Loose Fog Light
Discussion in '2.5 Gen Tundras (2014-2021)' started by Airborne22, May 11, 2025.
  1. May 11, 2025 at 3:51 PM
    Airborne22
    Airborne22 [OP] New Member
    Glen
    Suffolk, VA
    Hey all, I seem to have a loose foglight housing. It just snaps in place with two tabs on one side. Has anyone (I'm sure you have) encountered this and what was your fix?
  2. May 11, 2025 at 3:58 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Fairly common and there is a fix. Someone should be along soon to give you some pointers. I have an aftermarket front bumper.
    Airborne22[OP] likes this.
  3. May 11, 2025 at 4:26 PM
  4. May 11, 2025 at 5:23 PM
    Airborne22
    Glen
    Suffolk, VA
    Thank you!
    Jim LE 1301 likes this.
  5. May 11, 2025 at 5:47 PM
    ToyotaBeast
    ToyotaBeast New Member
    I had the same issue with mine on both sides. I used some felt pads around the clips that retain into the bumper and that was able to tighten it up a bit. I have also seen people use zip ties to help take up the slack too.
  6. May 11, 2025 at 6:15 PM
    :hattip:
    NewImprovedRon likes this.
  7. May 12, 2025 at 2:16 PM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    I bought new cheap housings, that helped a lot. Then I also ran several zip ties to secure everything and it's sense been better.
  8. May 12, 2025 at 2:58 PM
    AZBoatHauler
    So.Arizona
    These trucks are known for jiggly fog lights - it wasn't as noticeable with the incandescent lights but with the LEDs you could see the light bounce across every joint in the pavement.
    my solution was a Demello bumper.
  9. May 12, 2025 at 3:22 PM
    DanSanDiego
    DanSanDiego New Member
    2019 Tundra Limited 4x4
    Hot glue gun works really well to secure the loose bracket. I used hot glue on the underside of the bumper endcap. Can’t see the beads of hot glue and really locks in the fog light . If you need to remove the bracket some IPA or rubbing alcohol will allow the glue to pop off easily.
