Chip for increased mileage?
Discussion in 'Performance and Tuning' started by Sleddog, Apr 29, 2024.
  1. Apr 29, 2024 at 3:32 PM
    Sleddog
    Sleddog [OP] New Member
    2019 black Tundra TRD dbl cab
    Has anyone performed a chip upgrade on their 2019 Tundra SR5 4wd? I just returned from camping and my truck registered a whopping 7.5 mpg while towing a 5400 lb travel trailer! Granted, it was really windy, but I'm interested to know if anyone has made an upgrade to increase MPG. I see a few companies selling chip upgrades, and others who recommend installing a high performance air filter. Has anyone on the forum had any luck with either upgrade?
  2. Apr 29, 2024 at 3:36 PM
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    Not worth it. The chips won't help and your truck already has a cold air intake, could try a less restrictive air filter but I would stay away from oiled ones due to chances of over oiling and messing up the MAF.
    These trucks are thirsty, it's just part of the game with the 5.7, thirsty but reliable
  3. Apr 29, 2024 at 3:42 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
  4. Apr 29, 2024 at 4:14 PM
    Marvthehamster
    Marvthehamster New Member
    Tom
    CO
    2018 CM
    ADS/Deaver, Method's, 35's, RCI Armor, OTT Tune
    Repeat after me....7@70. This is your reality. Embrace it. I've towed a similar trailer for about 15k miles back and forth across our great nation. Ain't no chip gonna get you better mileage. I'd look at 5.29 gears or a S/C for any significant difference in towing performance. On the plus side, it won't hurt your mileage any further to throw in a few of your favorite cold beers and one of those comfy folding rocking chairs for your destination. Enjoy the trips!
  5. Apr 29, 2024 at 4:46 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    I don’t know what tire size you have. Maybe changing to a smaller tire size might help. But what was said above, not a lot you can do .
  6. Apr 29, 2024 at 6:22 PM
    Only way to increase MPG is to slow down. No chip will overcome physics. It takes energy to move that big trailer. Energy comes from burning fuel. Period. Decrease the amount of energy required (re-gear, smaller, lighter tires, lower the truck, or drive under 60mpg) and MPG will improve.
  7. Apr 30, 2024 at 3:12 AM
    Sleddog
    Thanks to all of you who replied! I appreciate all of the advice and recommendations. I'll give them a shot and hope for better mileage. If not, I'll just get used to lower mileage while towing! Thanks to all again!
    Saltyhero13 likes this.
  8. Apr 30, 2024 at 6:51 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Nope, to get the best MPG, keep the truck stock height and run stock size tires, highway tread. MPG ratings are 13/17 and it you drive carefully you can get a bit better, 1-1.5 mpg more perhaps.
    Towing -expect low double digits, even single digit at times depending on load and conditions. You are driving a 400HP, heavy, brick shaped vehicle so all this is typical.
  9. Apr 30, 2024 at 8:43 AM
    Sleddog
    Thanks for you response! My truck is leveled and I just put new Michelin ATX tires on it. I went with a slightly larger tire (275/70/18 vs stock 275/65/18), so combined with the leveling kit, that may explain some of the poor MPG. Thanks again.
  10. Apr 30, 2024 at 8:59 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The taller tires are killing at least 2-3 highway mpg alone
  11. Apr 30, 2024 at 9:57 AM
    Sleddog
    Good to know...thanks!
  12. Jun 4, 2024 at 8:56 AM
    Pd1014
    Pd1014 New Member
    2019 Tundra Platinum Crewmax
    Has anyone tried a Thornton n performance chip on their 5.7 ? I have a 2019 5.7 and was wondering what if any different before and after.
  13. Jun 6, 2024 at 6:57 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Let’s all say it together…
    No chip on the market is going to give you any appreciable amount of power or efficiency gains.
    PermaFrostTRD and nobodyintexas like this.
  14. Jun 6, 2024 at 7:00 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    hold on a minute...
    y'all said to never use the words power & efficiency in the same sentence*.
    what'd I miss?
    *like>> never use Supercharger & warranty in the same sentence.
    OldGuy03 and Retired...finally like this.
  15. Jun 6, 2024 at 8:18 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    Yeah, but I specifically said power OR efficiency. They don’t need to go hand in hand.
    As long as they get the point that there aren’t any chips available that are worth a shit, I’ve made a difference.
  16. Jun 6, 2024 at 8:24 AM
    PermaFrostTRD
    Northern NY
    By using the chip or ECU that belongs in a Prius you can get really great MPGs.
    The only drawback is you have to use it in the Prius.
    Welcome to Tundras. Get a 38gal tank (or 46gal Transferflow) so you can forget how much the last fill-up crammed it in your cram-hole.
  17. Jun 6, 2024 at 8:34 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    For my own edification -
    What would this "chip" be doing?
    specifically?
    Would it lean out the fueling?
    and why would one want to change the fundamental programming of a complicated engine?
  18. May 12, 2025 at 6:55 AM
    N5drw
    N5drw New Member
    2018 tundra 5.7
    Gears only
    I took my 2018 5.7 tundra from Oklahoma to Mississippi and pulled 30 foot travel trailer and only got 7.4 average miles per gallon got home had gears swapped from stock 4:30 to 4:88 and pulled same trailer from Oklahoma to SD. And average went to 9.4 miles to the gallon and pulled so much better no chip can do any better and I have stock size tires just my input
    2014 Black tundra and ColoradoTJ like this.
