Truck wont move in drive or 2
Discussion in '1st Gen Tundras (2000-2006)' started by Tondrama, May 11, 2025.
  1. May 11, 2025 at 11:54 PM
    Tondrama
    Tondrama [OP] New Member
    Victor
    Bay area calif
    2001 toy tundra sr5 access cab
    Work in progress
    So i had changed out my differential and got my truck running but it wont move in drive or 2 ,i can put it in low and it starts rolling once i get moving i can shift to 2nd and drive and it runs fine until i come to a complete stop then i need to put it in low again and start rolling then i can shift into drive and it rolls fine anyone know what may be causing this ,and its not my shift solenoids cause i replaced the whole valvebody in the transmission, any suggestions
  2. May 12, 2025 at 3:53 AM
    Are you sure the trans fluid level is correct?
    When exactly did this start, after which maintenance?
    Which engine, v6 or v8?
    Which transmission? There are like 6 different valve body types/variations for the 4spd auto A340 in your year Tundra and I’m wondering if you swapped the wrong valve body in, hence why you’re not able to shift into certain gears? @The Black Mamba has posted more info in his transmission dump thread here: https://www.tundras.com/threads/a340e-f-info-dump.151751/
    Reading that thread may help you determine if you did install the wrong valve body
    KNABORES likes this.
  3. May 12, 2025 at 5:27 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Will it accelerate from a stop in Drive? I know my ford ranger starts in 2nd when the lever is on ‘2’, but the tundra uses 1st & 2nd with the lever on ‘2’.
  4. May 12, 2025 at 5:31 AM
    I'm with @shifty` on this. Low fluid, or incorrect valve body / install. We're missing the timeline to make it make sense though. Problems before you swapped valve bodies? Obviously, or you wouldn't have messed with it. Same problem you still have? Or different new problem after? Immediately after? Or you swapped, it worked fine, now it's messing up? Step 1 is checking that fluid level though.
    shifty` and NewImprovedRon like this.
  5. May 12, 2025 at 6:54 AM
    Tondrama
    Victor
    Bay area calif
    Work in progress
    It only accelerates in low ,if i have it in 2 or drive it has engine climbing in rpms but no movement ,it has an A340F transmission which i had switched valve body from exact model transmission v8 4sp automatic, it does the exact same with original valve body as with new valvebody thats why im reaching out ive gone through factory service manuals and think i may be missing something it acts like its a manual transmission when in drive or 2nd with clutch pedal pushed in i had local jiffy lube guys top off tranny but it may be low still ill see how low it may still be later today
  6. May 12, 2025 at 6:56 AM
    "Jiffy Lube"
    :eek::eek::eek::eek::eek::eek::eek::eek::eek::eek:
    NewImprovedRon likes this.
  7. May 12, 2025 at 6:57 AM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    Oh geez...why oh why?
  8. May 12, 2025 at 7:03 AM
    Tondrama
    Victor
    Bay area calif
    Work in progress
    Transmission fluid isn't cheap these days , eek well i was desperate, it was in the heat of the moment, lol
  9. May 12, 2025 at 7:05 AM
    Tondrama
    Victor
    Bay area calif
    Work in progress
    All i could get with my last 11 dollas
    Sirfive likes this.
  10. May 12, 2025 at 7:41 AM
    Free to pop the hood once the trucks transmission has warmed up and pull the dipstick to check the trans fluid level.
    The Black Mamba, Sirfive and ATBAV8 like this.
  11. May 12, 2025 at 7:57 AM
    * While you're on flat ground, not an incline.
    Sirfive likes this.
  12. May 12, 2025 at 7:58 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    How many balls are in a a340? The solenoids arent ‘part’ of the valvebody.
    if you park it from first gear, then restart it, and go to drive does it reset in first? If its in the trans and time is money, then you’re gonna be looking for single tranny’s in your area. But maybe the first gear ?shuttle valve? Is sticky?
    sorry, i’ve got a dozen irons in the fire, and just dont have the bandwidth to dig into it right now, but maybe tues or wed when its triple digits.
    The Black Mamba likes this.
  13. May 12, 2025 at 8:01 AM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    I'd rather have the chap in your avatar work on my vehicle than anyone from Jiffy Lube.
  14. May 12, 2025 at 8:01 AM
    https://www.youtube.com/watch?v=E-kMsBMh6Ng
    Sirfive[QUOTED] likes this.
  15. May 12, 2025 at 9:43 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    my brother worked at jiffy lube.
  16. May 12, 2025 at 9:47 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    No.2 one–way clutch (F2)
    I'm sorry you went through that as I feel that you wasted your time and or money
    FSM section DI-402 page 1364
    shifty` and KNABORES like this.
  17. May 12, 2025 at 9:48 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    solid gold, as always.
  18. May 12, 2025 at 10:49 AM
    @The Black Mamba comin' thru in the clutch.
  19. May 12, 2025 at 2:16 PM
  20. May 12, 2025 at 4:10 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Yeah, but did you see what @Sirfive did there? :D
    KNABORES[QUOTED] likes this.
