How screwed am I?
Discussion in '2.5 Gen Tundras (2014-2021)' started by point08, May 10, 2025 at 7:51 PM.
  1. May 10, 2025 at 7:51 PM
    point08
    point08 [OP] New Member
    Kyle
    2014 Toyota Tundra 5.7L SR5 4WD DC
    AirLift LoadLifter 5000 Ultimate Plus, AirLift Wireless One 2nd Gen, TRD Rear Sway Bar, Bakflip G2 Tonneau Cover, Running Boards, Tint, Power Tailgate Lock, Hike-It X9 Throttle Controller, Tekonsha P3 Brake Controller with Custom In-Dash Housing, Method 701 Wheels, Toyo Open Country III Tires, 3WLiner Window Mod, External Fuse Box, Dash Cam, Pioneer DMH-1500NEX
    Dealing with the 'rat chewed my knock sensor' story that everyone has on here... I kept throwing a code with the 3rd party harness... so I bought an OEM harness and as I went to plug it in (tried to shortcut it with the lifting of the manifold), I realized I had loose cables in the harness from the loom... omfg.
    Trying to trace this down... i'm kind of at a loss.
    HulkSmurf14 likes this.
  2. May 10, 2025 at 8:02 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Well, this sucks...no way around it...you need new pins and some patience...you're very capable of knocking this out, but I'd walk away for a bit, come back after some rest and see if you're able to depin and reuse them...
  3. May 10, 2025 at 8:10 PM
    MarkM0369
    MarkM0369 New Member
    Mark
    2017 Tundra SR5 4x4
    275/70 KO2, Pro Hood Bulge and grille, OEM fender flares, Fox rear shocks
    That sucks, they make a molex connection tool and pin kit, and similar if you want to try and reconnect the pins, or you could go wire by wire and just use butt connectors or male and female spade connectors if you want to be able to easily take it apart again, and just skip the plugs, just label the wires so you know what’s what in the future
  4. May 10, 2025 at 8:15 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    This is time consuming but in no way impossible. Get a pin removal tool or use a needle. Unhook the battery, depin the plug, add a little
    More to each connection and add new pins. Then plug those pins into the factory connector. You can get the pin kits on Amazon for 20 bucks or so.
    point08[OP] and HulkSmurf14 like this.
  5. May 11, 2025 at 5:55 PM
    ToyotaBeast
    ToyotaBeast New Member
    Not a hard fix. You can get new pins from the dealer and just solder them on.
  6. May 11, 2025 at 6:04 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
