Rain guard adhesive
Discussion in 'General Tundra Discussion' started by War_Wagon312, Oct 21, 2017.
  1. Oct 21, 2017 at 3:20 PM
    War_Wagon312
    War_Wagon312 [OP] Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    Looking for a little help. I have weather tech in channel rain guards. The adhesive that came on them was very weak and has worn off. Now when I have my windows down and I hit a bump bing bang boom crunch they rattle around in the channel. Looking for a suggestion on what 3m tape to use for em.
  2. Oct 21, 2017 at 3:28 PM
    War_Wagon312
    Rich
    Stock horse
    Thank you sir! I was unsure if I used double sided stickiness for the in channel type that I wouldent be able to get them out if they break or something. Needed some reassurance . Your the man!
  3. Oct 21, 2017 at 3:43 PM
    War_Wagon312
    Rich
    Stock horse
    Got it. I could have swore mine had the same strip as the rear. A very thin line of some kind but I could be way off. Just going to have to embrace the rattle. Thank you again.
    NewImprovedRon likes this.
  4. Oct 21, 2017 at 4:18 PM
    War_Wagon312
    Rich
    Stock horse
    Hahaha I just did a back flip from the seated position. I need the help so I am game. Maybe throw an inch strip up front and an inch in the middle and an inch in the rear to hold it. I'll try it on one side and if I muck things up I won't do the other side. I will keep the window rolled up for 24 hrs to make sure it seats correctly. I'm thinking get the thinnest double sided tape I can find? I set needed someone to bounce ideas off.
  5. Oct 21, 2017 at 5:36 PM
    War_Wagon312
    Rich
    Stock horse
    I'm gonna do it tomorrow. I'll let you know afyer 24 hrs how it worked. Thank you for supporting team blue and Thank you for your army service!.
  6. Oct 23, 2017 at 11:21 AM
    War_Wagon312
    Rich
    Stock horse
    Tape worked mint. No flap no rattle and they stay put instead of floating around in the channel. Solid work sir!.
  7. Oct 23, 2017 at 11:25 AM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    I have 3m double sided on mine. also had the same tape on my 2015.. never a problem, easy to install.. I already typed all that before I saw that your problem was solved, so I refuse to delete what I have just typed. Congrats! lol
  8. Oct 23, 2017 at 11:28 AM
    War_Wagon312
    Rich
    Stock horse
    Love the dedication! All good man I have done that several time so I'm with you. I know from here on out to slap some on right away and avoid the nonsense.
