Something so easy....
Discussion in '2nd Gen Tundras (2007-2013)' started by Jtimon, May 10, 2025.
  1. May 10, 2025 at 12:29 PM
    Jtimon
    Jtimon [OP] New Member
    I went to replace my ignition coil for cylinder 7, I was seeing that misfire error. Expecting something straight forward. Well to my surprise, when I pull out the previous ignition coil, the rubber boot part decided to stay seated at the bottom of the hole.
    Being cylinder 7, I have little to no visibility into the hole, and even if I did, I don't have a clue how to free the boot from the bottom.
    Does anyone have some wisdom they could share with me?
  2. May 10, 2025 at 12:56 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Bore camera and a hook, harbor freight or Amazon. Cheapest option wins, unless you want it long term.
    Edit: btw the easiest jobs are the ones that usually turn out to be the longest jobs.
  3. May 10, 2025 at 1:43 PM
    Needle nose pliers. The loooooong skinny kind
  4. May 10, 2025 at 2:00 PM
    Rathesun
    Rathesun New Member
    Alaska
    2013 Tundra Double-cab 5.7L engine
    Tunrod and Jtimon[OP] like this.
  5. May 10, 2025 at 2:16 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    2021 DC SR5 4x4 (guess the color)
    A pick set helps. Run a straight pick or precision screwdriver between the boot and the spark plug to break the seal. A shot of WD40 can help. Use a 90-degree pick or hook to grab it; pull gently.
    Jtimon[OP] likes this.
  6. May 10, 2025 at 2:22 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    IMPORTANT: make sure you get the spring that goes in the boot between the plug and coil body!
    Jtimon[OP] and blackdemon_tt like this.
  7. May 12, 2025 at 9:14 AM
    Jtimon
    These are all great ideas! Thank you!
    Going to get a bore camera and long nose hemostat I think.
    Also, had an early morning thougth, why not just pull the spark plug out? Provided the boot doesn't get in the way
  8. May 12, 2025 at 9:32 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 1997 FZJ80, 2003 Tacoma SR5 V6 5Spd
    The boot should get in the way
  9. May 12, 2025 at 10:05 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    To see into the plug hole all you need is a small mirror on a handle and a flashlight. Angle the mirror correctly and bounce the light off of it.
  10. May 23, 2025 at 11:12 AM
    Jtimon
    To circle back on this, I have a borescope and a hemostat. I am able to grab the boot with the hemostat, but have spent like 45 mins trying to get it to come free. The hemostat eventually slips off before the boot releases its grip on the spark plug.
    Any ideas on what to do next?
  11. May 23, 2025 at 1:16 PM
    Mr Badwrench
    Mr Badwrench New Member
    Someone above mentioned using a pick. You might try a little WD at the base of it and try to twist it with a hooked, or right angle pick. Can you get a big flat screw driver into the hole? You might be able to twist and manipulate it enough to break it free. Acetone might work to soften the rubber too, I wouldn't dump a bunch in though.
    Another thought... maybe a heat gun?
