn't paying attention to that detail enough. Good point.
    RobertD[QUOTED] likes this.
  14. May 13, 2025 at 8:29 PM
    #5444
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    uberflex is flexible but isn't reinforced and can cause surging. Kobrajet is reinforced but a bit more pricey.
  15. May 14, 2025 at 12:45 PM
    #5445
    BC Tundra
    The truck is Silver Sky Metallic (I believe that's the name of the silver colour that year?). And yes, Rob D explained it - I would just remove and replace the vinyl if the rain guards weren't stuck on top. I am considering buying replacement vinyl and cutting the new pieces so they fit around the rain guards, but what are the chances I can make that look as good as factory and not mess it up? Was hoping there was a product to 'revive' the vinyl, even if were a 'temporary' solution. If I had been on top of things better I'd have bought some replacement vinyl and done that at the same time as the rain-guards - I just wasn't expecting the appearance of the factory vinyl to deteriorate so fast over the course of the past winter/spring - before that it was holding up reasonably well.
  16. May 27, 2025 at 8:41 AM
    #5446
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    I bought a bottle of Adam's Graphene ceramic spray, and the first time I used it I was less than impressed. However, I believe that was due to user error, as I was using too much product. Now that I've figured it out, I really like the stuff and it gives a great shine. I did my truck and the wife's car after clay bar, and I really am impressed with the stuff. But I have to ask, is this stuff really worth the price or is it just upscale detail spray? I realize it's no substitution for a real ceramic coating, but it's highly unlikely I'd ever apply one to an 18 y/o truck. Who can fill me in on this spray stuff and maybe make a recommendation for other products. Thanks
    Fotnot likes this.
  17. May 27, 2025 at 7:18 PM
    #5447
    It’s good for maybe 6 months with proper maintenance washing.
    Their actual graphene dressing will get you multiple years on it, with proper wash care and presuming it’s not stuck in shit weather all day. Be sure to polish before you apply. You could prob skip a clay bar since a buff and polish would get it out anyway
    dondino[QUOTED] likes this.
