  1. May 11, 2025 at 9:02 PM
    Stone Chingon'
    Stone Chingon' New Member
    BC
    East County SD
    2021 Crewmax 4x4 Limited
    Yaa maybe a bit overkill but I just couldn't pass up the deal I made, and I couldn't be happier with the way the truck rides and drives now. I previously owned a 2006 Tundra double cab and installed the Fox factory series coil overs-non resevoir and wow what a difference in ride quality. These Elite series Fox's are the Jam! We will be hitting the dirt at the end of this month on a camping trip so I'll have to report back with how she feels out on the trails.
    TNThunder, woods, BR73 and 2 others like this.
  2. May 12, 2025 at 3:35 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    All good,
    5w30 does just fine in this climate. Even in the bitter cold (…that we get in the region). I don’t think you will have any issues on the Island. And from my basic research it seems that Pennzoil Platinum is on the lighter side of a 5w30…take that with a grain of salt obviously. I have also used Mobil 1EP with the same results.
    I haven’t noticed any loss in MPG’s FYI, but the Toyota “tick” is definitely quieter. I have never owned a Toyota truck (3-3.4’s L and 2-4.0’s L) that didn’t have that tick.
    bulldog93, koditten and ATV25 like this.
  3. May 12, 2025 at 3:57 AM
    Tboh1870
    Tboh1870 New Member
    Herman
    Just starting reno
    Ahhh ... yep I could see the benefit to that functionality for sure
    On its 1st trip for us it did what they said it would do though
    Xcumminsguy[QUOTED] likes this.
  4. May 12, 2025 at 4:01 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    NICE!!
  5. May 12, 2025 at 4:03 AM
    Corndog123
    Sam
    Tennessee
    Yes, please keep us posted.
  6. May 12, 2025 at 4:04 AM
    Corndog123
    Sam
    Tennessee
    Just do your Jedi mind trick thing.
  7. May 12, 2025 at 6:50 AM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Did the brakes this weekend. As expected everything was rusted together. The wheel spacers were seized on to the rotor which forces me to fabricated a slide hammer. The locating pins for the brake pads were rusted solid. Ended up cutting them in have, grinding off the heads and using a punch to drive them through. Wire brushed everything down, Painted the calipers and backing plates. Coated everything with a thin layer of red grease to keep it from seizing again and bolted it back together. Bedded them in and should be good to go now. I went with Bendix Fleet Metlok rotors. They were in the budget and seem to have good reviews. Seems like I have some uneven wear on the pads. The inside pads were worn more than the outside pads. I will keep an eye on this and a caliper swap may be in my future.
    Side Note: Also had to deal with bulging lug nut covers. Spent about 30 minutes removing the stainless cover on all 10 lugs I had off for the front wheels. I painted them black to match the wheels and let them sun bake while I did the brake job. They seem to be holding up well. If you are in a snow prone area I would either swap the lugs out or get ahead of them. I didn't have any issues removing them other than being stuck in the socket and having to smack them on a rock or piece of metal to remove but it could have been a lot worse.
  8. May 12, 2025 at 8:39 AM
    Corndog123
    Sam
    Tennessee
    Yep, did my brakes not long ago and my lug nuts were apparently put on there by a gorilla. Had to use an impact to take them off. Didn't have a breaker bar or lug nut 4 way. I have aftermarket rims so the stock lug wrench didn't fit the nuts either.
  9. May 12, 2025 at 9:40 AM
    Corndog123
    Sam
    Tennessee
    Got new shoes put on her. 305/55R20 Nitto Ridge Grapplers. 20250512_113450.jpg
  10. May 12, 2025 at 10:12 AM
    mfelton18
    mfelton18 New Member
    South Central Texas
    2014 Magnetic Grey SR5 4x4 crewmax
    Washed her up today.
  11. May 12, 2025 at 10:30 AM
    Corndog123
    Sam
    Tennessee
    Yep, just got back from running her through the car wash. New wipers too.
    ATV25 and mfelton18[QUOTED] like this.
  12. May 12, 2025 at 10:55 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Email received- LSK race kit should be shipping this week. Slight delay on the RCV axles.
  13. May 12, 2025 at 11:03 AM
    SAGE63
    San Diego County
    nice.... well RCV LT axles worth the wait I guess
    HulkSmurf14 and reywcms[QUOTED] like this.
  14. May 12, 2025 at 11:08 AM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    THE DE-CHROMING(is that even a word??) BEGINS. and was able to relocate my FRAC camera, SSOOO much better now. IMG_20250512_094349173_HDR.jpg IMG_20250512_094352452_HDR.jpg IMG_20250512_120323554.jpg IMG_20250512_120334101_HDR.jpg
  15. May 12, 2025 at 11:17 AM
    Ebrperk
    Ebrperk Old member
    2018 1794 MGM
    Those look incredible, great score
  16. May 12, 2025 at 11:22 AM
    Ebrperk
    Ebrperk Old member
    2018 1794 MGM
    I'm jealous, hopefully this is the next mod. That is the system I want(need).
    BlueRibbon4x4[QUOTED] likes this.
  17. May 12, 2025 at 11:29 AM
    Ebrperk
    Ebrperk Old member
    2018 1794 MGM
    Installed mine a few weeks ago, can definitely hear the tone change when the VVTI adjusts the cams. Still waiting on the MPG increase that was rumored to happen
    BR73[QUOTED] likes this.
  18. May 12, 2025 at 12:22 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    No regrets here! Not obnoxious, just a nice tone. Haven’t put the resonator on yet, but if it lowers the drone even more than it has already, should be awesome.
    Tripleconpanna, RobertD and BR73 like this.
  19. May 12, 2025 at 1:02 PM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    Had some uneven wear on my front tires so I replaced them and got an alignment. Probably the last KO2's I'll ever buy.
  20. May 12, 2025 at 1:07 PM
    Armstrs
    Armstrs New Member
    Steven
    East Texas
    2017 Silver CrewMax 5.7L 4x4
    Amp research power steps OEM tow mirrors OEM tonneau cover TRD Sway Bar Black Texas Lone Star plates :) Auto tail gate lock KB Voodoo 22” aluminum bed rack TRD Pro headlights Katzkin seats Black badges
    Looks great! I finally decided to order a grill/ surround and hood bulge to de-chrome. And… there is a national back order with 147 orders ahead of me.
  21. May 12, 2025 at 1:08 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I've heard that before about the KO2s...
    Tripleconpanna, BR73 and JMGmanAZ like this.
  22. May 12, 2025 at 1:11 PM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    My reference to the last set I'll ever buy is because the KO2's aren't being made anymore and have been replaced with the new KO3's. I personally really like them, but understand others do not.
    woods, NewImprovedRon, BR73 and 2 others like this.
  23. May 12, 2025 at 1:27 PM
    HulkSmurf14
    2014 Tundra Limited
    I hear ya! I had challenges myself when I owned them...but it was for a different 4x4 in a different era...I now only use Cooper ST MAXX tires on all of my stuff...I'm not certain how much longer they're to be made though...
    BR73 likes this.
  24. May 12, 2025 at 2:00 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    I had a set of KO3'S and after some wear they were absolutely trash.Im on Toyo Open Country AT III'S now and they are far superior IMHO
  25. May 12, 2025 at 2:09 PM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    all this tire talk has me confirming my next set I plan to get by EOM. Leaning towards Falken Rubitrek's. If not those, maybe the Wildpeak AT4. the current Cooper Discoverer AT3 XLT are showing a lot of dry rot, cracks on blocks, in grooves, and on sidewall. Not feeling good about that at all.
    Apparently the Rubitrek's are a sleeper, very similar to the Wildpeaks, but designed to be slightly more highway/road friendly.
    HulkSmurf14 likes this.
  26. May 12, 2025 at 5:17 PM
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    The AT3 Wildpeaks were good to me. Almost 90,000 miles and one intermediate alignment around 50,000. Hoping the new AT4’s will do as good.
  27. May 12, 2025 at 5:29 PM
    Ace96
    Ace96 New Member
    Western KY
    2021 Voodoo Blue TRD Sport
    Bought a TRD PRO grille to swap out. Went to put the star washer on the garnish and broke one of the damn pegs off the garnish. Fook me. :frusty: Guess it’s epoxy time. :facepalm:
  28. May 12, 2025 at 5:31 PM
    drgordon13
    drgordon13 New Member
    2020 Gray Tundra TSS
    Great mod! Was that a kit or did you do that on your own? I have a DB cover and would love to do that !
    French Avocado and BR73 like this.
  29. May 12, 2025 at 5:44 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Doing the power steering flush this evening PXL_20250512_234913271.jpg PXL_20250513_004046793.jpg
  30. May 12, 2025 at 5:48 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Everything looks brand new! What did you score it all for?
